Brand new truck vibrations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RocketTaco, Nov 16, 2018.
  1. Nov 16, 2018 at 7:00 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Go to the dealership first then see what they diagnose. If not happy go to another, if still not happy post what both said here. If still not happy you now have multiple opinions to sort through.
    BillsSR5 and VaToy like this.
  2. Nov 16, 2018 at 7:16 AM
    Further
    Further Member
    Dave
    2018 Black on Black Taco TRD Off-Road
    I've got a similar vibration(s) issue, bought the truck 2 weeks ago (2018 TRD Off-road) - whole truck vibrates between 55 and 75 mph and then the shuttering during braking. Took to the dealer 1st time at 300 miles they found a flat spot on rear passenger side tire, got it replaced - no difference. Took it to another dealer at 600 miles, they re-balanced all four wheels - no difference, still same vibration and actually seems like its getting worse. Called Toyota USA yesterday just so I'm on record/document whats going on. Dropped it off to another dealer (dealer where the car came from) this morning for the 3rd (hopefully last) time. Unfortunately there is snow on the roads so they're going to have to wait to diagnose until the roads are clear so I'm in a loaner till then.
    All the comments above about this being a truck and its supposed to drive like that are BS - I've driven many trucks in my life and the vibrations in this thing are not normal and its definitely not how they're supposed to drive. Take it to the dealer and be persistent. I've got 2000 miles on mine in 2 weeks - I drive alot and am now uncomfortable in my 40k brand new truck. I'm not giving up until they figure this shit out or I get a new truck (Exactly the same as what I have cause I actually love the truck).
    Good luck!
    smikels likes this.
  3. Nov 16, 2018 at 7:20 AM
    chadabear
    chadabear Well-Known Member
    Chad
    Louisiana
    2018 DCSB 4x4
    Should stop here....
  4. Nov 16, 2018 at 7:39 AM
    RocketTaco
    RocketTaco [OP] Well-Known Member
    2019 SR Access Cab V6
    I really dont understand the negative responses to someone asking a question and starting a discussion. It's a discussion forum. If you don't want to be part of the discussion then don't, no one is forcing you.
    No one should ask about rims because they can just go look at some rims? No one should ask about tires because they can just google some reviews? Any question can be solved elsewhere, so why have a forum?
    abhamber, Bushed and Further like this.
  5. Nov 16, 2018 at 7:43 AM
    Further
    Further Member
    Dave
    And just to add to that... I doubt the OP is asking for a solution (i wouldn't be anyway) on this forum, that would be silly. There is no reason not to start a discussion to see if there are others with the same issue and what if anything they've done to solve their problem. That's what the forum should be about. I just joined this forum and already kinda turned off by the silly negative responses to an appropriate post.
    Bushed likes this.
  6. Nov 16, 2018 at 7:44 AM
    Flytmech
    Flytmech Well-Known Member
    Jase
    Geneva Alabama
    2016 Tacoma TRD OFFROAD 4x4
    All Pro Offroad bed rack Defender Basket OME/Dakars Total Chaos ucas C4fabrications LoPro Smittybilt 9.5 comp Uniden 520xl (tuned) CVT Mt. Shasta Black Oak 50 curve led
    Ignore the trolls, they go away when they dont get any attention. Hope you find your answer. Most folks are happy to help on here.
    Briavael, smikels and CusterFan like this.
  7. Nov 16, 2018 at 8:46 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    The truck is brand new, go to the dealership and see what they say as the visit is free.
    You did not elaborate where you feel the vibration other than its at different speeds.
    Felt in the gas and or brake pedals at accel and decel? Check drive shaft coupling / U joints for tightness. Could be rotors
    Felt in the steering wheel? Tire Balance
    Felt in the seat and dash? Noise isolate/motor or cab mount.
    Just for reference what air pressure are you running?
    Since you didnt elaborate we cant really hazard a guess. I can tell you with brand new offroad tires you might get a vibration for a few miles until the tread wears in.
    Take it to the dealership and have them ride with you to feel the symptom first then get back with what they say if they cant find a reason.
    Its what we did long before we had forums so the process can still work.
    hiPSI and VaToy like this.
  8. Nov 16, 2018 at 9:40 AM
    smikels
    smikels Well-Known Member
    Shane
    Suffolk, Virginia
    OP you doing great. This is what a forum is for to post things about the truck and get good information. Always good to post and see what others may know. Ignore the hot air man some people will try and help and not talk down to you to make themselves feel better.
    CusterFan likes this.
  9. Nov 16, 2018 at 10:42 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    member "Further" proves my point. he took it 2 different places. they threw parts at it for a normal/unknown issue and it didn't fix it. states hes had multiple other trucks. probably none of which were 3rd gen tacos. brings up the for what he paid for it part. then states he wants a new truck which will also probably do the same thing.
    unless you've driven 10-15 other 3rd gen tacos how can you state that it is a actual problem or what the vehicle does. just cause you don't like the way it drives/feels doesn't mean its broke or that it will break in the near future. yes many people have complained about these issues. but have any of them been fixed? same with transmission shifting issues. has anyone on this forum actually had their transmission fail? any part of it? or do they all just object to the way it shifts.
    I bought my 2016 in july of 16. it has some of the same issues the OP and others have brought up mainly from this post shuddering on decal. on or off brakes. hasn't got worse, hasn't got better.
    there has been some talk of rear leaf springs causing this issue. maybe that is it maybe not. how long do you want to spend in a loaner or eating donuts while. Toyota tries to decide if its a defect or customer extra sensitive.
    on other note. does anyone know if Toyota uses a PICO Scope? its measures mila g's at seat frame. and can classify them as tire/engine/drivetrain/prop shaft vibrations. and can narrow down where its coming from. and if they are above spec. have used this on 14-18 Silverado's for vibration concerns.
  10. Nov 16, 2018 at 5:18 PM
    perryp
    perryp Well-Known Member
    Perry
    Great White North
    2013 TRD Off Road
    If you're willing to make the effort...and a simple diagnostic.
    Switch front left tire with rear left...test drive and comment..better (left front tire is out of round or out of balance).
    Switch right side tires,...better or worse?...same?..
    Sometimes the solutions are simple.
    The diagnostics is 90% of the problem
    And btw guys,..be nice with the posts.
    This fellow is a brother after all...
    If he drove say....a Dodge,...I'd get the rope....and drag him to a bridge! (just kidd'n)..
    jsinnard likes this.
  11. Nov 16, 2018 at 6:05 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Air pressure.
  12. Nov 16, 2018 at 8:44 PM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    The Pico is the mandated shop tool for sensor and network, etc diagnostics. I’m not sure if they make use of the accelerometer accessory. That sounds like a cool idea though. Driveline vibrations are not something I’ve spent enough time studying.
  13. Nov 16, 2018 at 9:22 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    You can ask any questions you want to here,ignore the negative responses,you have a warranty on the truck,take it in and have Toyota fix whatever the problem is.
  14. Nov 16, 2018 at 9:25 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Check your lug nuts make sure they are all tight, first of all. Call the salesman that sold you the truck and tell them to get you right in and ask for a loaner.
  15. Nov 17, 2018 at 4:01 AM
    #35
    turbosnail
    turbosnail Well-Known Member
    Pa
    18 dbl cab sr5 v6 4x4 , 1985 turbo sr5 pick up
    I’m curious to find out what your service department turns up as the culprit , my 2018 sr5 has had this exact same vibration at the exact same speeds . My truck only has 800 miles on it so far , I love the truck otherwise .
  16. Nov 17, 2018 at 4:10 AM
    #36
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    @mds08
    Mark, do you want to chime in on how the vibrations felt on your truck with the missing wheel weight on the rear tire?
  17. Nov 17, 2018 at 8:39 AM
    #37
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    There are a thousand reasons why a truck vibrates and there will be a thousand answers that will be absolutely meaningless to the service department. There is nothing wrong with being informed but being informed with the wrong information is just as bad as not knowing anything. If your serious about educating yourself on the mechanics of your Tacoma get a service manual and start reading. Your assuming that the service department is going to bullshit you even before you visit them. Go in with an open mind and work with them. If they dont resolve the issue then try another dealership or call Toyota customer service.
  18. Nov 17, 2018 at 8:46 AM
    #38
    SpeySquatch
    2016 TRD OR DCSB
    There is a leaf pack replacement TSB that has new leafs that fix the driveline angle. (Likely your issue), could also be off balance wheels
  19. Nov 17, 2018 at 9:13 AM
    #39
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I lifted the truck with bilstBil 5100s, 1/4 shim for taco lean and a one inch block in the rear, added the ECGS clamshell. Put new 265/70/17sl Toyo open country at2 on trd pro Sema wheels. Had a slight vibration at 53 and around 64. Thought it was a rear tire out of balance, left rear out a little. Also did a front diff drop. The truck felt great after that. The vibe felt in the pass. Seat shaking and I could feel the vibe mostly when I rested my left leg on the door panel. They did a diff drop at first and then re road forced all tires. It was so slight of a vibration I only felt it on certain type of roads and when the tires were cold. I have such a short comutec to work I didn't feel it all the time. Now 300 miles on the re balance all is well. The shop was for sure a diff drop was the answer but it was definitely a help. I got almost 3 inch in the front when the new tires were on.
  20. Nov 17, 2018 at 10:18 AM
    #40
    RocketTaco
    I appreciate the input, both positive and negative, even if you don't understand my point if view for asking. I'll report back after the dealership checks it out on Tuesday.
