Brand new dead battery
Discussion in '1st Gen. Tacomas (1995-2004)' started by fiore530, Oct 13, 2022.
  1. Oct 13, 2022 at 5:27 AM
    fiore530
    fiore530 [OP] Active Member
    I have a 2001 xtracab 4x with no aftermarket electronics other than the radio (which I've checked, has no drain) and my brand new battery (interstate) died at the gas station. I drive it everyday. It started when I left work, drove five miles stopped at a gas station shut it off, came back out it was dead…Ive checked the terminals, the connections, the solenoid and they all seem fine. Can’t think of anything that would drain the battery that quickly…
  2. Oct 13, 2022 at 5:32 AM
    1997tacomav6
    Denver
    Put a volt meter across the battery when it’s at idle, should be 14 volts,
    Typically this is alternator or a defective battery or cables,
    Check the ground strap wires and the one to the block under the engine
    Smokestacks, Nessal and Taco critter like this.
  3. Oct 14, 2022 at 1:08 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Bad battery it happens.
    Without a Meter you just looked. Why did you just replace the battery??
    By Die no battery output at all or it did not crank?
  4. Oct 15, 2022 at 10:06 AM
    Caslon
    Caslon Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    Autozone and the like will check your alternator for free.
  5. Oct 15, 2022 at 10:09 AM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Were you able to jump start it?
    That would eliminate starter and cables at least.
    Batteries these days just up and die, with no warning.
  6. Oct 15, 2022 at 2:15 PM
    Aircates
    Aircates Well-Known Member
    Texas
    1997 Tacoma lowboy
    So when you say it was dead, did it try to spin over?
  7. Oct 16, 2022 at 1:36 PM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Possible bad battery terminals.
