Braking and Lights/Radio Power go out
Discussion in '3rd Gen. Tacomas (2016-2023)' started by webdevl, May 10, 2019.
  1. May 10, 2019 at 5:48 PM
    webdevl
    webdevl [OP] Member
    2017 OR DCLB
    Here is a strange one for you (2017 OR Long Bed). So about two month ago I started experiencing random problem where the radio would shutoff when braking. The dealer has attributed it bluetooth and did a radio flash, ecu flash, etc, but it continues. The main problem is that when I take it is they cannot reproduce it since it does not happen all the time. Once it starts on a trip it will do it until i turn the truck off and restart and that sometime makes it to that is stops doing it, but not always. Trying to get some ideas from the community of where to start looking since I am out of warranty (45k) and tired of paying for diagnostics that do nothing.
    Symptoms:
    When hitting the brakes the radio turns off
    the headlights dim or fliker off and on
    Sometimes the dash goes dark and then comes back on
    I was able to reproduce in neutral one time in which case the entire engine shutoff. Given this I am thinking the engine kicks everything back on
    I am thinking a ground short, but don't even know where to start. Love the truck, but this is driving me crazy.
    I have some video I can post if any one wants to see, but it will be next week as I am travelling.
    Lucifer1 likes this.
  2. May 10, 2019 at 6:19 PM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    You have any rodent damage, body work done or rust issues? Sounds like a bad ground.
  3. May 10, 2019 at 6:27 PM
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    The armchair mechanic in me says charging system or battery. Battery cables clean and tight?
    Have the battery load tested.
  4. May 10, 2019 at 6:27 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Sounds like a ground or power issue. Brakes have electrical boots on some models, to they will consume a lot of power. I’d start monitoring battery voltage at different points in the trucks wiring when you get the problem. Or, just replace the battery as a quick shot in the dark and check the main grounds for corrosion.
  5. May 10, 2019 at 6:29 PM
    slowtacotruck
    17 offroad
    stuff
    It wouldn't hurt to check and see if there is voltage drop under load between the battery posts and the cables themselves.
  6. May 10, 2019 at 6:36 PM
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    lets go over the easy stuff first, Battery has been load tested and is good ? battery connectors removed,cleaned, properly reinstalled, especially the ground. what you are describing is an intermittent bad ground, or a battery that is experiencing an internal short.
  7. May 10, 2019 at 7:27 PM
    webdevl
    webdevl [OP] Member
    2017 OR DCLB
    So to answer questions
    1. Battery has been tested and tests good under no load and load. May replace anyways just to be sure
    2. 45k so out of warranty hence trying to figure this out
    3. Yes there was damage to the front right hand side 2 yrs ago and it was repaired and checked by toyota, and I have checked that area also looking for anything that could be out of place/mis-repaired.
    4. No LED's
    5. No rodent damage that I am aware of and don't live in an area with a lot of them, unless you count redskins fans :)
    Boghog1 likes this.
  8. May 10, 2019 at 7:49 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    If ground and voltage is good...the only other thing I can think of that has commonality with brakes, meter and radio; is the CAN BUS.
    Though, it should throw a U-type DTC if that were the case.
  9. May 10, 2019 at 8:04 PM
    slowtacotruck
    17 offroad
    stuff
    Anybody have a wiring diagram for one of these things?
  10. May 10, 2019 at 8:36 PM
    webdevl
    webdevl [OP] Member
    2017 OR DCLB
    So at this point I think I am going to do the following.
    1. replace the battery with a new battery just to rule that out
    2. Start tracing grounds ( does anyone have a good diagram?)
    3. hope it goes away ;)
  11. May 10, 2019 at 8:38 PM
    slowtacotruck
    17 offroad
    stuff
    I have a 94 f350 and after cleaning and spraying deoxit on the grounds I have no electrical issues. It may have a few years on our tacos though.
  12. May 10, 2019 at 9:10 PM
    splitbolt
    NW Arkansas
    FWIW, after skimming the below diagrams, I doubt it's a grounding issue.
  13. May 11, 2019 at 4:00 AM
    TD90S
    GA
    ‘18 TRDOR 6MT
    Have you had the alternator tested?
    Trailer brake installed on the truck?
  14. May 13, 2019 at 12:08 AM
    webdevl
    webdevl [OP] Member
    2017 OR DCLB
    I have not had the alternator tested yet, but will add that to the list of things to do.
  15. May 31, 2019 at 10:34 PM
    webdevl
    webdevl [OP] Member
    2017 OR DCLB
    So before I took it in I was checking the oil and noticed that the battery hold down had become loose and there was some terminal corrosion. I cleaned the battery terminals and tightened the battery hold down. This seems to have corrected the issues I was having. 200mi and not issues so far.
    Boghog1 and TD90S like this.
  16. Jun 1, 2019 at 5:57 AM
    TD90S
    GA
    ‘18 TRDOR 6MT
    Years of working on cars has taught me to always check the simple stuff first.
    Happy it was a cheap repair for you.
