Brand new 2019 Tacoma won't hold alignment???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by H2oSkiGuy, Dec 4, 2019.
  1. Dec 4, 2019 at 4:30 PM
    H2oSkiGuy
    H2oSkiGuy [OP] Active Member
    2019 Gray Toyota Tacoma TRD Sport 4X4
    Two and a half weeks ago I purchased a brand new 2019 Toyota Tacoma TRD Sport 4X4 with 4 miles on the odometer. On the drive home I noticed it was pulling to the left and had a vibration in the steering wheel. I took the vehicle back to the dealership and they found the toe-in to be out so they aligned it and balanced the tires. The vehicle still pulled to the right so again I took it back and this time they said the air pressure in the tires was low, so they inflated and realigned it again. The vehicle doesn't pull as bad but if you let go of the wheel it will always drift to the right and leave the lane. I've noticed that the steering wheel seems off center about 5 degrees to the right and if you center it the vehicle will drift to the left instead of travel straight. I'm going back to the dealership tomorrow and I'm at a loss for what to do. Has anyone had this problem or heard of this problem with tacomas and if so what was the fix if any?
    bbartol likes this.
  2. Dec 4, 2019 at 4:32 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Welcome to the forum, my advice, find a different dealership!
    CED17, toofast4u752 and su.b.rat like this.
  3. Dec 4, 2019 at 4:37 PM
    2016BBP
    2016BBP Well-Known Member
    Southeast
    SR5 V6 Auto
    Method Wheels, WxTechGuards, TowPkg, KNDropn, 3M-Tint
    And let me guess, if you go back to the dealer and ask if it`s been wrecked, their answer is, not to my knowledge.
    Trust me, this happens, my own, low down brother told a customer that some years back.
    toofast4u752 likes this.
  4. Dec 4, 2019 at 4:41 PM
    H2oSkiGuy
    Thank you sir! Not a bad idea I was thinking the same thing however I've become a pain for them and I think they want to give me my money back the tacoma still has less than 500 miles. If they don't take it back then I'll probably end up at another dealership.
  5. Dec 4, 2019 at 4:42 PM
    ryan760
    ryan760 Well-Known Member
    The alignment on my truck is shockingly good. Steering wheel dead center, tracks straight, no pulling whatsoever.
    Find a different dealer, and if that one can't get it right, then personally I'd just pay to have a reputable alignment shop do it.
    Taco_Craig likes this.
  6. Dec 4, 2019 at 4:45 PM
    H2oSkiGuy
    Not a bad idea I may go that route
  7. Dec 4, 2019 at 4:48 PM
    ryan760
    Honestly, it's an easy fix for a shop that knows what they're doing and is experienced in alignments. Don't worry about it, and congrats on the new truck!
  8. Dec 4, 2019 at 4:49 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Your title is a bit misleading. It implies you’ve had the alignment checked multiple times and each time it’s becoming unaligned. In reality, it just needs a good alignment.
  9. Dec 4, 2019 at 5:00 PM
    WileECoyote
    WileECoyote Well-Known Member
    SoCal
    1st Gen 4WD 2.7L RegCab
    Yaesu FT-1900R w/ 2m/70cm Comet SBB-224 antenna, Cobra 19 DX IV w/ 4ft Francis CB24 Hot Rod antenna, Uniden Bearcat BC355N 800Mhz mobile scanner (analog), an external BNC mount routed to inside the cab for a handheld fire/police scanner or HAM HT's, Rancho RS5000 front struts and rear shocks, 6in KC Daylighter (pencil beam), 15x7 Black Rock Wheels Series 942, 31x10.50R15 Firestone Destination AT, fog lights, COBRA antenna hood mount (this is used to mount the GoPro on to)
    Try rotating the tires front/rear. If the pulling goes away then you MIGHT have what is called a "radial pull".
    I don't know if you know or have tried that already???
    Anyways...
    jetfishn likes this.
  10. Dec 4, 2019 at 5:02 PM
    H2oSkiGuy
    Yeah I agree the title is crap lol I've had it aligned twice but your correct its not coming unaligned it just never been properly aligned. I was starting to think maybe there was some kind of defect and it couldn't be aligned. I'll try another dealership and see what happens.
  11. Dec 4, 2019 at 5:03 PM
    H2oSkiGuy
    I haven't but I'll keep it in mind if another dealership isn't able to get it to align
    WileECoyote[QUOTED] likes this.
  12. Dec 4, 2019 at 5:08 PM
    TRDProOne
    TRDProOne Well-Known Member
    CA
    2019 TRD Pro in Super White
    One of the dealership lot guys may have had some fun in the parking lot and smacked a curb and didn’t say anything.
    A crooked steering wheel on a brand new vehicle would make my OCD go crazy.
    Big tall dave likes this.
  13. Dec 4, 2019 at 5:12 PM
    WileECoyote
    SoCal
    Even better, just swap the fronts only Left/Right and if the pulling changes the other direction, it is pointing to the tire(s).
  14. Dec 4, 2019 at 5:17 PM
    WileECoyote
    SoCal
    I'm NOT saying that it is not an alignment issue, but even new tires can have issues and will not necessarily "work" like you would think.
    Just saying that it is a quick and easy way to rule that possibility out.
    Hope this helps...
    H2oSkiGuy[OP] likes this.
  15. Dec 4, 2019 at 5:25 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Welcome, and congrats on the new Tacoma truck!
    The dealer appears to be lost, so finding a competent one for all your future services would be a good idea.
    If an alignment was performed or checked, they should have provided you with a hard copy of all the settings.
    Also if you can post it, this would be very helpful for diagnostic purposes, or to be sure if it’s even an alignment concern and getting the right advice on how best to correct the issue.
    Also do look at the multi-information display to verify that the tires have the correct tire pressure and that the front is relatively even (1-2 -+ psi).
    BillsSR5 likes this.
  16. Dec 4, 2019 at 5:31 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Exactly!
    H2oSkiGuy[OP] and The hammer like this.
  17. Dec 4, 2019 at 5:34 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Mine was off center on the test drive. They apologized profusely that it was missed. Fixed it in twenty minutes and it's been perfect since. Said alignment was a little off on delivery.
  18. Dec 4, 2019 at 5:36 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    The hammer likes this.
  19. Dec 4, 2019 at 6:03 PM
    H2oSkiGuy
    Yep it drives me crazy I hate driving it
  20. Dec 4, 2019 at 6:06 PM
    H2oSkiGuy
    Got it
