Brakes stuck after washing the truck??????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BBBsti LTD, Oct 26, 2010.
  1. Oct 14, 2016 at 8:15 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Holy 6 year old revival.
    Scrat likes this.
  2. Oct 15, 2016 at 6:23 AM
    mshultz
    mshultz Well-Known Member
    Michael
    Wooster, Ohio
    Barcelona Red
    My 2014 does that after washing the underbody. The last time, I had to drive it half-way out of the garage with the right rear wheel locked, until I had enough room to back up and break it loose.
    It is caused by the semi-metallic brake pads rusting fast to the brake drums. In the old days, vehicles had asbestos pads which did not rust.
    The solution is to not set the parking brake until the brake drum has time to dry.
    BillsSR5 and Scrat like this.
  3. Oct 31, 2016 at 6:59 AM
    Scrat
    Scrat GRYLNG
    Jacob
    Woodland Park
    V6 SR5 '15
    ARE CX Topper, Yakima rails with various accessories, Bilstein 5100, Icon RXT, OME 886 coils, Firestone Ride-Rite, 265/75/16 KO2, Mobtown Offroad Rear Bumper., Diode Dynamic map and dome lights, headlight harness, Cali-raised bed stiffeners, Cali Raised accessory bed mount, Cobra 75wx st, Leixen VV898e, Safari Snorkel, SOS Sliders, CBI Full skids pack, and more coming!
    I use my parking break often when parking on inclines. Thanks for the info.
  4. Oct 31, 2016 at 7:19 AM
    Blues0010
    Blues0010 Well-Known Member
    Ben
    Boise, ID
    2001 Tacoma SR5
    My parking break will do this after being washed. Haven't found a solution yet but it always seems to free itself.
  5. Mar 31, 2018 at 6:26 PM
    wmartin9385
    wmartin9385 Member
    Bill
    Saranac Lake, NY
    2004 Tacoma Double Cab 4x4
    Bilstein 5100 shocks all around, old man emu springs, add a leaf.
    Had this happen to my 2011 today. Washed it, let it sit for a couple hours, then went to pull out of driveway, in second gear, and rear brake seized up, stalling out the motor.
    Started back up, was able to go in reverse back into driveway. Then put it in 4wd low, and the rear wheel really froze up. Couldn't go forward or back, just chirping/dragging tires.
    After reading this post, I decided to take the wheel off and beat the brake drum around the outside with a hammer. Put the wheel back on, seemed free, then froze up again at the end of the driveway. ... Repeated process with hammer.
    Finally freed up and drove the hundred miles home. No issues since. ...Weird Tacoma stuff. Guess beating the brake drums every 105k is standard maintenance.
    Thanks for all the previous responses.
  6. Mar 31, 2018 at 9:41 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Clean and adjust the shoes, put some dabs of grease at the contact points between the shoes and the backing plate
    BillsSR5 likes this.
