Braking into the factory rear harness questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hotrod53, Jan 31, 2016.
  1. Jan 31, 2016 at 2:37 PM
    hotrod53
    hotrod53 [OP] Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    i bought some LED lights that I plan to mount under my rear bumper and connect to my backup lights. In the summer, phase II will be putting an override switch in the dash but that means running a wire from the dash to the rear. I already purchased a nice OEM looking dash switch that's on a slow boat from China ..... literally!
    What I want to do, and I'd hoped that someone has already unplugged the rear harness, is to disconnect the harness, strip back the plastic flex, tap into the 12v hot to be switched by a relay, and tap the reverse pin to fire the relay. Does anyone know how to unplug the harness connector? Does anyone know the color code for a 2014? I looked at it and I do not see a piece to push to allow me to pull the connector out. I want to be tapped into the correct side of the connector so that if the bumper is ever pulled, it will disconnect as intended.
    I purchased (2) 15 watt LEDs and I'm assuming that adding an extra 1.25 Amps per side or 2.5 amps to one side of the backup bulb wiring would not be the way to go? Opinions?
  2. Mar 25, 2016 at 12:50 PM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    No problem on adding amps to bulbs but wattage won't hurt.LEDS use a lot less amps...You will be fine..
  3. Mar 25, 2016 at 12:59 PM
    hotrod53
    Lynd
    Pittsburgh, PA
    I've had these installed for a few weeks and I love them. They light up the front of my neighbors house across the street when i back out!
  4. Mar 25, 2016 at 1:38 PM
    Hot Tacoma Blown
    NewYork
    05 4×4 tacoma
    Nice for you.Not for your neighbors.Awesome...
