brand new truck won't start!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bolt_thrower77, Mar 4, 2021.
  1. Mar 4, 2021 at 6:37 AM
    bolt_thrower77
    bolt_thrower77 [OP] Well-Known Member
    2021 DCLB trd or
    does anyone know if the computer will hold the "check charging system" light like an error code that can be read by service dept?
  2. Mar 4, 2021 at 6:38 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    pull key fob battery and pull the negative terminal off on your battery to see if you can reset the ecu. See if that helps?
    shakerhood likes this.
  3. Mar 4, 2021 at 7:35 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    When the Ignition is in the "On" position without the engine running you will get the Check Charging System indication.
    jayuu, Chew and usmc2msu like this.
  4. Mar 4, 2021 at 9:06 AM
    Hilux73
    Hilux73 Member
    2020 Limited
  5. Mar 4, 2021 at 10:14 AM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    This. The message pops up every time ignition is switched to on. It happens in most cars, but it’s usually just a battery symbol/light that no one notices.
    jayuu and shakerhood[QUOTED] like this.
  6. Mar 6, 2021 at 1:59 AM
    bolt_thrower77
    2021 DCLB trd or
    i know that all of you crusties couldn't sleep without an update so here it is.....
    I've tried for 2 days to replicate the no start/ lockout fun that i had and it won't do it....so i guess I'll just lose faith in a brand new pickup and try to remember not to use the remote start when i'm away from home.....thanks for the support tw....you guys i can actually count on
