Brakes Tighten
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Comerlover23, Feb 3, 2025.
  1. Feb 3, 2025 at 7:55 AM
    Comerlover23
    Comerlover23 [OP] New Member
    Is there any way to make my brakes tighter? I know the rear drums can be adjusted but it still dosent feel too tight. Bleed them too any way they can be adjusted? Maybe in pedal?
  2. Feb 3, 2025 at 8:15 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Adjusting the drums will not make them stronger. The only option you have is to get a membership here.
    t0p_d0g, jmneill and YF_Ryan like this.
  3. Feb 3, 2025 at 8:20 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    2020 TRD PRO // 2010 VETTE ZR1
    I assume you mean to achieve a higher pedal ?? CK the front brake caliper mounting slides , bushings & pad brackets., If they are rusted up & seized this will cause the caliper to not adjust, causing a low pedal.. If you are in a salt belt this is a major problem. IF you can pump the brakes 1 time and the pedal is higher this is the problem...Can't tell where you are from !!
  4. Feb 3, 2025 at 7:10 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Using the parking brake adjusts the rear shoes correctly.
