Brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bking91, Aug 5, 2020.
  1. Aug 5, 2020 at 4:24 PM
    Bking91
    Bking91 [OP] New Member
    2009 Tacoma
    First post! I have a 09 4wd 2.7 my calipers are starting to stick any tricks to free them up? Or should I buy new ones? I live in Ohio so they get salt. pad wear is grooved out on the outside and inside of pad
  2. Aug 5, 2020 at 4:30 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would just get new ones. Not worth the hassle IMO to rebuild.
    TnShooter likes this.
  3. Aug 5, 2020 at 5:11 PM
    Clearwater Bill
    Billy
    Largo Florida
    What is sticking? The pistons? If so, and they made it 11 years, they deserve to retire.
    Most people never service their brakes until brake work is needed from poor performance. Salt country folks should service them at least annually when doing frame rust preventative. Maybe more often if they are off road in water/muck a good bit.
    Jimmyh likes this.
  4. Aug 5, 2020 at 5:12 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    I just did my front brakes, rotors and calipers. One caliper had only one cylinder working. The service records indicated that the prior owner didn't spring for the calipers (was recommended by Toyota) when the frame was replaced 5 years ago, so they were original. They did do the pads and rotors. If your rust condition is anything like mine, you may need to replace the hard brake line from the caliper to the flex line. I did the flex lines also. I went with a PowerStop kit from Rock Auto. Do both sides!
