Brand new ARB locker leaking air
Discussion in 'Technical Chat' started by austin2009, Aug 25, 2018.
  1. Aug 14, 2019 at 6:58 PM
    #121
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    Ordered mine November 2018 installed December. Used 2-3 times without fault, was checking the system over tonight and I sprung a leak into the housing. Emailed ecgs will report back
    WPNZ likes this.
  2. Oct 21, 2019 at 7:42 AM
    #122
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Just called ecgs to let them know I have a leaking air seal in my rd129 arb locker. This past weekend was the second time I’ve used the locker since February when I sent it back to them to change my last air seal.
    lame...
  3. Oct 21, 2019 at 7:45 AM
    #123
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Bummer. If you get a chance, you should try the TJM.
  4. Oct 21, 2019 at 8:47 AM
    #124
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Are you running your compressor over 100psi? The ARB air lockers don’t need a lot of PSI. You should have a 105 psi shut off on it. Also, a 1-2 gallon tank will actuate it 50+ times.
  5. Oct 22, 2019 at 7:31 PM
    #125
    JLink
    Josh
    Ocean, NJ
    Ecgs is covering the cost.. just sucks to have to send it back to them again.
    I’m using an arb ckma12 compressor with their solenoids and pressure switch. I’d be surprised if their kit supplied more pressure than their lockers can handle.
  6. Oct 22, 2019 at 7:33 PM
    #126
    jp_flynavy
    jp_flynavy IG: @TrailLimoOverland
    2015 Tacoma DCLB
    Is this since the new, new German seals? I got mine replaced a few months back, 3rd set of seals, so far so good. ECGS has top notch customer service. They offered to bring the truck in, since I live relatively close.
  7. Oct 22, 2019 at 7:39 PM
    #127
    JLink
    Josh
    Ocean, NJ
    I don’t know what seal they put in it last time, but it was February 2019, and I could’ve sworn it was supposed to be “the newest” seal at the time. But based on them taking two weeks to get it back to me, when they said it would be two days, I don’t have much faith in what they did last time.
  8. Oct 22, 2019 at 9:18 PM
    #128
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    why is that? Is it an easy swap?
  9. Oct 23, 2019 at 5:09 AM
    #129
    jp_flynavy
    2015 Tacoma DCLB
    They had the newest seals from Germany around late march. I had mine installed in april.
  10. Oct 23, 2019 at 6:19 AM
    #130
    jowybyo
    Joe
    Baltimore, MD
    IMO the design is better. The way they actuate the locker is different and doesn’t rely on a lip seal to seal against a rotating part. I’ve I’m understanding it correctly, the ARB design is seeing wear even during daily driving without using the locker. The TJM actuator doesn’t have this issue. There is no seal against a rotating part.
  11. Oct 23, 2019 at 11:13 AM
    #131
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    that’s not good on the ARB. But I’ve heard nothing but good things about the Harrop. Well I take that back, one negative I’ve heard is that there could be a potential for 1/4 Rotation of free wheel spin in certain situations. but I’ve heard great durability always worked when needed very fast actuation can engage in Any drive mode. And no leaky issues of the ARB. Right now it’s the direction I’m heading for sure. Prolly skip on a front locker and Harrop in the rear when I re gear.
    Sna and Hamer95USA like this.
  12. Oct 23, 2019 at 12:03 PM
    #132
    jowybyo
    Joe
    Baltimore, MD
    Even before this thread started, I found a lot of people having issues with ARB lockers that leaked. I found hundreds of complaints dating back at least a decade. That's pretty much why I begin looking for other options.
    https://www.youtube.com/watch?v=1nYZo--7Xh4
    This video does a decent job showing the differences be the ARB and the TJM.
  13. Oct 24, 2019 at 2:57 PM
    #133
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Mine has been leak free since the latest seal. Been several months
  14. Dec 8, 2019 at 9:42 PM
    #134
    k_j_souv
    k_j_souv Well-Known Member
    NorCal
    3G OR DCSB, Dual Case, 42s
    Was this issue of a "bad batch" of seals exclusive with the 8.4 rear ARB? I just purchased a front ARB and was wondering if there are any known issues with the front ARB locker/seals for the clamshell as of late?
  15. Dec 8, 2019 at 10:20 PM
    #135
    deeezy
    Dana
    Hawaii
    I would ask the vendor you purchased from, if they could verify that your recently purchased locker is not part of the batch that had the bad seals. My new lockers are leak free.
  16. Dec 9, 2019 at 6:40 AM
    #136
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I've got a seal sitting on the bench that I bought a few months ago for when I tear into mine, any idea on the part number(s) that are good/bad?
  17. Dec 9, 2019 at 7:34 AM
    #137
    deeezy
    Dana
    Hawaii
    Sorry, but I do not know. ECGS did all of the warranty work.
  18. Dec 9, 2019 at 7:42 AM
    #138
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    . If it was made within a certain time frame it has the bad seal. It doesn’t matter about the make Jeep, Ford, Chevy, Dodge all had bad seals too.
    The lockers have serial numbers on them.
    People didnt really have problems with the front lockers because only the spider gears turn unless your in 4x4. so it doesn’t build up heat like the rear
    deeezy and k_j_souv[QUOTED] like this.
  19. Dec 9, 2019 at 8:05 AM
    #139
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Probably just get a new one then to be safe, low dollar item for a giant PITA.
    deeezy[QUOTED] likes this.
  20. Dec 9, 2019 at 11:27 AM
    #140
    deeezy
    Dana
    Hawaii
    Total PITA!
