Brand new taco is noisy
Discussion in '3rd Gen. Tacomas (2016-2023)' started by scotch10, Jul 30, 2019.
  1. Aug 2, 2019 at 10:51 AM
    #141
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    :rofl:Loled
  2. Aug 2, 2019 at 10:59 AM
    #142
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Sometimes the door frame/hinge bolts need a slight adjustment to get the door to seal properly as well.
    scotch10[QUOTED][OP] likes this.
  3. Aug 2, 2019 at 9:31 PM
    #143
    SCREAMINSAL
    SCREAMINSAL Well-Known Member
    Pulled up next to some MOLTEN hot chicks driving a gladiator.... I said nice tits(truck)!!!
    Driver yells back... Nice Tacoma...! Made my day even youth my Taco is badass!
    Superdave1.0 and Bunk Moreland like this.
  4. Aug 2, 2019 at 9:32 PM
    #144
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    :worthless:
  5. Aug 2, 2019 at 9:44 PM
    #145
    SCREAMINSAL
    Next time I'll take a pic. I think they're local and I know I'd wanna drive that thing I'll the tires fall off!
  6. Aug 3, 2019 at 5:59 AM
    #146
    OBXfamilyOf4
    OBXfamilyOf4 Member
    Todd
    Northeast NC
    '19 Magnetic Gray Met. Tacoma 4WD TRD Sport Double Cab LB
    I am definitely not experiencing this "noisy" that several others are complaining about. I did the weather seals around the doors. I have noticed absolutely no whistling. In saying that, I drive anywhere between 75 (hangs head in shame) and 35 mph to and from work. Not comparing it to my '18 Honda Pilot would be smart though. I bought a truck expecting to do truck things with it. I do know that my truck is much more quite than my company's & coworker's Rangers.
    Maybe the sport is more quite than the OR, but I have no idea if that is correct or not.
    And laughed at the picture of the pussy driving. I'll have to use that 1 sometime.
  7. Aug 3, 2019 at 6:28 AM
    #147
    Jim1946
    Jim1946 2020 TRD Sport 4X4
    San Francisco Bay Area
    2020 TRD Sport 4X4
    You talking about the chicks or the truck?
    Dryfly24 likes this.
  8. Aug 3, 2019 at 6:30 AM
    #148
    Jim1946
    2020 TRD Sport 4X4
    I have owned every generation of Toyota trucks since 1977. To me, they only get better with every generation. Love my 2019 the most.
    BillsSR5 and ancient11 like this.
  9. Aug 3, 2019 at 7:57 AM
    #149
    Wasatchrider
    Wasatchrider Well-Known Member
    Me too
  10. Aug 3, 2019 at 8:08 AM
    #150
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  11. Aug 3, 2019 at 8:10 AM
    #151
    BillsSR5
    bill
    2014 SR5
    do these come in TALL MAN SIZEs images_18163b9ff7911e9b8e9592be4de5ae911d09175d.jpg
  12. Aug 3, 2019 at 8:32 AM
    #152
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    OP, spend a weekend riding in my 98 wrangler 4banger witha soft top or Tacoma with a prinsu rack, bed rack loaded with kayak,bikes , wife,2 kiddos and a 60lb goldendoodle puppy then report back.
  13. Aug 3, 2019 at 11:53 AM
    #153
    BillsSR5
    bill
    2014 SR5
  14. Aug 3, 2019 at 12:02 PM
    #154
    Searat99
    Searat99 Well-Known Member
    Carl
    Albany,New York
    2016 Silver Tacoma TRD Offroad
    Not much road noise here, in fact with the windows up I hardly hear my STT Pro's slapping the pavement. After driving Fords for the past 20 years I consider my Tacoma a luxury vehicle.
    GreyBaldTaco, Paul631 and BillsSR5 like this.
  15. Aug 4, 2019 at 6:25 AM
    #155
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    :rofl::rofl::rofl:
    BillsSR5[QUOTED] likes this.
  16. Aug 4, 2019 at 9:02 PM
    #156
    SCREAMINSAL
    I dint see the pic of a "PUSSY" diving but my first thought was, Bill Clinton in a truck!
  17. Aug 4, 2019 at 11:25 PM
    #157
    stun gun
    Aaronski
    Tacomas.
    Well that settles it. There is officially a gif for everything
    GillyLink and BillsSR5[QUOTED] like this.
  18. Sep 13, 2019 at 5:21 AM
    #158
    ToyotaFan1975
    ToyotaFan1975 New Member
    Paul
    2019 Double Cab 4X4
    Gator Tonneau Cover, Duratrek 4 Inch Step Bars
    I have the same issue. On further investigation I have found that it is the rear cabin AC vents that are just behind the back plastic panel of the truck. They let air out of the cabin and are basically a big hole right to the outside of the truck so all the sounds of the road come in. I am going to remove the back panel and use sound absorbing foam panels on it and see if that helps. I'll let you know the results when complete which will not be for a while because of work. Here is a YouTube video explaining the issue. https://www.youtube.com/watch?v=Be344ECh5pM I did a test and indeed it is them. When you drive down the road with the air on fresh mode for a while and then press the re-circulation button, the sound gets noticeably quieter within a second. The only way to eliminate the noise completely would be to block them off which would seriously compromise the HVAC system so it is highly not recommended. A lot of people are complaining on different forums about the new F-150's too so it seems to be an overall truck issue and not exclusive to Tacoma's. I have even see forums of people who cover them or take them out because of the noise and then their AC makes whining and whistling noises. Most of them ended up putting them back in and just living with the road noise.
    ancient11[QUOTED] likes this.
  19. Sep 13, 2019 at 5:39 AM
    #159
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    get a decibel meter on your phone and do a comparison.
    SCREAMINSAL likes this.
  20. Sep 13, 2019 at 5:43 AM
    #160
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I find if you turn up the radio really loud, that all the noises and problems go away! :bananadance:
