Brand New Tacoma Developing 1000's of rust spots on body
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ListenUpSonny, Mar 27, 2019.
  1. Mar 27, 2019 at 11:51 AM
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Had the same issue on my 97 white monte carlo.... full detail, stripping cleaner like ironx and then waxed and buffed....great after that. As other have said this is not your truck rusting, it is environmental debris contamination.
    rdpoe likes this.
  2. Mar 27, 2019 at 11:54 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    We’ve seen the same type of post at least three times in the last week.
    As we all know, this is not body panel rust, but surface contamination rusting. The question it raises for me, is why is it always white trucks with this complaint?
    -Is the white paint softer and gets grit lodged in it more easily?
    -Are the rust spots just more visible on white paint?
    -Does the white paint absorb the colour of the rust?
    -Does the chemical composition of the white paint increase the rusting of the metal grit?
    I know no one has the answers, but it does always seem to be white trucks that have this issue.
    Boghog1 likes this.
  3. Mar 27, 2019 at 11:55 AM
    salmonmigration
    salmonmigration Well-Known Member
    2018 TRD Sport 6MT
  4. Mar 27, 2019 at 12:01 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
  5. Mar 27, 2019 at 12:04 PM
    Kjntaco
    Kjntaco Well-Known Member
    Oahu, Hi
    Like everyone said use a fallout remover followed with clay then seal with a good wax or sealant.
  6. Mar 27, 2019 at 12:09 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    My exact experience in my garage as well. I spend more time keeping the white maintained than I do the silver. I assume because the silver has a clear coat and the super white doesn't.
    OP, it's easy to remove. Just don't wait a few years then try to get it off. Clay barring is an annual event in my garage.
  7. Mar 27, 2019 at 12:12 PM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    GL
  8. Mar 27, 2019 at 12:16 PM
    toyotatacomaTRD
    My paperwork always gets a big ol "No Wash" right across the front if its ever at the dealership. Last thing I'd ever do is let the lowest on the totem pole clay my vehicle. Learn how to do it yourself, it's super easy. The dealership definitely wouldn't take the time to do it properly. They're running through vehicles as fast as they can.
    El Duderino, aggr0crag and Kjntaco like this.
  9. Mar 27, 2019 at 12:24 PM
    Kjntaco
    Oahu, Hi
    If your wife drive the same roads as you and her car is good then it's probably when they transported your truck to the dealer or you parked in a bad spot and metal dust got on your paint. I wouldn't trust dealership detailers to fix it tho.
    aggr0crag likes this.
  10. Mar 27, 2019 at 12:53 PM
    Stocklocker
    17TRDORDCSBAT
    Why don’t they clear coat the white? That’s seems to be the issue here.
    ListenUpSonny[OP] likes this.
  11. Mar 27, 2019 at 1:08 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Agree with this.
    After my accident And I got my 4R back from the collision place I noticed the same exact thing. I could only surmise that it was metal flakes from the repair shop that had embedded in the paint/clear coat and we’re starting to rust. I did a full wash and clay bar and was able to remove it. Haven’t seen the issue reappear since then.
    Well, I respectfully disagree with you. It appears as metal flakes embedded into the clear coat and paint that’s rusting and causing the staining. It’s not a defect of the paint or adhesion that’s causing the metal underneath to rust and stain from the bottom up.
    If you dump a bunch of metal dust on your truck and drive around and it starts to rust and stain, is it the dealers responsibility to remedy it for you? I don’t think it is.
    Hook78, aggr0crag and Stocklocker like this.
  12. Mar 27, 2019 at 1:08 PM
    R242
    R242 I have a tortoise
    Rick
    Indianapolis, IN
    2024 SR 4x4 6 spd
    Confirming it's metal deposit on top of paint, had same issue with natural white 4runner. Polish cleaner to remove then wax. I like Klasse products.
  13. Mar 27, 2019 at 1:11 PM
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    I don't think I'll move to Maine...I'll stay in Texas
    Chew likes this.
  14. Mar 27, 2019 at 2:41 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    It happens to every color car/truck in the northern states Rusted particles) where road salt is used. (Down south they don't rust as fast) Metal particles embedded in paint, AKA rail dust but other metal particles off of road also. You notice it more on white, more than any other color. Do the sandwich bag test on any truck/car. Put it over your hand and lightly rub it over an area on your truck. It will feel like sand paper. Now Clay bar an area, and redo sandwich bag test, it will be smooth as a baby's ass. Clay bar pulls the particles out of paint.
    5500 likes this.
  15. Mar 27, 2019 at 2:49 PM
    #35
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    You're in Ohio?? Its probably because you're located so close to the RAV4 factory in Ontario that it wasn't shipped by train. No train, no rail dust.
    edit: Oh wait the RAV4 has the rail dust... I had it backwards that is really weird.
  16. Mar 27, 2019 at 2:56 PM
    #36
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    We actually prefer folks only visit. The winters here a insane, not sure even Mainers can survive them. Oh, LLBean has great mail order catalogs, and lobsters can be shipped as well. :stirthepot:
  17. Mar 27, 2019 at 2:58 PM
    #37
    Jaymes
    Jaymes Well-Known Member
    Lloydminster Saskatchewan Canada
  18. Mar 27, 2019 at 3:00 PM
    #38
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Hit that with a clay bar, then a good sealer wax.
  19. Mar 27, 2019 at 3:59 PM
    #39
    ListenUpSonny
    ListenUpSonny [OP] Member
    2019 SR, 4x4 Double Cab, V6 Tacoma
    none
    Freeport
    This is a bit of an unfair characterization of how I've treated my vehicle. I've done nothing but drive on roads. Not all vehicles have this issue, especially not after 2 months. And, yes, I do believe that if a specific paint is prone to it, which it seems to be due to a lack of clear coat, I do believe it's Toyota's responsibility (maybe not dealers, but they are the go between).
    Thank you for all the opinions. At this point, I am out of state and waiting to get back home. So, further discussion is probably moot.
    SR-71A[QUOTED] likes this.
  20. Mar 27, 2019 at 4:57 PM
    #40
    Kjntaco
    Oahu, Hi
    Has nothing to do with clear coat, heck I got some metal dust on my painted wooden bench when I was drilling something and after a few days it imbedded itself and rusted exactly like your truck. I've fixed a bunch of vehicles with the same problem.
    Boghog1 likes this.
