Brand New Wheel Bearing VERY hot...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nick_kellog9, Mar 28, 2024.
  1. Mar 28, 2024 at 5:39 PM
    Nick_kellog9
    Nick_kellog9 [OP] Well-Known Member
    Nicholas
    Eastern Shore MD / Daytona FL
    2002 Supercharged 5MT Lunar Mist
    OME's Firestone Destination AT/2 265/70r17 Nomad 501SA Convoy Salt Baja Designs Squadron Sport/S1 Leer Camper JBL/Pioneer Stereo
    Update from last post titled "Wheel Bearing Woes":
    Got the spindle back from the shop today.
    They said it went on no problem.
    Re-installed the spindle in the truck, the bearing felt a little tight not too bad. This is after re-installing the axle nut etc...
    I took it for a drive, everything seemed ok, except that the brake shield was bent and I had to re-bend it away from the hub or whatever it was rubbing on.
    Seemed fine, brought the truck home, felt the hubs. Left one (good one), was warm but basically cool to the touch.
    The one that was just pressed in was HOT. Like burn your fingers hot.
    Any ideas?
    No play in it or anything just really hot.
    Really need to get this thing sorted out.
    Thanks!
  2. Mar 28, 2024 at 5:58 PM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Bearing too tight, no grease, brake not releasing...
    wilcam47 likes this.
  3. Mar 28, 2024 at 6:00 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    4x4 or Prerunner?
  4. Mar 28, 2024 at 6:07 PM
    Nick_kellog9
    Nicholas
    4x4
    Brake caliper had no issues before this so I don’t think that’s what it is but I could be totally wrong…
  5. Mar 28, 2024 at 6:08 PM
    Nick_kellog9
    Nicholas
    Would the bearing be too tight based on not being supported while being pressed?
    I’m going to call the shop in the morning and ask how they supported the inner race while pressing the hub on.
  6. Mar 28, 2024 at 6:16 PM
    LanceRN
    Lance
    That would be a good start...and jack up that wheel and see if the brake is dragging.
    skeezix and Nick_kellog9[OP] like this.
  7. Mar 28, 2024 at 6:19 PM
    Hotdog7
    Hotdog7 Well-Known Member
    Fred
    1gen Tacoma
    Toytec 2.5-3" lift 2010 rims wheel spacers tundra brake upgrade
    I'm sure you won't hear the truth If you ask that. Did you put proper torque on axle nut?
  8. Mar 28, 2024 at 6:19 PM
    Nick_kellog9
    Nicholas
    Got a little less than a full rotation when spinning the tire.
    I’ll go look again to see…
  9. Mar 28, 2024 at 6:20 PM
    Nick_kellog9
    Nicholas
    Torqued to 173 ft/lbs
  10. Mar 28, 2024 at 7:20 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I wouldn’t drive with it on there and bring it back to them.
  11. Mar 29, 2024 at 7:38 AM
    Hotdog7
    Fred
    1gen Tacoma
    I just replaced my daughters press in wheel bearings without removing knuckles on a Kia Rio. From what I've watched on YouTube I see them removing knuckles and have a special tool to use on press not sure if that's the only way or you can use press on tool while on truck but definitely need support inner race while pressing on hub.
  12. Mar 30, 2024 at 8:06 AM
    Nick_kellog9
    Nicholas
    Update!
    removed and replaced the inner oil seal in the spindle. Removed and lubricated the caliper.
    All good now!
    LanceRN and Dalandser like this.
