Braking issue?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TaCOdeRoja, Apr 14, 2021.
  1. Apr 14, 2021 at 11:39 PM
    TaCOdeRoja
    TaCOdeRoja [OP] Member
    2020 Red Tacoma TRD Off-Road
    I just bought a used 2020 TRD Off-Road and noticed what I perceive as the brakes sticking when coming to a full stop. This only seems to happen in the last few feet or so of stopping, so I am going pretty slow. I am very light on the brake pedal, and don't press on it hard. I am new to Tacomas and pick ups for that matter. I previously drove a 2005 Subaru Outback.
    So my question.... is this normal for Tacomas or pickups in general due to its size and weight or can there be something wrong with the brakes? I figured I would get some feedback from the group before taking it to the shop to have it looked at for possible issues. Thanks in advance and I am glad to be in the group.
  2. Apr 14, 2021 at 11:50 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    welcome aboard. 2020 Tacoma. Should still be under warranty. Right? Have you looked at the brakes? Have you checked the brake fluid?
  3. Apr 15, 2021 at 8:16 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    What are the symptoms? What makes you think they are sticking exactly?
    Chew likes this.
  4. Apr 15, 2021 at 8:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    Not following what you are describing.
    Sticking brakes usually means they won't release, they drag, etc. Normally associated with everything but the actual stopping process. Exception being a sticking caliper that grabs faster than the other side, causing a quick pull to that side. Even then, the 'sticking' reveals itself in other ways too.
    Nothing exotic on these braking systems. Some would even say antiqued with the rear drums.
    So, better description/symptoms would help........
    shakerhood and Chew like this.
  5. Apr 15, 2021 at 8:34 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I think I know what you're describing. It's just a byproduct of Toyotas electronic brake booster bs. It takes a while to get used to.
    When you're coming to a stop it feels like you're letting off more and more and more but the truck keeps stopping at the same rate, right? Like it's hard to come to those zero G stops?
    TaCOdeRoja[OP] likes this.
  6. Apr 15, 2021 at 8:44 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    The Tacoma does a lot of engine braking as well. Maybe you're feeling that? Good way to check would be to turn on ECT and see if it goes away. If so, that's what you're feeling.
    Superdave1.0 likes this.
  7. Apr 15, 2021 at 3:22 PM
    TaCOdeRoja
    Thanks everyone. It is not exactly sticking in the sense that it becomes stuck. It is more like hard breaking in the last couple of feet of the complete stop. You kind of jerk forward the last few feet and I am not adding any additional pressure to the brakes. I will try it with ECT on and see if it changes. There is plenty of Brake fluid and everything was checked when I bought the vehicle. I even had a different dealership do a multipoint inspection when I had it in the shop for a different reason. I appreciate everyone's input.
  8. Apr 15, 2021 at 3:29 PM
    TaCOdeRoja
    Yes this is kind of what I am feeling. Thank you. That validates what I might be feeling with the brakes.
  9. Apr 15, 2021 at 3:34 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I'm still not used to it. But it's normal.
  10. Apr 15, 2021 at 3:37 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Could be a downshift to 1st gear adding significant engine braking. I thought the 2020s had a decently programmed transmission, though.
    If it does it every time I would take a dealer tech for a ride or ask that they drive it briefly.
    Scott Rosenberger likes this.
  11. Apr 15, 2021 at 3:41 PM
    Technique
    Alex
    Utah
    Never noticed anything like that in my truck. Even coming from a car when I first got the truck.
    Weird!
  12. Apr 15, 2021 at 3:55 PM
    Tacolife5
    Tacolife5 Well-Known Member
    Durango, Colorado
    2017 TRD Off Road DCLB
    I felt this in my friends 08 4 Runner and my 2017 Tacoma. Pretty annoying but you get used to it.
  13. Apr 15, 2021 at 11:00 PM
    TaCOdeRoja
    I don't believe it is a down shift issue. It even happens while I am inching up as I park in the garage. It will almost grab and jerk forward like a hard stop.
  14. Apr 16, 2021 at 5:07 AM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Ahh yes, doesn't sound like a downshift.
  15. Apr 16, 2021 at 6:42 AM
    jakbakcrak
    jakbakcrak Well-Known Member
    Jack
    2020 Quicksand TRD Off Road Tacoma
    Several aesthetic
    My 2018 did it and my 2020 does also from time to time. Feels like it has a mind of its own occasionally. Mine happens more in reverse, when I'm backing into my garage. I get a jerking motion, while trying to control the decelleration, while letting up and down on the brakes. Feels like the truck wants to speed up, even with brakes on and no foot on the accelerator. Other times, no problem.......temperamental beeeotch..!
  16. Apr 16, 2021 at 9:27 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Ahh okay, that makes more sense.
    To me, the brakes are good, but very grabby, when I get in to my work F150 (that has very good brakes, but very different) I sometimes feel like I'm either barreling through stop signs looking like a D, or I feel like I'm pushing hard. I prefer the Tacoma's feel.
  17. Apr 16, 2021 at 9:31 AM
    CRSTRD
    CRSTRD Well-Known Member
    2020 Tacoma TRD Off Road
    We own a 2018 and a 2020 and brakes in both are pretty much the same and take some getting used to. The term I also use is "grabby". Seems you get more braking action than the pedal force applied, at certain low-speed stops. My wife complained about it, when she first got her '18, but she has gotten used to it.
  18. Apr 16, 2021 at 7:01 PM
    TaCOdeRoja
    I appreciate everyone's input, "grabby" is the term I will use going forward. Sounds like this is just a inherent part of being a Taco owner and something I will get used to in time. You all are the best. Thank you. I can rest easy now.
    Chew likes this.
  19. Apr 16, 2021 at 7:50 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Since its a used truck maybe the previous owner put some kind of aftermarket pads on that are making it grabby, wouldnt hurt to pull the wheels and do a visual.
    Chew and TaCOdeRoja[OP] like this.
