Brakes went soft completely out of the blue
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gmonatl, Jul 24, 2022.
  1. Jul 24, 2022 at 7:03 PM
    Gmonatl
    Gmonatl [OP] New Member
    GM
    2003 prerunner 4x4
    Within the last three years I have replaced front brake pads and rotors and the rear drums and shoes. My brakes have been firm and effective until a week or two ago. The pedal has gone soft. On first push of the pedal it very nearly goes to the floor. at any decent speed on the road I would definitely not be able to stop suddenly. I have parked it until I can figure this out. Let me add these facts and observations:
    Front pads and rotors are in great shape
    Rear Shoes and drums are in good shape, one drum may be ever slightly warped
    No leaks anywhere I can see. it stays in my garage which has a painted floor and would notice a leak
    Brake reservoir is absolutely full and has not been topped off since the brake work a few years ago
    The brakes will pump up and actually seems like they will work, but a firm push on them 1) wont stop the truck effectively 2) pedal goes to the floor after "breaking through" the initial firmness i was able to get by pumping. To be more clear it initially seems like it will be a crisp braking action then the pedal breaks through something and goes to the floor.
    I am about to dig into the problem and thought I'd float it here first. I intend to bleed the brakes tonight as that seems to be the fist action prescribed in the service manual.
    Any thoughts will help!
    2003 Tacoma Extended Cab 4x4
  2. Jul 24, 2022 at 7:20 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Vacuum pump failure maybe?
    Funny how the 3rd gen manual says to replace that part like it's a consumable. Wonder if it's the same on yours.
  3. Jul 24, 2022 at 7:26 PM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    Master cylinder gone bad? Time for a rebuild? Disclaimer: shot in the dark, no actual experience or authority to diagnose on a hunch.
  4. Jul 24, 2022 at 7:28 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Usually brake booster or master cylinder, assuming no air in the system.
    If I had to guess, probably master cyl.
    TWJLee and GrundleJuice like this.
  5. Jul 24, 2022 at 7:45 PM
    Gmonatl
    GM
    2003 prerunner 4x4
    Thanks for the feedback. another quick question: what is the function of the booster, beyond the obvious? how does it work?
  6. Jul 24, 2022 at 8:06 PM
    0xDEADBEEF
    Booster uses vacuum from the engine to enhance your input to the brakes,giving you more braking force than you would have otherwise.
    Gmonatl[QUOTED][OP] likes this.
  7. Jul 24, 2022 at 8:07 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
  8. Jul 24, 2022 at 8:10 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    With no fluid loss evident I'd lean towards the master cylinder. I haven't done one on a 1st gen but the part is less than $100 and usually only takes about an hour from start to finish, including bleeding the brakes.
  9. Jul 24, 2022 at 10:51 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    Sounds like the master cylinder took a dump. I had an old Honda that did that. I took it in for a smog test and as I was leaving the shop the brakes went soft. Changed out the m/c and bled the whole system out and brakes were solid again. Remember to bench bleed the m/c before you install it back in your truck.
    TWJLee likes this.
  10. Jul 25, 2022 at 5:54 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    If you are losing fluid and its not on the ground, then its draining into the brake booster....
    Master cyclinder rebuild kit is about $70.....
    If that brake fluid gets into the booster, those are many hundreds of $ to replace....
    So neglecting a failing master could get very expensive.
    If the booster is going out, you would of gotten a hard pedal instead.
    Gmonatl[OP] likes this.
  11. Jul 25, 2022 at 6:14 AM
    gzig5
    gzig5 Well-Known Member
    Mequon, WI
    2002 Tacoma PreRunner 2WD
    Can the load sensing proportional valve over the rear axle cause this? When I was looking into replacing mine, I seem to remember some reports of a soft pedal indicating a problem with it.
  12. Jul 25, 2022 at 7:08 AM
    O'Silver_Taco
    MD
    If you got air/moisture anywhere in line, the brakes get super soft when all that heats up and expands.....
    Is there a difference between cold and hot?
    Any chance you need to rebleed the master.....
  13. Jul 25, 2022 at 6:35 PM
    Gmonatl
    GM
    2003 prerunner 4x4
    No they are soft pulling out of the garage and soft putting it back. I have ordered a new master cylinder. My plan is to remove the old one, bench bleed it, install, do a system bleed and see where i am. Thanks to everyone for the input.
  14. Aug 28, 2022 at 12:15 PM
    dikster
    dikster New Member
    1998 tacoma trd
    none
    OP..what is result of your brake problem?
