Brakes won’t bleed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WhiteTaco427, Sep 25, 2024.
  1. Sep 25, 2024 at 8:46 PM
    WhiteTaco427
    WhiteTaco427 [OP] Member
    2010 White Tacoma 4x4 V6
    3” bilstein lift, 285 KO2s
    Hello forum. Just finished up putting new suspension in my truck and tried to bleed brakes but can’t get any pressure into my pedal. Pumped for more than 15 minutes (way too long to be pumping for anything) and still nothing. New leafs so had to disconnect. No cracks or leaks in the line. Slightly sloped driveway, ass end sat down all night with a slow drip from the lines due to a bad plug job. Air in MS? Bench bleed?
  2. Sep 25, 2024 at 8:54 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Use a vacuum bleeder, you can buy a cheap one at Harbor Freight. Unless you were doing something extreme you could’ve left the brake lines connected by just disconnecting the mount point in the middle of the rear axle.
    Micbt25 likes this.
  3. Sep 25, 2024 at 8:54 PM
    zguy1
    zguy1 Well-Known Member
    Midwest
    Did you put the key in the ON position?
  4. Sep 25, 2024 at 9:04 PM
    WhiteTaco427
    New leaf pack. USUALLY easier to disconnect and just bleed after but not this time lol.
  5. Sep 25, 2024 at 9:05 PM
    WhiteTaco427
    For most of it. Part of it, the car was totally off.
  6. Sep 25, 2024 at 9:08 PM
    zguy1
    Midwest
    No expert here, but I flushed my brake fluid just a few days ago. On my first attempt to bleed my brakes with the brakes pumped up and the pedal depressed, no fluid would come out of the bleeder screw. Only when I had the ignition on would fluid come out of the bleeder screw.
    EDIT: you could clearly here the brake booster actively pumping while bleeding with the ignition on.
  7. Sep 25, 2024 at 9:11 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    TRD OffRoad (not sure what year this started) has an electronic brake booster, so it would make sense for these to need the ignition on.
    Others, probably same as an any vacuum boosted vehicle.
    OP - what model is your 2010? Got a photo of your brake booster?
    EDIT: it may be the 2012+ with ATRAC TRD OffRoad models that have the electronic brake booster only.
  8. Sep 25, 2024 at 9:16 PM
    WhiteTaco427
    It’s a base model. No TRD off-road. I can get a photo tomorrow.
  9. Sep 25, 2024 at 9:29 PM
    Bishop84
    Bishop84 Well-Known Member
    Did it run empty? It shouldnt be an issue.
    A few things, the bleeders may be plugged, especially if its rusty.
    The ABS module may have a huge amount of air in it.
    What I do is remove the bleeder entirely and make sure flow is getting to them. If need be I drill out the ports and clean them.
    Full stroke bleeds are an alternative to pump and bleed, so you build up pressure, let off the pedal, open the bleeder, then full stroke, close bleeder.
    Hopefully it doesnt come down to an ABS bleed.
  10. Sep 25, 2024 at 9:37 PM
    WhiteTaco427
    Ok gotcha. The pedal won’t build up pressure at all. Doesn’t matter how long I pump it. I’ll check the clog problems tomorrow.
  11. Sep 27, 2024 at 9:48 AM
    WhiteTaco427
    Bled the master using a bleeder kit and brakes bled after just fine.
