brand new truck won't start!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bolt_thrower77, Mar 4, 2021.
  1. Mar 4, 2021 at 3:43 AM
    bolt_thrower77
    bolt_thrower77 [OP] Well-Known Member
    2021 DCLB trd or
    i remote started the truck this morning and when i went to get in it stayed on ( usually shuts off)....the defrost vents were on full blast....i thought this strange so i turned it off and when i tried to restart... nothing!....lights and blowers come on with " check charging system ".... won't let me control climate system either....truck has 2k miles on it...:(
  2. Mar 4, 2021 at 3:45 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Check fuses.
  3. Mar 4, 2021 at 3:45 AM
    Mmaira2018
    Mmaira2018 Well-Known Member
    Is it an aftermarket remote start? To the best of my knowledge, if its faulty you'll have to remove it to get the truck to start since it acts as a go-between with the ignition and the ignition switch
    Kev250R, SR-71A and JaiOME like this.
  4. Mar 4, 2021 at 3:46 AM
    bolt_thrower77
    2021 DCLB trd or
    now im locked out of it....fml
  5. Mar 4, 2021 at 3:47 AM
    bolt_thrower77
    2021 DCLB trd or
    factory remote start....push lock button 3 times and hold 2021 or....
  6. Mar 4, 2021 at 3:47 AM
    Mmaira2018
    You can still unlock the car door with the physical key that's in the starter fob. Push the little tab on the side and it should slide out
  7. Mar 4, 2021 at 3:50 AM
    bolt_thrower77
    2021 DCLB trd or
    just checked battery has 12v....
  8. Mar 4, 2021 at 3:50 AM
    bolt_thrower77
    2021 DCLB trd or
    got in with hard key and it randomly started
  9. Mar 4, 2021 at 3:52 AM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Under 2k miles...let warranty deal with it, or at least take it in and have a record of it going in with this issue
    Skydvrr likes this.
  10. Mar 4, 2021 at 3:54 AM
    Norms_207
    Norms_207 Well-Known Member
    ME
    2016 TRD Sport DCLB
    If it happens again I would take it in
  11. Mar 4, 2021 at 4:06 AM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    This must be a software bug. Happened to me recently on a new 2021.
    Same thing, opened door after remote start by grabbing handle and it didn't shutoff (weird), then trying to start would only go into something like accessory mode and off. I think it tripped the immobilizer or something. Both keys behaved the same. Finally got out, locked, unlocked, got in and started normally. The computer apparently needed to get back to the right sequence to be happy.
    SR-71A likes this.
  12. Mar 4, 2021 at 4:42 AM
    desert_gypsy
    desert_gypsy Well-Known Member
    2020 MGM TRD Off-Road
    This is likely to be one of those things that the dealer cannot replicate if you take it in for this issue.
    Skydvrr likes this.
  13. Mar 4, 2021 at 4:54 AM
    Gutentight
    IL
    Remote started mine maybe 20x and it only happened once. Thought I stumbled on a new feature and Toyota listened that others don't kill the engine after remote start, but no this is some factory system glitch.
  14. Mar 4, 2021 at 5:31 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    If you have recently added any electrical doodads (even unrelated) definitely go back and check those, after that, I'd take it in.
    Kev250R likes this.
  15. Mar 4, 2021 at 6:07 AM
    bolt_thrower77
    2021 DCLB trd or
    i did replace the stereo and added a sub....but everything is wired correctly and there os good voltage at battery..... just wondering why the check charging system light?
  16. Mar 4, 2021 at 6:10 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    To properly check a battery, it is tested under load. Visit a shop or auto parts store, they'll do it.
    Kev250R likes this.
  17. Mar 4, 2021 at 6:14 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I have a 19 with aftermarket remote start that randomly does the same thing. It's only done it twice in 2 years but each time the engine didn't turn off when I opened the door. It died with the brake and wouldn't restart.
    To fix it each time I get out and cycle the door locks and wait a few minutes and starts like normal. It's a glitch so I've just left it be.
    jmneill likes this.
  18. Mar 4, 2021 at 6:17 AM
    bolt_thrower77
    2021 DCLB trd or
    damn dude..... that's crazy......it wasn't horrible because i was at my house.... would have been a different story if i would have been out somewhere and got locked out or whatever
  19. Mar 4, 2021 at 6:20 AM
    neatoneto
    neatoneto Well-Known Member
    CT/Mass
    2020 TRD Off Road DCSB
    It might be a bug with the Toyota Remote Connect issue with the 2021's. I've remote started about 200-300 times in the last year on my 2020 and no issues so far. I'd take it in if it happens again. They'll have to escalate it and possibly check the logs.
  20. Mar 4, 2021 at 6:22 AM
    ICU1
    ICU1 Well-Known Member
    Uninstall and reinstall key fob battery...
