Brand new 19 OR 4wd stuck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by stoonley, Oct 19, 2019.
  1. Oct 19, 2019 at 7:24 AM
    stoonley
    stoonley [OP] Member
    Shawn
    '19 TRD OR DCSB
    put into 4wd and the truck stopped pulling into a parking lot. Tried to take out of 4wd and the light stays blinking. Can’t accelerate the truck. Less than 30 days off the dealer lot.
  2. Oct 19, 2019 at 7:27 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    Are you doing this on dry pavement?
    GreyBaldTaco, dirtydog57 and Junkhead like this.
  3. Oct 19, 2019 at 7:27 AM
    stoonley
    Shawn
    '19 TRD OR DCSB
    Yeah
    Junkhead likes this.
  4. Oct 19, 2019 at 7:27 AM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    Did you keep moving a little bit?
    I have to wiggle the steering wheel and creep forward for mine to drop out at a complete stop.
  5. Oct 19, 2019 at 7:28 AM
    DTaco18
    ^^ Bad idea unless only going straight... Binds up everything.
    Put selector back in 2WD so that the light flashes, and move steering wheel back and forth a little while moving at like 1mph. Should drop back out of 4WD.
    GreyBaldTaco and Junkhead like this.
  6. Oct 19, 2019 at 7:34 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    If you were doing a tight turn on dry pavement in 4WD, it will bind. That is normal behavior. Driving on dry pavement in 4WD is not. As mentioned, leave it in 2WD and maybe try backing up and moving forward while slightly moving the steering wheel back and forth to get the gears to let go.
    GreyBaldTaco likes this.
  7. Oct 19, 2019 at 7:39 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Ugggh. So much to learn here.
  8. Oct 19, 2019 at 7:43 AM
    whitepony04
    whitepony04 The Big Igloo is coming...
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    Eibach pro kit, 3 leaf aal, ecgs, fn fx pros, bfg ko2, gator sfx, Meso stuff
    Learning is stupid
  9. Oct 19, 2019 at 7:45 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    At least it's not reading. Eww.
  10. Oct 19, 2019 at 7:47 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Truck is broken, please trade in for ranger asap.
  11. Oct 19, 2019 at 7:57 AM
    stoonley
    Shawn
    '19 TRD OR DCSB
    That fixed it. Thanks. Lesson learned
  12. Oct 19, 2019 at 7:58 AM
    dirtydog57
    dirtydog57 Well-Known Member
    Colorado
    2019 SR
    Oof
  13. Oct 19, 2019 at 8:01 AM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    Don’t feel bad. You’re not the first nor the only one. I’ve learned this lesson on my own also and found that others had same issue when I logged onto internet to search for why my new truck could be coming to a stop for what I thought was no reason. It’s ok on slow turns but 90 degree turns.... doesn’t end well. Just be thankful you didn’t learn this trying to do a u-turn on the highway :)
    And by the way, I learned my lesson pulling into a parking lot thankfully also!
  14. Oct 19, 2019 at 8:07 AM
    Stocklocker
    17TRDORDCSBAT
    OP,
    The truth:
    With a Toyota truck that is “malfunctioning”, your first questions should always be “what am I do wrong”. 99.9% of the time, you will be fucking up, and will need to consult the manual, or educate yourself, here or elsewhere. They chances of it being a defective truck are slim. I suggest you seek out some “how a 4WD system works” type videos on YouTube (there are many good ones) and start from the beginning.
    This is a great resource:
    https://m.youtube.com/watch?v=47m7QAPrpsI
  15. Oct 19, 2019 at 8:07 AM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    Dry pavement 4wd doable only going straight... NOTHING will brake if op do this to keep everything lined...
    I do this around 1 or 2 days a week on a 4 mile long dead straight stretch of road on my way to work..
    GreyBaldTaco and Thunder Fist like this.
  16. Oct 19, 2019 at 8:11 AM
    Stocklocker
    17TRDORDCSBAT
  17. Oct 19, 2019 at 8:11 AM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    I had a similar experience. Pulling out of a parking lot, watching traffic, I reached down to turn the ac fan up a bit and accidentally got my hand on the 4WD knob. Traffic cleared and I started a turn out of the lot and damn, it started bucking like a pissed off bull. Two seconds of that and I figured out what I did and quickly fixed it. Much more careful now.
    Stonerok likes this.
  18. Oct 19, 2019 at 8:16 AM
    piff
    piff Well-Known Member
    Minnesota
    2019 Quicksand Tacoma TRD OR DCLB AT
    Bone stock baby
    Curious that Tacoma doesn't have a center diff? How does it engage 4wd? Guess I need to do some learning!!
  19. Oct 19, 2019 at 8:20 AM
    0xDEADBEEF
    It has a transfer case, which essentially locks together the front and rear driveshafts. Going around a corner they need to be independent or else it binds.
    AWD adds a center differential, but there are downsides that are not good to have for real offroad use.
    GreyBaldTaco and shakerhood like this.
  20. Oct 19, 2019 at 8:21 AM
    Stocklocker
    17TRDORDCSBAT
    You have a transfer case. The center diff in some vehicles gives them an “all wheel drive feature”, which allows the front and back wheels to run at different speeds in addition to differences left-to-right,
