Brand New Double Cab with Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dalsmthme, May 31, 2009.
  1. May 31, 2009 at 3:29 PM
    dalsmthme
    dalsmthme [OP] Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
    So I picked up my new double cab Taco on Friday. Noticed a vibration through the seats an stearing wheel, at any speed above 35mph. It feels like tire out of balance. I then took it on a few farm lanes hunting thiss weekend. The front end feels a little loose over general rocks and small bumps. Is this pretty normal or is the vibration linked to the loose feeling in the front end?
  2. May 31, 2009 at 3:29 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    check your lugnuts???
  3. May 31, 2009 at 3:33 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Take it back to the dealer and get it fixed!!! Either that or tell them to swap you with a new one because thats BS.:eek:
  4. May 31, 2009 at 3:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    May have to have the tires re ballanced. For the "Loose feeling" in rocks and loose dirt, air down to let your tires get more traction.
  5. May 31, 2009 at 3:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Could be this too......
  6. May 31, 2009 at 4:20 PM
    dalsmthme
    Ithaca, NY
    I set the air pressure to 30 psi and torqued the lugs to 92ftlbs. I am taking it back tomarrow to have the rebalance. I hope it is just that.
  7. May 31, 2009 at 4:35 PM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2008 double cab, 4X4, V-6, TRD. Super White.
    OME 885 coils & front shocks, with TT top plate, Total Chaos UCA, Rear OME extended shocks, Rear TSB, Rear Toytec AAL, trimmed the saber-tooth-tiger-long-ass mud flaps. 17" XD Revolver rims, 265/75/17 BFG AT KO's. Ripped out the crappy FM Modulator & installed a PA-15-toy interface. OEM bed matt.
    Exactly! Brand new Tacos should be spot on. I 'm sure your dealer will take care of you. Make sure it's to your satisfaction. Test drive others if needed.
    Welcome to TW:D
  8. May 31, 2009 at 5:03 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    My dealer didn't take care of me. I ended up having to go to Discount Tire to get a road force test done. They failed miserably and I got them returned (partial credit with 6k miles, I drive a lot) and picked up some BFG All Terrain KO's. Much better, but any AT tire will still never be "smooth." My truck came with the Rugged Fails (TRD OR).
  9. Jun 2, 2009 at 1:52 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    My tires were out of round from the factory and I had them road force tested which showed them way off of normal specs. I had issues with the dealership not wanting to do anything about it. If you have a tire warranty it should be good at any distributer of what ever brand you have, so if they are bad you can get them replaced at a tire shop instead of the dealer, check your paperwork. I had dunlops on mine :puke:.
  10. Jun 2, 2009 at 4:04 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Wow, that's good to know. Can you elaborate on the process....
  11. Jun 2, 2009 at 6:07 AM
    dalsmthme
    Ithaca, NY
    Yeah, well, I am a pain in the ass. I just dropped $30K at there dealer. They WILL fix it.
  12. Jun 2, 2009 at 7:14 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    I said the same thing, like I said... Discount Tire ended up fixing it. :/
    I also literally had it back after 70mi on the ODO (that's 1 round trip for me, home that night, back the next morning).
  13. Jun 2, 2009 at 8:55 AM
    zero niner
    zero niner romeo oscar bravo
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    All Pro front plate bumper, 5100 1.75" Bilstein up front, 1" block and TSB in rear, UWS lowpro tool box, Toyota Side Steps
    Seriously, this drive me crazy, especially now days, you'd think there'd be better customer service! DT had to fix a factory mistake??? Shameless... I'd have a call into the Service Manager, GM of the dealer and Toyota Customer Service. I wouldn't stand for that! Reading stuff like this makes me :mad:
    Rob
  14. Jun 2, 2009 at 9:10 AM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    Keep in mind, that tires are NOT part of the factory deal...they are warrantied by the TIRE manufacturer. This is nothing new to car/truck warranties, it's been this way for a long time. No need to jump down Toyota's throat when it's the TIRE manufacturer's problem.
    By trying to force Toyota into doing something, you are barking up the wrong tree IMO. Hence some friction with them...especially when you demand they do something that is covered by the tire manufacturer. Check out your warranty information...it's all there.
    Does it suck you have to deal with this? Yep. But go about it in the right way and it'll turn out just fine. Tomorrow will come, birds will sing and all will be right in the world. :D
  15. Jun 2, 2009 at 9:19 AM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    So just to get the right perspective, if you have 70 miles on the truck and they have bad tires on it, Toyota's not responsible for it? The wouldn't even be the middleman on assisting you? I could understand if it became a problem down the road but I would expect the truck to be 100% when purchased new. This is new to me, so this will be good info before I get all hot and heated...
    Also, I know what the rules may say but many stores take care of their customer, example, Homie Depot tells you that you have to go through the manufacture warrenty but every time I've gone in with a problem (within a reasonable amount of time), explained it nicely, they've exchanged it.
    I'm always intersted in how customer service is dealt with, I have over 17 years in retail, and there are polices and rules, and then execeptions to keep a customer.
    Rob
  16. Jun 2, 2009 at 5:44 PM
    dalsmthme
    Ithaca, NY
    Well, that didn't work. All they did was move the suspect tire from the front passanger side to the rear. I still have a shimmy in it and there is no evidence they even moved any weight. Going back Saturday. I am still concerned about the lose feeling in the front end. It is accompanied by a clunk sound when I feel it, but it only occurs on the rocks or chopy dirt.
  17. Jun 2, 2009 at 8:03 PM
    SaltySteve
    SaltySteve sMo
    Denver
    2012 4runner
    Agreed.
    Fact of the matter is this dude just dropped 30 grand on a BRAND NEW vehicle. It shouldn't matter what the problem is with it. The dealership should be doing backflips to remedy the problem. No ifs, ands, or buts about it.
    If it's a tire issue the dealership should replace all 4. If it fixes the issue then it is now on the dealership to deal with the manufacturer. This is in NO WAY the customers responsibility. If this doesn't fix the problem then they need to do everything in their power to fix the problem up to and including replacing the vehicle. The customer can walk away feeling taken care of and the dealership can figure out what the problem is on their time instead of wasting the customer's time.
    There is no excuse for poor customer service.
  18. Jun 2, 2009 at 8:07 PM
    ClemsonTacoma
    ClemsonTacoma Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    uhmm im not satsified b/c my dealer wont even call about the tsb and i need a truck to haul what its advertised to not half
  19. Jun 2, 2009 at 9:19 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    The Dunflops are FAMOUS for developing flat spots. Mine does it consistently if parked a couple of days. Serious shimmy through the steering wheel, but not the whole truck. It smooths out after a little while though.
  20. Jun 3, 2009 at 4:14 AM
    FoxySandChick
    Kristin
    Henderson, NV
    Look in your paperwork from the dealer, there should be a pamphlet on the tire warranty which is through the tire manufacturer not through the dealer. It has a lot of stipulations to qualify and they make it almost impossible to qualify.
    Basically you can take it to any authorized tire dealer for whatever brand tires you have, make the complaint and have them tested, if they come back as being 'out of approved specs' ie out of round from a road force test not just a regular balance (look up Hunter Road Force Testing) then that dealer makes a claim to the manufacturer and they are replaced.
    Good luck, I was as much of a pain in the ass as possible and made a scene inside the service department in front of customers...it didn't work.
    I went to the Service Manager then to the General Manager and to the Regional Manager and then I went to Toyota Customer Service. I wrote complaints to the GM and 3 letters to Customer Service. I got the run around from the Dealer and Toyota for over a month, they were going to honor my complaint at first the dealer was going to pay then they changed their mind, then Toyota said they would honor it, I was even told from Toyota Customer Service that a check was in the mail and a week later I was told they decided not to honor my complaint and refused to continue to investigate my claims. Not much you can do after Toyota won't help.
