Brand new Tacoma is already rusting!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoNate, Dec 25, 2012.
  1. Dec 26, 2012 at 9:10 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    100% normal for some parts to instantly rust once they leave factory
    for nuts and bolts, that is why mechanics have cutoff torches. most all cars will
    need something burned off/heated up/hammered/chiseled to replace a part someday
    now, if you see rust on a painted part, then there is an issue
    for any of this rust under the vehicle (except hot parts) just blast some Krown or
    Boeshield on it, cosmoline,....any of the corrosion protection stuff...on a regular basis,
    and it will stave it off... and can prevent use of torches later on to remove stuff
  2. Dec 26, 2012 at 4:19 PM
    gasgasman
    gasgasman Well-Known Member
    The topic of discussion was about the cast iron components. Rust on stamped steel components, like the frame should be addressed.
  3. Dec 26, 2012 at 6:41 PM
    TacoNate
    TacoNate [OP] Member
    N'Awlins area
    '13 PreRunner SR5
    Thanks, one and all, for the warm welcome! I appreciate it, especially the razzin’ I got from some of you. :D
    This is my second Tacoma, and my first new one. I lost my previous one, which I loved, because it got a little ‘moist’ in Hurricane Katrina. The last seven years I’ve had an old Ranger which did honorable service hauling everything from two-by lumber to top soil as I rebuilt after the storm. When the Ranger appeared to have two wheels in the grave I decided to take the plunge with a new Tacoma.
    I'm still a little disappointed that there was so much rust on my brand new vehicle's front end. I mean, sure, you guys make a good point- Bare metal will rust, and cast parts will rust fast, but why is there so much uncoated metal surface to begin with? We have the technology, it’s called paint. I’m not expecting nickel plating, just paint. Beyond the machined surfaces, I found it especially disconcerting that the control arm bolts are already rusting. If that's what they look like after a few hundred miles, what will they look like after tens of thousands of miles when they might need to be loosened for service? Will the rusting over the years weaken them? That's not just a hassle, but potentially it could be a safety issue. Call me anally retentive, but it’s 2012, I just expect better from a first world manufacturer.
    The flecks of rust on the frame rails and inside a few holes was disappointing too. Decades ago, I used to work at the Ford frame plant at the Rouge Complex in Dearborn, MI. All the truck frames there were treated in a chromate solution and then dip-coated in paint to prevent rust. And that was 25 years ago. What's up, Toyota?
    Let me address you guys’ points, trying to credit and thank everyone for their kind and thoughtful contributions:
    Maxamillion2345, OffroadToy, and DoorDing-
    I found Fluid Film on the Web site for O’Reilly Auto Parts. When I went to my local O’Reilly outlet today, none of the staff there had heard of the product. We found it on their system and they’ve ordered it for me. It should be here in a few days. Thanks for the tip!
    JNome-
    I looked for a shop that does undercoating around here. I’ve discovered that we don’t have nearby shops that do that here in “The Sowf.” By nearby, I mean closer than Corpus Christi, TX. The only Ziebart outlet around here only does auto glass. Time’s ticking and I should get it done while the truck is still new, and I’ll keep looking…
    DR Da_da-
    Irrelevant to this thread, but I am a huge fan of the Coasties in their helos. Their work during Katrina was nothing short of heroic. The whole N.O. area will never forget their incredible skill and bravery. Hey, is someone slicing onions around here? Sniff. Damn onions. Best wishes for the New Year to everyone at Belle Chasse NAS!
    Gasgasman-
    Steel does not form a protective oxidation layer like aluminum does. Cast iron does better than steel, but it all crumbles to dust eventually. Unless it’s made of COR-TEN(tm) steel, oxidation is not going to help. Also, they should be painting highway overpasses, our infrastructure is going to hell. There is no excuse for ignoring its maintenance. But that’s off-topic.
    127.0.0.1-
    Loopback, you have the same IP as I do! Who woulda thunk it? Computers aside, I have to disagree with your assumption. I think that everything that isn’t welded at the factory should be disassemble-able (if that’s a word.) That is, a cutting torch should not need to be used to free up a normal service item like steering and suspension linkages. Just my opinion. Heat? Yes. Persuasion? Yes. Cutting torch? No, not for a service item, other than for exhaust parts and a few others. C’mon, it’s the 21st Century, we can do better than that. Toyota can too. As for painted parts. See my comments on the frame, above.
    Well, that’s it. Sorry for the long post. And thanks for the help and the welcome, everyone! I spend a lot of time on my favorite motorbike forum, and this Tacoma forum seems to be as passionate, responsive, and informative as that one. I’m impressed. And grateful. All my best to all of you for the New Year.
    Nate
  4. Dec 26, 2012 at 6:54 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    fluid film or waxoil or por15 if you want a really involved job
  5. Dec 26, 2012 at 7:03 PM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    Where the hell are the CV shafts?
  6. Dec 26, 2012 at 7:04 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  7. Dec 26, 2012 at 7:06 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Holy shit that truck is clean
  8. Dec 26, 2012 at 7:11 PM
    Vstrom30
    Midwest
    Joking. Very clean though.
  9. Dec 26, 2012 at 7:45 PM
    TacoNate
    N'Awlins area
    '13 PreRunner SR5
    Hey, it's new. But I bet my GSA's been filthier than your Vstrom. :p
    You kids kill me. RWD only, FTW!
  10. Dec 26, 2012 at 7:46 PM
    OZ-T
    Peter North
    British Columbia
    My '09 had more rust than that on it when it was brand new on the lot up here
  11. Dec 26, 2012 at 7:49 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Unpainted metal, meet moisture, and have oxidation!
  12. Dec 26, 2012 at 7:52 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Like OZ-T my 10' had that much or more when I first got it off the lot in Alaska.
  13. Dec 26, 2012 at 8:04 PM
    Vstrom30
    Midwest
    Hey, mine's rear wheel drive most of the time.
  14. Dec 26, 2012 at 8:06 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Move roughly 1400 miles due west, right down I-10 and you won't have to worry about such things. ;)
    One of the perks of living in the desert but there are times I miss that wet stuff that falls from the sky.
  15. Dec 27, 2012 at 7:43 AM
    #35
    jamesdemien
    jamesdemien Member
    They rusted off
  16. Dec 27, 2012 at 6:44 PM
    #36
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    It's worse than that - when two different metals are touching, you get galvanic corrosion, which will basically accelerate the process.
  17. Dec 27, 2012 at 9:19 PM
    #37
    JNome
    JNome Made in Maine.... Yessah bub!
    Jake
    Pace, FL
    '10 BSP SR5 4wd
    WeatherTechs, TRD Skidplate, Hidden Hitch Reciever, Tractor Supply Toolbox, Bedmat, Hayden Transmission Cooler, Leer 100R cap, yakima roof rack, Bilstien 5100's all around, Eibach lift coils, Toytec AAL w/ TSB springs, All Pro Flip Kit w/ Timbrens, Line X'd Rocker Panels, Magnaflow 17115 Exhaust, Cobra CB w/ PA Horn, Hi-Lift Jack w/ custom mount, Relentless Fab Sliders, Satoshi Grille w/ Hella 700's HID mounted behind
    Good luck with getting it coated.... like you said though... do it while its new. Bummer about the Ziebart place.
  18. Dec 27, 2012 at 10:36 PM
    #38
    Doug2000
    Doug2000 Well-Known Member
    London, Ontario, Canada
    2017 Tundra 5.7L
    Oil undercoat your truck, I don't like ziebart, it's a one time deal, it dries out and is way to expensive, and what if they miss a spot.
    I have undercoated my 08, 4 times now, they spray the bottom, inside the frame, drill holes in the doors, the tailgate, and the rockers and spray in every corner. They put a little plastic cap in the drilled holes to keep the stuff out.
    I won't even buy a used vehicle hasn't been oil sprayed, you can always tell the ones that have been.
    Krown is said to be the best, but I go to Oil Guard, here in Toronto Area.
  19. Dec 29, 2012 at 4:27 PM
    #39
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Does this product actually kill and stop the rust from forming or is it more of a preventive?
  20. Dec 29, 2012 at 7:21 PM
    #40
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Excellent! i just picked up a can cause some jack@#$ gouged my corner bumper down to bare metal and it has started to rust...
