Brand new truck having trouble starting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Weasel09, Dec 10, 2013.
  1. Dec 10, 2013 at 9:15 PM
    Weasel09
    Weasel09 [OP] Well-Known Member
    Wes
    Wahiawa, Hawaii
    6 Speed TRD Offload & X-Runner
    I bought my current tacoma less than a month ago, and about a week after I got it I would have to turn the key a few times before it would start. Almost every time I go turn the key it will click once and then nothing. I do it 3-7 more times and it starts and runs fine. Everything still works with the key in the ACC position. Occasionally I will turn the and it will click once then I hold it and it starts. I've looked at the battery and all visible wires and I see nothing wrong. I have been trying to take it back to the dealer to get it looked at but just haven't had time.
  2. Dec 10, 2013 at 9:16 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    How's the corrosion on the battery terminals? Sparkplugs look good?
  3. Dec 10, 2013 at 9:18 PM
    Weasel09
    Wes
    Wahiawa, Hawaii
    Nonexistent, it's got 800 miles on it. They are actually shiny!
  4. Dec 10, 2013 at 9:19 PM
    Weasel09
    Wes
    Wahiawa, Hawaii
    I don't think it's spark plugs because when it does get started it will run fine all day.
  5. Dec 10, 2013 at 10:46 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Poor Battery, High resistance connection on the battery or starter, or defective starter.
    The click you hear is the starter solenoid, at that point the starter should turn.
  6. Dec 10, 2013 at 11:05 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Just like Guam, im sure corrosion will be a major pain in the butt for you.
    I would first disconnect the battery terminals and clean them good.
    They may look good but not making a good connection underneath.
    if that doesn't work, then look at the battery, then the starter as stated above
  7. Dec 11, 2013 at 3:10 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Things like this are always frustrating. You buy a new vehicle and it has some problem and this kind can be difficult to run down. If you checked the battery voltage and it is good then there is a bad connection some place and it will have to be checked out. Most likely a lose wire or even a bad switch. Take it to the dealer and leave it. Get a loaner and go about your business until they find the problem.
  8. Dec 11, 2013 at 3:15 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Sounds like a bad battery or like your starter is locking up.
  9. Dec 11, 2013 at 7:54 AM
    Weasel09
    Wes
    Wahiawa, Hawaii
    I appreciate the help guys, I guess I'm just going to have to take it to the dealer.
  10. Dec 15, 2013 at 10:14 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    I would check the battery's State-of-Charge and fully recharge, if necessary., especially if the vehicle has been parked for several weeks. Batteries are perishable and new to be periodically recharged to prevent sulfation and to replace the power lost by the natural self discharge and the vehicle's parasitic load. Next, I would look for corrosion, oxidation or paint between the battery terminals and posts or ground. If the problem persists, I would have the battery, charging system and starter load tested.
