Brand New 2023 MT Clutch Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Marco_Off_Road_ID, Apr 25, 2023.
  1. Apr 28, 2023 at 5:32 PM
    #41
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    That’s the ticket - gotta give it the beans for smooth shifts
  2. Apr 28, 2023 at 5:35 PM
    #42
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry, but my thing is always about not raising the throttle to get going. Just blend and launch. I can do that with the Taco and have no issues accelerating faster than normal traffic.
    Gimme a few and I'll post a vid.
    Edit:
  3. Apr 28, 2023 at 7:00 PM
    #43
    Northerntaco69
    Northerntaco69 Well-Known Member
    2023 TRD Offroad 6MT dcsb
    Trd pro grill, blackout overlays, black tailgate inserts
    That's so weird I find mine is so easy. I can take off no throttle just let go of the clutch. The easiest manual I've ever driven. I do notice the accumulator though. That is a little bit to be desired. I'd like to delete that eventually.
    Junkhead likes this.
  4. Apr 28, 2023 at 7:08 PM
    #44
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I think it's about time I ponied up for one of your tunes :anonymous:
  5. Apr 28, 2023 at 7:09 PM
    #45
    Northerntaco69
    Maybe that's the ticket
    doublethebass[QUOTED] likes this.
  6. Apr 28, 2023 at 7:29 PM
    #46
    Sinister184
    Sinister184 Well-Known Member
    23 Tacoma TRD OR 4x4
    I don’t think I saw anyone say you can adjust the start sensor, but mine was pretty deep in as well. There’s been a few times I had to redo my position to get it to start. I didn’t find the clutch overly heavy, but that’s probably because I’ve owned a lot of sports cars that were much heavier. The accumulator gets a lot of attention but the engagement doesn’t bother me, and won’t fix OPs issue.
  7. Apr 28, 2023 at 8:55 PM
    #47
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah!
    :hattip:
  8. Apr 28, 2023 at 9:12 PM
    #48
    racerx321
    racerx321 Member
    Minnesota
    I had what sounds like a similar issue. Disengaging the clutch fully required moving my seat so far forward that my knees were then hitting the steering column.
    I ended up adding a clutch pedal extender and that helped tremendously:
    https://www.tacomaworld.com/threads...ch-pedal-extender.419069/page-2#post-26649435
    It's still not an ideal arrangement, but has made things more comfortable.
    I don't know enough about the clutch position issue you mentioned, but that seems worth addressing, as the pedal extender is only 1.5" and it really changed the feel of the clutch pedal action.
  9. Apr 28, 2023 at 9:24 PM
    #49
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I find 1st to be a tricky bugger when not at a complete stop. And 2nd under 1000 rpm is a dog. One pricey solution is a regear, tune is a bit less pricey but constantly evolving. I will say, with time, I can get it in first when moving with some patience and planning but it’s definitely a slow transition.
    My ‘05 5 spd is less smooth and the clutch pedal is less refined but it also takes first when rolling with less effort. Or maybe I care less?
  10. Sep 12, 2023 at 11:44 AM
    #50
    jewboi
    jewboi Well-Known Member
    do you typically downshift when coming to a stop like that or were you just for the purpose of making that vid? just curious
  11. Sep 12, 2023 at 11:46 AM
    #51
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Always shift down to at least 2nd gear.
    doublethebass likes this.
  12. Sep 12, 2023 at 11:50 AM
    #52
    jewboi
    forgive me because i basically taught myself how to drive stick, so never learned the 'most proper' way, but that seems like alot of additional clutch work for what benefit? I usually just brake in gear until pretty low RPM then throw it in neutral if coming to a full stop.
    seems like premature brake wear would be more favorable than engine braking gained from downshifts?
    Sandthemall likes this.
  13. Sep 12, 2023 at 11:53 AM
    #53
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I just like to row. No benefit other than my own enjoyment.
    I have said it before, the beauty of an MT is that you can put it in the gear that you want when you want. If you want no gear at all, so be it.
  14. Sep 12, 2023 at 11:55 AM
    #54
    jewboi
    gotcha, even after years in this truck im just pretty ass at rev matching downshifts
    if i could do it as well as you did in that clip i'd probably be doing it all the time as well :rofl:
  15. Sep 12, 2023 at 11:58 AM
    #55
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks! I appreciate the compliment.
    Mine was pretty bad with the accumulator and Stock tune. With the ADM and a tune, it feels like other MTs that we have had. Quite a lot of fun on twisty roads.
  16. Sep 13, 2023 at 7:19 AM
    #56
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    I consistently down shift and engine break - been driving MT for 30 years and never had an engine issue, brake issue or premature clutch wear for that matter.
    Means I don't have to brake super hard and there are a few stop signs where I live that I can 'roll' doing this - and just start right into 2nd.
    doublethebass and Taco22trdor like this.
  17. Sep 15, 2023 at 9:47 PM
    #57
    CCATT-RN
    CCATT-RN Well-Known Member
    Erskine
    2006 Land Cruiser
    Will just putting it into 4wd high let you back up without having to rev it so high?
  18. Sep 16, 2023 at 1:28 PM
    #58
    Firn
    Firn Well-Known Member
    White OR
    No. 4 low would, but not 4 high.
    CCATT-RN[QUOTED] likes this.
  19. Dec 7, 2023 at 10:12 PM
    #59
    MattiasdelTaco
    MattiasdelTaco unknown member
    Illinois
    2023 trd sport MT
    swapped for clean, scoopless hood
    Does it matter what brand of SAE J1703 FMVSS 116 DOT 3 brake fluid is used when doing the ADM, or replacing clutch fluid at any point, or is there pretty much no difference, as long as it’s a DOT 3 brake fluid? e.g., AMSOIL, Valvoline, Peak, Prestone, Mobil, Lucas Oil, Toyota oem etc.
    Tried searching, but didn’t find this specifically.
  20. Dec 8, 2023 at 8:45 PM
    #60
    Firn
    White OR
    It should not matter
    That said, I am a fan of replacing the fluid with dot 3 low viscosity (lv) if you live in an environemnt that gets cold. If using my ADD (the disk) then I recomend it.
    LV fluid has nearly identical viscosity when hot, but about half the viscosity when cold (brake fluid viscosity changes a LOT)
