Brakes Won't Work.... Can't Shift Out of Park... HELP!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Slodgetto, Jun 19, 2012.
  1. Jun 19, 2012 at 2:53 PM
    Slodgetto
    Slodgetto [OP] Über Posre
    Silas
    Specs: 99 Tacoma, 3.4 V6, Automatic, No ABS
    Was working on my bed bob/dovetail when I decided that I needed to make an errand.... so I plugged my tail lights in real quick and secured them. When I went to make sure they were working, I discovered that the brake lights weren't coming on! The blinkers worked, and the red part worked when I turned the headlights on, but still no lights when depressing the brake pedal. I then tried to put the truck in drive and the shifter would not let me. (which tells me the truck doesn't think I'm even pushing the brake pedal.) so I checked fuses and all seems to check out there. I have been noticing a squishy brake pedal and less braking power these last couple of weeks, and it was even worse now, so I decided to inspect and bleed the system. Saw no leaks or damage to the brake lines and proceded to bleed the system with a vacuum pump (starting with RR, LR, BPV, RF, LF). It didn't help at all, so I thought maybe my pump wasn't effective so bled the system again, this time with a partner on the brake pedal. Brake pedal still very mushy (easily is pressed down to the floor) and can't shift out of park.
    My guess is master cylinder.......:( What do you all think?
  2. Jun 19, 2012 at 2:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Blown fuse. Find the blown one, and replace it.
  3. Jun 19, 2012 at 2:58 PM
    Slodgetto
    Silas
    I looked.... :eek: maybe I need to pull a few more..
  4. Jun 19, 2012 at 3:00 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    check fuses or maybe the stoplamp switch?
  5. Jun 19, 2012 at 3:05 PM
    Slodgetto
    Silas
    Found it. :eek: 15A fuse labeled "STOP." Thanks guys, I feel like a retard.
  6. Jun 19, 2012 at 3:15 PM
    white toy taco
    white toy taco 505 Member
    Albuquerque, NM
    '06 OR and '02 OR (sold)
    hahahaha thats hilarious man!
  7. Jun 19, 2012 at 3:17 PM
    Slodgetto
    Silas
    :anonymous: at least there's not a single bubble of air in there now.... :D:laugh:
  8. Jun 19, 2012 at 3:20 PM
    white toy taco
    Albuquerque, NM
    yea exactly and everything is all nice and clean
  9. Jun 19, 2012 at 3:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  10. Jun 19, 2012 at 3:29 PM
    Slodgetto
    Silas
    :D
    :eek:
