Brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by timinco77, Dec 7, 2008.
  1. Dec 7, 2008 at 10:57 AM
    timinco77
    timinco77 [OP] Active Member
    Colorado Springs
    07 Tacoma Access Cab
    Rear TSB
    Hey guys, I have a 2007 Access Cab, 4.0 v6, 4x4. I only have 12k miles on it. My brakes are vibrating while stopping slowly. But when I floor the brakes its smooth as cutting butter. Also it will pull to one side or the other while braking. Any sugestions? Or should I just bring it in.
    Also one more thing. I know there have been many post about how sensitive the tacomas are on tire balaning and alignment. I have had to bring my truck back to the dealer ship three times now, since have my SPRING TSB to redo the alignment and tire balance. What if anything do you think I should do. Thanks
  2. Dec 7, 2008 at 11:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The vibration could be caused from 2 things. 1, the wheels were not torqued propperly when installed, or 2, the rotors may be slightly warpped.
  3. Dec 7, 2008 at 2:52 PM
    TACOMAN22
    TACOMAN22 Well-Known Member
    agoura hills
    Debadged TRD offroad, bhlm, black surround grill,
    K&N drop in air filter,flowmaster 40 series, blue interior neon, bhlm, color matched grill, alpine head unit w/ infinity reference series speakers, insane driver.....
    or it could be the abs
  4. Dec 7, 2008 at 7:14 PM
    timinco77
    Colorado Springs
    Rear TSB
    thanks for the information guys, i am going to make an appointment next week to get my truck in. I just really don't trust the dealership closest to me.
  5. Dec 7, 2008 at 7:18 PM
    wushaw
    wushaw Well-Known Member
    Texas
    08 AC TRD 4x4 6sp
    What did the TSB have to do with tire ballance?
    It's obvious that their ft. end man is having issues with aligning your truck.
  6. Dec 8, 2008 at 4:24 AM
    davatk
    davatk Well-Known Member
    Northwestern Virginia
    2009 DC TRD Sport Long Bed
    Tube Steps, Hood Deflector, ScanGauage, GPS
    First, if you are physically able, always rotate your tires yourself, and DO NOT overtighten the lugs. Use the lug wrench that came with the vehicle, and just get them tight, but don't stand on the lug wrench. Make sure you apply the approximate same tightness to all of them. This will save you a bunch in rotor replacement/turning costs. I have found that almost all auto/tire places will overtighten the lug nuts with their impact/air wrenches, which will essentially warp the rotors. Some even claim it "torque" them, but from what I've seen, I'm not sure they even do that properly - eg. if they overtightened it in the first place they need to re-loosen it to apply the appropriate torque. I haven't had any rotor problems since I started rotating my own.
    Since it sounds like they may already have screwed yours up (did they remove the wheels when doing the TSB ?), you may need to have them replace your brakes/rotors, then MAKE SURE they torque the lugs properly, or maybe even better, bring it home and retorque the lugs yourself after they get done.
  7. Dec 8, 2008 at 6:28 PM
    timinco77
    Colorado Springs
    Rear TSB
    Hey thanks for you reply. They threw in a free rotation when I got my TSB done, so yes they did removed the tires. I have only had this problem since they did that. Should I invest in a torque wrench with a display to show me the correct torque? I will be bringing my truck in next week, i have a feeling they are going to fight me and I will need to call customer care.
  8. Dec 8, 2008 at 6:40 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    When I went in last week to have my RLS TSB done, they said my truck was elegible for a brake TSB which was new pads and turned rotors.
  9. Dec 8, 2008 at 8:12 PM
    timinco77
    Colorado Springs
    Rear TSB
    Thats good to hear, I did not realize there was a brake TSB.
  10. Dec 9, 2008 at 8:22 AM
    davatk
    Well, I don't have a torque wrench, I just do it by feel. But if you are one of those guys who thinks they need to stand on the lug wrench when tightening, then by all means you need a torque wrench ! :D
