Brakes won't build pressure. Booster?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jad275, Jul 13, 2020.
  1. Jul 13, 2020 at 4:18 PM
    Jad275
    Jad275 [OP] Member
    2000 6cyl 4x4
    6" lift
    Hey y'all. My brake pedal is going ask the way to the floor now, very poor braking. I tried bleeding the lines, which helped a little but the pedal doesn't seem to be building pressure. I think it's a problem with the booster. When i push the pedal, I can hear and feel air coming out of the rubber part (pictured). I tried bleeding more, but it seemed difficult, as if there was very little pressure building up in the system.
    What do you guys think? I'm thinking replace the booster. $211 AutoZone. They have two different parts with two different diameters (8.5" and 9" iirc?) The guy said he would check based on my vin.
    Thanks!
    2000 trd 4x4 6cyl 3.4l
  2. Jul 13, 2020 at 4:26 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    A failed/failing booster would result in a hard pedal and rpm variation as you brake.
    A soft pedal would be due to air in the system, failing soft lines that swell when you press the brakes, failing/failed master cylinder. Also, check the adjustment of your rear brakes.
  3. Jul 14, 2020 at 2:42 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Using the Parking brake if it works correct keeps the rear shoes adjusted.
    The shoes get out of Adjustment it takes pedal travel to meet the drum.
    Has the fluid level in the Master Cylinder dropped??
  4. Jul 14, 2020 at 5:29 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    That's not how a booster works, it only amplifies the effort you apply to the brake pedal into the input of the master cylinder. It doesn't have a thing to do with the hydraulics. You probably have a failing master cylinder.
  5. Jul 14, 2020 at 8:07 AM
    Jad275
    Jad275 [OP] Member
    2000 6cyl 4x4
    6" lift
    The fluid level in the master did not drop. I ordered a new master, we will see how that works. I'll do some diagnostics today since it doesn't arrive till afternoon.
    I talked to my neighbor, who is very savvy, he said it might be a check valve in the brake lines, and it is essential to bleed the brakes evenly, the same amount on all 4 valves. I've definitely never worried much about that, bleeding the passenger rear side most since it's furthest from the master.
    (Unrelated, but he has Toyota truck pre 1st gen with over a million miles!) He thinks it's a booster problem, likely the diaphragm burst and won't hold pressure. He said I could check it with a host to see if it holds pressure. I'll be trying to find a YouTube video on that this morning...
    Thanks guys!
