Brakes will not bleed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotafreak89, Nov 29, 2024.
  1. Nov 29, 2024 at 10:41 PM
    Toyotafreak89
    Toyotafreak89 [OP] Member
    Brad
    09 gray 4dr short bed 6spd manual 4x4
    2in lift, cmc, 35x12.5x15
    I just recently installed a rear locker in my truck and now unable to figure out why I cannot get my brakes to bleed and actually work well. I am able to squishy pedal back but that is it. I have to pump the pedal 2 or 3 times then it will firm. I’ve used the traditional someone in the vehical on the brake pedal and also vacuum bled with no more air bubbles.
    any insight would appreciated
  2. Nov 29, 2024 at 10:48 PM
    Taco y mas
    Taco y mas Well-Known Member
    SoCal
    Tacoma TRD Sport
    None
    Bleed the one farthest from the master first. Then move closer and closer. If that doesn't work there is air in the master.
    oldtimertoyota and super_white like this.
  3. Nov 29, 2024 at 10:52 PM
    TacoTuesday1
    FL
    The factory and every mechanic for years use pressure bleeding but what do they know
    Why I oughta... likes this.
  4. Nov 29, 2024 at 10:57 PM
    Toyotafreak89
    Brad
    Found a Toyota manual how to bleed them and it said passenger rear, driver front, driver rear and then passenger front.
    how do you bleed the master in the truck. I’ve only ever bled them on the bench.
  5. Nov 30, 2024 at 12:23 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    You can bleed them, on the vehicle, it's just way more messy, and you don't want brake fluid on paint. You pump the pedal and crack one of the lines, you should have rags or a container to catch the brake fluid.
    I prefer doing it on the bench.
    I usually do: L/R, R/R, R/F, then L/F.
    Taco y mas likes this.
  6. Nov 30, 2024 at 3:54 AM
    Why I oughta...
    Why I oughta... Well-Known Member
    2014 Base AC 4x4 2.7 5speed
    I used one of those motive power bleeders when I changed my brake fluid. No problems and the pedal stayed firm afterwards. I think they would work well for just bleeding also.
  7. Nov 30, 2024 at 5:10 AM
    Clearwater Bill
    Billy
    Largo Florida
    ABS?
    If air got into that, conventional bleeding won't correct it.....
  8. Nov 30, 2024 at 6:30 AM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    If air got into the ABS module you could take the truck to a gravel/dirt road drive and then slam on the brakes to activate the ABS then take it back home and bleed it. You might have to repeat, if you have more air in the ABS module.
  9. Nov 30, 2024 at 6:31 AM
    Micbt25
    TM
  10. Nov 30, 2024 at 7:43 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    TRD-ORs have the electric booster that makes bleeding easy. Just press the pedal and open a bleeder. the pump will push fluid.
    techstream is needed to bleed the ABS pump. You can get the dongle and some sketchy software from Amazon. There is a very helpful virtual box image out there that makes install easy if you have that technical knowledge. This is what I did and having the toyota software opens up some possibilities.
  11. Nov 30, 2024 at 7:52 AM
    Toyotafreak89
    Brad
    Thanks I’ll give it a shot. My abs light is on. Thx
  12. Dec 1, 2024 at 9:25 AM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    I just did rear suspension, had to disconnect rear brake lines in order to bolt up leafs. I had to bleed my brakes multiple times, to get normal braking. Used harbor freight brake bleeder.
  13. Dec 1, 2024 at 9:58 AM
    Dustrider
    Dustrider Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    If you have drum brakes and the shoes aren't manually adjusted up close to the drum, even if there is no air, it will take several pumps before the shoes travel far enough to firm up the pedal
    and the assistant pumping the brake pedal is unlikely to work , I have had good results with the Miti-Vac
    winkel likes this.
