Brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by David Tarantino, Dec 22, 2010.
  1. Dec 22, 2010 at 9:32 AM
    David Tarantino
    David Tarantino [OP] Well-Known Member
    N.J.
    08 tacoma
    Ok what brake pads rotors you guys useing
  2. Dec 22, 2010 at 9:33 AM
    HomerTaco
    HomerTaco All up in your GRILL Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    Stock.... Do you have suggestions on an upgrade???
    I'm gonna need new rotors soon!:rolleyes:
  3. Dec 22, 2010 at 9:35 AM
    David Tarantino
    N.J.
    08 tacoma
    thats what iam looking for a upgrade
  4. Dec 22, 2010 at 9:38 AM
    HomerTaco
    Craig
    Bucks County Pa.
    Gotcha.:popcorn:
  5. Dec 22, 2010 at 9:39 AM
    SManZ
    SManZ el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I'm running Hawk HPS pads on EBC Sport dimpled/slotted rotors.
    The rotors were a freebie so I can't complain, but if I had to actually pay for them they're not worth the $200 unless the cool look is worth it to you.
    The Hawk HPS pads are a good buy, but I'm going to try the LTS pads on my next go around. The HPS work well until they get too hot, which takes 4 or 5 repeated stops from 60mph. Around where I am thats pretty common driving.
    Goodridge stainless steel lines are the single best investment I've made to the brakes. It gets rid of that spongy feel and I'm very happy with them. They're just time consuming to install and you must have flare nut wrenches.
  6. Dec 22, 2010 at 10:02 AM
    David Tarantino
    N.J.
    08 tacoma
    yeah i have all the tools i was just looking to see what was working best on our trucks :D thanks guys
  7. Dec 22, 2010 at 12:34 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
  8. Feb 17, 2011 at 2:47 PM
    Ray07tacoma
    Ray07tacoma Well-Known Member
    Ray
    Phoenix
    07 Tacoma access 4x4
    turbo KN Filter 3" Lift Kit Rock Sliders TRD Skid plate ProComp 285/75R16, Removed. FJ Wheels w/ 265/70R17 Delay wiper switch 168xxx miles, engine lost compression at cyl 1. Replaced with pulled engine with 63k miles (non Turbo).
    truck has 84k, no issues with brakes but need new pads now. 6 lugs oem rotor with 17" rims/tires.
    I have a F150 with drilled rotors and ceramic pads that I am very satisfied, so I was thinking about ceramic pads for the Taco;
    so I called Hawk and salesman is telling me that HPS pad are better?? so I am asking feedback from anyone that are using either one.
    trying to decide which works best.
    Appreciate any comments
  9. Feb 17, 2011 at 2:55 PM
    Ray07tacoma
    Ray
    Phoenix
    which Hawk pads, ceramic, LTS, HPS???
