Brand new 2022 Tacoma starting problems and loud blower fan noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AleutianTaco, Mar 16, 2022.
  1. Mar 16, 2022 at 11:18 AM
    AleutianTaco
    AleutianTaco [OP] Active Member
    2022 TRD auto. 88 miles. Last night I installed a quick disconnect negative battery terminal. Started truck after, it stumbled a little bit but fired up. Same thing twice.
    Sat over night in garage. Went to drive it this morning and crank crank crank crank. Try again, crank crank crank crank.
    Tried holding the key fob next to the push button and crank crank crank crank crank crank, cough, sputtered and finally came to life.
    What's up with that? Seems to start normally now except the blower fan for the hvac is making a loud annoying whining noise.
  2. Mar 16, 2022 at 11:35 AM
    howmuch4onerib
    howmuch4onerib i sure am hungry
    Marc
    Seattle
    '21TRDORDCSBLOLOMFGTLDRIDC
    remove that and see if the prob goes away maybe? not sure why that would cause this issue but never hurts to see...
    Tacomod and Samuel like this.
  3. Mar 16, 2022 at 11:36 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Yep, have you tried taking the quick disconnect off? Sounds like it could very well be causing the issues...probably doesn't have a solid connection.
    SR-71A likes this.
  4. Mar 16, 2022 at 11:52 AM
    AleutianTaco
    I haven't tried taking it off but it cranked lively like it had lots of voltage. Here is the style of terminal I used. Connections are clean and tight. I can't see how it would cause the starting problem.
    https://www.napaonline.com/en/p/NW_785111?r-src=SSE:PDP&ppid=NW_728218&ir=5&tps=10
  5. Mar 16, 2022 at 12:12 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Before you decide that "how it would cause the problem", try REMOVING it from the equation.
  6. Mar 16, 2022 at 12:13 PM
    AleutianTaco
    I was suspecting it has something to do with the security system. I'll remove it and see what happens. Its been starting normally now the last few tries.
  7. Mar 16, 2022 at 12:15 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    What is the one and only thing you changed and then the problem started? One and only? You came here and asked, yet you don't want to listen?
    TacoSteez and Borracho Loco like this.
  8. Mar 16, 2022 at 12:16 PM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    My uncle had a bad time with those on his motorhome. Any real reason to run one on your Taco?
    shakerhood and SR-71A like this.
  9. Mar 16, 2022 at 12:16 PM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    From that picture, I think that the knife bar looks too thin to supply the current necessary. To prove that, jump across it with a good jumper cable and see if that helps.
    Kwikvette likes this.
  10. Mar 16, 2022 at 12:19 PM
    forana
    Kaneohe, Hawaii
    What is the purpose of the disconnect? Just curious why you'd put that junk on a brand new truck?
    SR-71A likes this.
  11. Mar 16, 2022 at 12:21 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Was going to say, it looks flimsy as hell. Bet it gets hot after cranking to fire it up.
  12. Mar 16, 2022 at 12:28 PM
    AleutianTaco
    Because the truck will be parked inside a container for extended periods of time when not in use. Wanted a quick and easy solution to cut off the battery. No power available to use a battery maintainer. I'll try finding something better.
    Skydvrr likes this.
  13. Mar 16, 2022 at 12:29 PM
    Borracho Loco
    DFW, Texas
    No shit. He asks our advice, then disregards it all and says "I'll wait it out and try something else."
  14. Mar 16, 2022 at 12:32 PM
    AleutianTaco
    I'm not saying I don't want to listen, but either the battery gets a lot of voltage or it doesn't. The starter was turning as quickly as it did before I installed the QD. There were no indications of low voltage or poor connection. So logically it seems unlikely to be the actual cause. But I already stated I will remove it and see if the problem goes away.
    My friend runs these same terminals on four Tundras and one Tacoma without issue.
  15. Mar 16, 2022 at 12:35 PM
    AleutianTaco
    Reading comprehension. I said I would remove it.
    Skydvrr likes this.
  16. Mar 16, 2022 at 12:44 PM
    Worn14mmWrench
    Worn14mmWrench Well-Known Member
    Kevin
    '22 DCSB TRD OR Silver
    Planned - TRD heritage grill, retro Toyota badging, TRD Pro style wheels
    We had issues on my wife's 2017 Highlander (same drivetrain as Taco). After only about 2 years of owning it, it was doing the same thing, cranking but wouldn't start. I tested the battery and it was like 12.4 volts, multiple testers said it was good and we also tested at Autozone. Put it back in, seemed fine for a day, then same problem. Finally replaced the battery and it went away. My opinion (no data here), is that the absolute stupid-assed feature of the auto-start stop puts a lot of extra load on the battery, as at stop lights all the accessories have to run off battery. I think that causes them to go bad really quick or leaves them with a low charge and the computer won't start or even sometimes try to crank. Also, fast forward to more years (2017-2019, then 2021) the 2nd battery failed (under warranty). I wish you could permanently disable the auto-start/stop feature, and I heard on some vehicles due to chip shortage they have removed the feature. That would be amazing if my truck coming in a couple of weeks was missing that feature.
    Most likely your issue is the quick disconnect, but I will say on the 3.5L platform I don't trust the electrical system with auto start/stop enabled
  17. Mar 16, 2022 at 12:50 PM
    Technique
    Alex
    Utah
    I am curious if there is a good quick disconnect of sorts that people recommend. Would be handy when working on electrical stuff to have something like that installed.
  18. Mar 16, 2022 at 12:51 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I'm not sure if you missed the other 8 responses to remove the quick disconnect, but I'm here to let you know, you should try to remove the quick disconnect and see if the problem goes away.
    forana likes this.
  19. Mar 16, 2022 at 12:51 PM
    grandpawmoses
    David
    No money
    Not 100% sure about this but wouldn't you lose radio presets and even delete driving habits from your ecu by using a cutoff?
  20. Mar 16, 2022 at 12:51 PM
    GOROAM
    GOROAM Where can I get Raptor lights?
    19 TRDOR
    Crawling Malls
    Darwin is on a roll today :bananadead:
