Brand new here! 06 regular cab 4x4 manual 4cyl
Discussion in 'New Members' started by HOSNOFF, Mar 7, 2016.
  1. Mar 7, 2016 at 3:37 PM
    HOSNOFF
    HOSNOFF [OP] Member
    William
    2006 Tacoma 4x4 4cyl Manual Reg Cab
    I just bought my first vehicle an 06 regular cab 4x4 manual 4cyl. It's got 140,000 on it. Whats the first thing you would inspect on it to make sure it's road-worthy?
    I don't think the shocks/struts have ever been replaced (judging by the used state of the rest of the truck and the bumpy/jumpy ride on the hwy) so I'm thinking of putting in the 5100 Bilsteins all around and AAL's. I only want 0-1.5" of lift so as not to wear or break anything indirectly later on!
    Got a couple of quotes for the bilstein kit + installation that seem outrageous (one was 1200 and the other 900). What say you, Taco people!?
  2. Mar 7, 2016 at 3:39 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Welcome to the TW, nice truck.
  3. Mar 7, 2016 at 3:41 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Welcome to the club!:thumbsup:
  4. Mar 7, 2016 at 3:45 PM
    Markcal
    Markcal Well-Known Member
    I would call a Toyota dealership with the vin#, to make sure your Tacoma had the LSC performed, because you have until March 31, 2016 to have your frame inspected. If it fails you get a new frame and if it passes you get the framed sprayed with CRC.
  5. Mar 7, 2016 at 3:46 PM
    Joelev
    Joelev Well-Known Member
    $900 for a suspension replacement with parts included isn't crazy. But if I can do a suspension install, then you can, too.
  6. Mar 7, 2016 at 3:48 PM
    HOSNOFF
    HOSNOFF [OP] Member
    William
    Good call! I will be doing that this week.
  7. Mar 7, 2016 at 3:49 PM
    HOSNOFF
    HOSNOFF [OP] Member
    William
    I've seen the posts about not needing a spring compressor? I'm sure I could do the suspension install, I feel like a might just order all the parts and make it work to save about 300 in labor.
  8. Mar 7, 2016 at 3:57 PM
    Markcal
    I ordered my Bilstein 5100 shocks for both the front and rear from Jet.com and with the 15% discount, I ended up paying $255 and shipping was free too. I was going to install the rear shocks myself and was debating if I can do the fronts also, but either way it will need an alignment after they are installed.
  9. Mar 7, 2016 at 3:58 PM
    Stags863
    Stags863 Bye Felica!
    Florida
    2014 DCSB TRD Off Road 4x4
    - Bilstein 5100's set at 1.75 - 265/70/r17 Goodyear Wrangler Authorities - 6000k headlight and fog light bulbs - NiLight off road LED rear lights - Light bar mounted behind front bumper - White LEDs in dome, map, and sun visor - Tint (5% around / 35% front) - Universal 13 inch metal antenna - Beer bottle opener in bed - Organizer storage box in center console and glove compartment - Mounted MagLite to top of center console storage box - MGM grille - MGM rear bumper - CamLocker toolbox - Rubber floor mats - 2 USB and Cig lighter chargers in rear of center console - Headrest mounted iPad holders for rear seats
    Welcome to TW
  10. Mar 7, 2016 at 4:04 PM
    Markcal
    For someone who has never done suspension work before, would you recommend installing the front shocks myself? Have you ever seen the video of someone installing the front shocks without using a spring compressor? Would you recommend that method to install the front shocks?
    Thanks,
    Mark
  11. Mar 7, 2016 at 4:05 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Welcome to the rare RC 4x4 club!!
    Edit: I would check and/or replace the usual...spark plugs, air filter, oil & filter change, PCV valve, clean throttle body, front & rear differential fluid, transfer case fluid, transmission fluid, grease driveshaft, check antifreeze, brake fluid, etc.
    If you records of the above, obviously dont do it again. Just things I would check/replace when buying a used vehicle.
    HOSNOFF[OP] likes this.
  12. Mar 7, 2016 at 4:09 PM
    HOSNOFF
    HOSNOFF [OP] Member
    William
    https://www.youtube.com/watch?v=5E6u7dC7EHg
  13. Mar 7, 2016 at 4:10 PM
    HOSNOFF
    HOSNOFF [OP] Member
    William
    Thanks! I had an 01 a while back that got totalled by some elderly folks, and it took me 8 years to find another suitable one!
  14. Mar 7, 2016 at 4:12 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I never installed my first set of shocks until I did it.
    You got to do it sometime. Once you do it, you are now a pro.
    The bolt type spring compressors are only $40. Buy them once and be done with it. I never had utube to help me learn. You have a huge advantage. Go for it! Save some money.
  15. Mar 7, 2016 at 4:16 PM
    Markcal
    Yes, that is the video I watched as well as one other. I just wondered if it is as easy as these videos look like they are. I know the rear shocks would be very straight forward, but I didn't know if the fronts are for first timers too.
    If your frame has passed inspection, you must get new rear leaf springs, because there is a recall. I don't know where you live, they are slowly doing each geographic area at a time and mine just became available in my area.
    Welcome to TW by the way!!
  16. Mar 7, 2016 at 4:24 PM
    HOSNOFF
    HOSNOFF [OP] Member
    William
    Thanks!
    Yeah today is the first time I'm hearing of the recalls, I'm going to call a dealer tomorrow and get her inspected.
  17. Jul 5, 2016 at 11:03 PM
    HOSNOFF
    HOSNOFF [OP] Member
    William
    Update, I called the dealership about the leaf spring recall and they ordered the parts (per my VIN# I assumed). 2 weeks later, they were ready to install. I drop my truck off and they call me the next day to inform me that they had order the wrong parts (order for extended cab). They said it would be another 2-3 weeks. It will have been a month this Thursday, so I called them today. Still no parts, but should be there in a few days.
  18. Jul 5, 2016 at 11:08 PM
    HOSNOFF
    HOSNOFF [OP] Member
    William
    The front is very straight forward. Although it is helpful to have two people when positioning the sway bar for reassembly. Me and a buddy of mine installed Bilstein 5100 adjustables on the front a week or two ago and it was a piece of cake. I put mine on the lowest setting because I have the 2.7L and it still raised the front close to an inch. I also installed new OEM springs to replace the worn out crap that was on there.
  19. Aug 23, 2016 at 4:17 PM
    HOSNOFF
    HOSNOFF [OP] Member
    William
    Annnnd nearly 3 months to the day, the dealership called to say they have the recall parts in.
  20. Aug 23, 2016 at 4:24 PM
    koditten
    Kirk
    Central Michigan
    Good deal.
