Brand New Truck Overheating?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 90YotaPU, Aug 23, 2010.
  1. Aug 23, 2010 at 2:11 PM
    90YotaPU
    90YotaPU [OP] The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Today I was driving along at about 50 mph when I noticed the temperature guage was really high. I got out and found that the top radiator hose had disconnected. My truck has under 1,500 miles on it (only four weeks old). I reconnected the hose and let it cool off then started it up and the temperature went right down. I got about five minutes down the road and it went up again. Again waited about two minutes restarted and the guage went right back to normal. So I pulled into an AutoZone to get coolant and filled the tank. From Autozone I went to the dealer (where it is now). But on the way the temperature guage went up and down three times! The dealer gave me a loaner car and said they'll look at it tomorrow. Also the last twenty minutes I had no heat which obviously means there's no coolant (or not enough) circulating through the engine.
    Any ideas on what the problem is? Being there's so little miles I can't see why it wouldn't be covered under warranty but I can't stop wondering what the problem is.
  2. Aug 23, 2010 at 2:14 PM
    cinch
    cinch Member Extraordinaire
    Al
    Boulder Creek Ca
    2010 Prerunner double cab
    You filled the tank but did you fill the radiator while the thermostat was open? I don't think just filling the tank would add enough coolant to fill the system if the radiator hose was completely disconnected.
  3. Aug 23, 2010 at 2:15 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    chances are the clamp securing the hose was loose/broke, coolant probably leaked out causing the system to lose pressure so the temp rose to high, causing the hose to eventually fall off. *shrug* thats my guess! let us know what the dealer finds out and how they handle it
  4. Aug 23, 2010 at 2:23 PM
    efmugen
    efmugen Well-Known Member
    Pasadena,CA
    06 4-banger
    maybe a faulty thermostat :confused:... anyhow dont forget to tell the dealer you refilled the radiator with autozone coolant so they can refill with the OEM pinks coolant after they service your truck.
  5. Aug 23, 2010 at 2:37 PM
    90YotaPU
    Union County, NJ
    Thanks guys I'll keep everyone updated. That's one thing I just thought about is I just filled up the tank. I didn't want to try opening the radiator cap. Maybe I shoulda brought it home first and let it cool down. I was so close to the dealer I figured I'd just take it. In the meantime I'm driving around in a 2010 Hybrid Highlander. Nice truck. Will let everyone know that outcome.
  6. Aug 23, 2010 at 4:20 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    Probably have air in the system. Need to purge the air out.
  7. Aug 23, 2010 at 4:23 PM
    skunk
    skunk what did I miss?
    Rudi
    SoCal
    2010 TRD 4x4 (STOLEN)
    YOU WILL BE MISSED Satoshi Grill, FX-R retros, husky liners, bed bolt d-rings, TRD short throw shifter, 2.5 Fox Coil overs, AP UCA's, AP Expo rear leaf with Fox 2.0 shocks, Extended SS brake lines, AP kick-out sliders, 265/75/16 on Konig Countersteers, AllPro Apex front bumper and Zip Ties.
    2010 = Dealer warranty problem
    bastids.
  8. Aug 24, 2010 at 11:10 AM
    90YotaPU
    Union County, NJ
    Just heard back from the dealer. Turns out the hose clamps have two settings on them (never heard of this but ok). One setting is to allow it to be loose enough that you can slide it on and off the radiator. The second setting is to keep it tight to the radiator. Apparently the factory installed the clamp on the loose setting which made it come off. The reason it wasn't working right after I filled it up was because it needed to be bled. I asked and they confirmed that they did drain all the old coolant (including the AutoZone stuff) and replaced it with the Toyota coolant.
    Thanks for the feedback guys.
  9. Aug 24, 2010 at 11:13 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    em 2 setting on those OEM hose clamps...I don't think so...i've taken my coolant hoses off so many times I know for a fact its just at full clamp or open...nothing in between...I always use a set of pliers to open them up...
    but glad to hear the stealership fixed it...hopefully it didn't ruin anything else...
    do you have a SG2? if so you can watch the water temp...
  10. Aug 24, 2010 at 3:39 PM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    I'm going to go out and check my radiator hoses imediately!
  11. Aug 24, 2010 at 3:53 PM
    terry13
    terry13 Active Member
    terry
    missouri
    2010 tacoma 4x4 sport
    Mud flap trim, T-Rex eyelids, map light dome light mod, hood deflector, Access bed cover, Grillcraft upper and lower, Painted engine cover, 2.5" Readylift leveling kit, 10" Kicker sub and amp, Weathertec floor liners, tailgate hose clamp mod, shortened factory antenna, EGR in channel window visors, flyzeye dash light, blacked out badges, 17x8 Ultra Maverick Wheels, 3rd brake light vinyl TRD decal, AFE CAI,
    checked my clamps since i have a 2010 also. everything looks ok. the clamps do have a part of it that sticks up that looks like it might hold it open if you open it that far. but not sure. im used to either on or off.
  12. Aug 24, 2010 at 8:41 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Some spring style hose clamps have tab on them that allows them to "lock" in the open position, which makes removing/installing the hoses easier. I've seen this happen on many brand new vehicles. When the truck was built at the factory, the person responsible for clamping the hoses on missed 1:mad: (out the possibly hundreds they did that day).
    Hope no damage was done to the engine when overheated!!!:eek:
  13. Aug 24, 2010 at 8:52 PM
    T0LLPHR33
    BSP TRD Off-Road
    mines must be the old style clamps since its an '06...:confused:
    I would do a complete flush of the oil...if your coolant was above boiling point that could make the oil start to gum up and build up residue...just a suggestion...
