Braking while pressing on the gas pedal question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BassAckwardsDyl, Jan 27, 2013.
  1. Jan 27, 2013 at 9:29 PM
    BassAckwardsDyl
    BassAckwardsDyl [OP] The Red Bull
    Dylan
    Kapolei, Hi
    07 Sport DC 4x4
    She is no longer the same Sport that I bought!!!
    So, just got done changing out brake pads on the truck and power bleeding the front lines. I got a little oil on the pads which is no big deal. Went for a quick drive around the neighborhood to test out the truck to make sure everything was ok. One thing I have now noticed and didn't before.... When accelerating or traveling at a consistent speed and pressing the brake pedal LIGHTLY, the truck will decelerate to almost a stop. (NO IT WASN"T THE BRAKES SLOWING ME DOWN). I pressed on the brakes just enough for the brake light to come on but not apply any pressure to the pads. Want to know if this is normal with our trucks... Again, I have not noticed this before. If I let off the brake, the truck drives like normal. Also, if i am at a stop with my foot hard on the brake and the press the gas, the truck does want to accel.
    Any feedback or comments about this would be great.... thanks y'all
  2. Jan 27, 2013 at 9:32 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    i just avoid pressing the brake and the gas pedal at the same time...
  3. Jan 27, 2013 at 9:32 PM
    TeamSarcasm
    TeamSarcasm Mr. President
    When you press the brakes....the truck will slow down :notsure:
    maybe you need to get use to the new brakes?
    Can you have to much fluid in the lines causing pre-mature braking?
  4. Jan 27, 2013 at 9:34 PM
    OZ-T
    OZ-T Did you get your precious photos ?
    Peter North
    British Columbia
    Could be the new brake override software
    Did you get the pedal chop recall done ?
  5. Jan 27, 2013 at 9:34 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    It's a normal operation. The throttle cuts out when enough brake is applied.
  6. Jan 27, 2013 at 9:36 PM
    Fightnfire
    Fightnfire Recklessly tired
    Luke
    Marysville, WA
    09 Access Cab V6 4X4
    Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Goodyear Wrangler Duratracs, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings,... oh and the hot wife mod.
    This. My truck does it too.
  7. Jan 27, 2013 at 9:36 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    2001 4x4 5Spd Xtra Cab V6
    205k+ miles, 265/75/16 BFG A/T's, OME 881's, Wheelers 5 leaf pack, 5100's, Home Made Sliders
    lame, so no brake stands for you guys.
  8. Jan 27, 2013 at 9:45 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Yup.
    Toyota's floor mat recall.
    Trim/hack the pedal so the mats won't snag it.
    Flash the software so if more than 25% throttle is applied and the brakes are applied, the ECU shuts down to idle.
    Of course, activated by the brake light switch, so if your switch is not adjusted properly, you could dump to idle when driving normally if the switch is "touchy"
  9. Jan 27, 2013 at 10:01 PM
    BassAckwardsDyl
    Dylan
    Kapolei, Hi
    07 Sport DC 4x4
    The reason i was pressing the brakes and the gas was to heat them up quickly to "burn" off the oil that was on them... just didn't want it to sit on the pads.
    The pedal chop was done without my permission a while back. Took the truck in for the blower motor under warranty and they took it upon themselves to do the pedal chop...
    Oz, Rich and File... thanks for the heads up with this. I haven't power bled my breaks since the work was done by the dealer and hadn't done both pedals at once since then... appreciate the info fellas
  10. Jan 28, 2013 at 5:37 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    No sudden acceleration for you!
  11. Jan 28, 2013 at 5:43 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You should have hit everything with brake cleaner when you were done rather than trying to 'burn off' any oil you spilled... With the wheel off, dose the caliper and rotor with CRC Brakleen to remove any excess oils and brake fluid. What you did, go for a drive knowing you had oil on your brakes, isn't necessarily the best idea.
  12. Jan 28, 2013 at 8:37 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    11 trd sport longbed
    weathertech visors,remote start,lojack, ARE z type topper, wet okole seat covers, pop n lock tailgate lock
    i agree with this post. any oil even brake fluid isnt a good thing to just try and burn off. those pads will chatter forever
  13. Jan 28, 2013 at 12:09 PM
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    Hahahh I used to something similar in my turbo integra. Build full boost while driving 20mph. 3rd honk and release of the brake.....gone.:cool:
    In the turbo world it's called brake boosting.
  14. Jan 28, 2013 at 12:12 PM
    JKD
    JKD Well-Known Member
    Brake stand should work. The brake override is only supposed to kick in if you hit the brakes after gas.
  15. Jan 28, 2013 at 3:00 PM
    File IFR
    Central MA
    ... wait for it.
    :ohsnap:
    :D
  16. Jan 28, 2013 at 5:24 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    video or it can't happen :p
