Brand new 2012 Tacoma V6 slight rough idle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cfrea, May 8, 2012.
  1. May 8, 2012 at 5:51 PM
    cfrea
    cfrea [OP] Well-Known Member
    2012 Tacoma Double Cab TRD Sport
    My Tacoma idles a bit rough. Not horrible but I can feel a little vibration/shake when it's idling at a stop light. Is that normal or should it be fairly smooth?
    Brand new with like 300 miles on the odo.
    Thanks
  2. May 8, 2012 at 7:01 PM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    I got about 700the on the clock right now. It'll eventually smooth out. Are you auto or 6mt?
  3. May 8, 2012 at 7:02 PM
    cfrea
    Auto. Does yours do it?
  4. May 9, 2012 at 6:07 AM
    ZonKs
    ZonKs Can speak french in Russian.
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    I experience the same thing. Very slight idle shudders. I was very surprised at this. My 07 felt like it was off it was so smooth. It's not enough to complain about personally - I really have to be looking for them to feel them, but the're definitely present. Hope they go away.
    Edit: auto with approx 160 on odo.
  5. May 9, 2012 at 6:21 AM
    Devux
    Devux Well-Known Member
    Devin
    Las Vegas, NV
    2014 TRD Sport 4x4
    Leveling kit & wheels
    Once you get through the "break in" period everything should smooth out. My 2011 idled a little rough for about the first 1000 miles, now it feels fine.
  6. May 9, 2012 at 6:26 AM
    medic2230
    Murph
    Bama! Roll Tide
    Mine did that for a bit but it's fine now that it has some miles on it.
  7. Jun 5, 2012 at 8:04 PM
    JSTACO
    JSTACO New Member
    TRD
    I have roughly 7000 miles on my 2012 Tacoma and still have the same idle issues. Does anyone know the fix?
  8. Jun 5, 2012 at 9:02 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Mine will only do it if its on the defrost mode... Bc the A/C kicks on and off... it will idle alittle rough for alittle bit then smooth out. (340 miles)
    Its not that bad though.. My 07 with 75k miles did it from time to time also..
  9. Jun 5, 2012 at 9:09 PM
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    I have the auto v6 and mine did it at first. After I installed the magnaflow catback, it smoothed out and sounded better plus the idle went down a couple hundred rpm's
  10. Jun 6, 2012 at 5:56 PM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    my 2010 has started doing this recently. very annoying for a truck with 36k on the odo...dealer says its normal ( sure it is...)
    edit: auto trans in this truck. My 08 6 speed never did it nor did my 2007 auto
  11. Jul 19, 2012 at 3:07 PM
    1stacoma
    1stacoma Well-Known Member
    Austin
    2012 MGM SR5 DCSB 4.0
    5100's front and rear, front 2.5" rear 2" AAL, 18% tint front and rear, color matched grill. SCS wheels 275/70/17 BFG AT KO's. DTRL toggle switch.
    Still experiencing this?
    Mine does the same thing I have around 1500 miles on mine. It seems a little worse when the AC cycles. It is so annoying if I kick the truck into neutral it seems to get better. I have an automatic.
  12. Jul 19, 2012 at 3:38 PM
    eshoremd
    eshoremd Member
    pasadena, md
    12 ac trd sport 4x4 black
    mine does this too. only when the a/c is on tho. i only have 140 miles.
  13. Jul 19, 2012 at 3:44 PM
    cfrea
    Still happens just a tad bit mostly if AC is on or if the motor isn't warm. Otherwise its fine
  14. Jul 19, 2012 at 7:53 PM
    PaintDrinkingPete
    PaintDrinkingPete Well-Known Member
    NoVA
    2012 4x4 TRD Sport DCSB
    My 2012 6 spd in neutral idles surprisingly smooth...but I guess that doesn't help.
  15. Jul 19, 2012 at 8:48 PM
    akhermit
    akhermit Well-Known Member
    Anchorage Alaska
    12 DCSB Magnetic Gray Metallic TRD Offroad
    I have a 1000 miles on mine, and it still idles a little rough. This is the only new vehicle that I have owned that does this. I don't quite understand it.
  16. Jul 19, 2012 at 9:21 PM
    MotorsportsAustin
    MotorsportsAustin Well-Known Member
    Austin
    Belmont, CA
    2012 Off Road 6spd
    2012 V6 6 speed, idles fine (consistently within less than 100 rpms according to the needle), always has.
    I would try different gas, then take it to the dealer - it's on warranty.
  17. Jul 20, 2012 at 9:20 AM
    ZonKs
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    Mine idled rough when I first bought it. After 1000 miles it's smooth as silk.
  18. Jul 23, 2012 at 5:29 AM
    Devux
    Devin
    Las Vegas, NV
    2014 TRD Sport 4x4
    You mean less than 1,000 right? :eek:
  19. Jul 23, 2012 at 5:34 AM
    mdcmn7
    mdcmn7 Well-Known Member
    Chuck
    East Coast
    Is this the tacoma tap everyone talks about? Mi.e has about 2k, and defiantly is not smooth as silk.
  20. Sep 3, 2014 at 11:26 PM
    PastorShep
    PastorShep Member
    Doug
    Mesa AZ
    '12 Tacoma Ext. SR5 4X4
    No stealum' tailgate mod
    I have a 2012 Tacoma with the 4 L, V-6, 34K miles, and have noticed the rough idle problem. Seems worse right after a stop or coming to a stop from the exit ramp. I will stop, take my foot off the brake going forward a few inches, brake and then the roughness starts. If I had a carb might think it was a float problem.
    Taking it to the dealer on Monday for them to check it out.
    No difference if the A/C is on or not.
