Brand of Motor Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shortround67, Oct 7, 2012.
  1. Oct 7, 2012 at 11:34 PM
    shortround67
    shortround67 [OP] Member
    :)Just wondering what brand of motor oil most of us use in the tacoma? I use mobil 5w-30 in my 2011 prerunner
  2. Oct 7, 2012 at 11:37 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    I personally use what ever oil that is real cheap usually a 5w-30. No synthetic for me. If my truck was newer like a 05+ i would use synthetic to take care of the engine better.
  3. Oct 7, 2012 at 11:43 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
  4. Oct 8, 2012 at 12:14 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I drain mine into a kitchen bowl (so I know it's clean) then I run it through several coffee filters and back into the engine. If it's low I'll top it off with whatever I got on hand.
    cheapest gallon jug of synthetic walmart has
  5. Oct 8, 2012 at 3:41 AM
    watacomaguy
    watacomaguy Active Member
    Washington
    2012 4x4
    Use whatever name brand oil is cheaper. They all are pretty good. There is no way I would strain my own oil and re-use it.
  6. Oct 8, 2012 at 4:14 AM
    NWTacoGuy
    NWTacoGuy Well-Known Member
    James
    Pacific North West
    2010 TRD Off Road DCSB
    Fabtech 6", xd addicts/35x11.50 Nitto Terra Grapplers, Black badges, Pioneer HU, 11' grille, ect ect ect....
    I used Mobil 1 for years on my old V8's....then got into Amsoil and never switched back. Over 7 years now I have used Amsoil and put it in everything I own. I am pretty sure I would run Amsoil in myself if it would help me operate better and get more longevity :D
  7. Oct 8, 2012 at 5:24 AM
    kurtw
    kurtw Extra Regular
    Kurt
    Leander, TX
    07 PreRunner Double Cab TRD Sport - Sold / 2016 4runner Trail Premium
    There's Mobil 1, then there's everything else. I've used everything over the years, done the research (I could prolly talk your ears off about zinc content) and tried everything. Unless you like spending $20 a Qt. for super high-end racing oil that gets changed way more often, I haven't found anything better than Mobil 1.
  8. Oct 8, 2012 at 5:32 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    Pennzoil Platinum. It gets good ratings and lab results on BITOG, and it's normally $1 cheaper for a 5qt Jug at Wally World.
  9. Oct 8, 2012 at 5:56 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I use Mobil 1.
  10. Oct 8, 2012 at 6:58 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I have been using Mobil 1 in new vehicles for the last 20 years or so...in that time we have not had a an engine issue that involved removing valve covers, oil pan or intake manifold. This includes several vehicles with above 200k on clock.
    Our 60's vintage trucks (three of them) get Rotella 15w-40 which has the right additives for flat tappet engines.
    About 20 years ago, Consumer Reports did a research project involving most major brands of oil and a fleet of NYC taxis. The rebuilt ALL the engines, put in different brands of oil, in a blind study, ran the engines for roughly 80k miles, and rebuilt them again, measuring oil usage and wear, using camshaft/tappet wear as their major indicator as well as oil usage.
    They concluded that if the oil met the API requirements, there was really no difference in engine life between various brands of oil. Their comment on the "super premium" oil such as mobil 1, amsoil and such was that if they improved engine life, it was difficult to measure. I would consider NYC taxi service to be severe service with 24 hour operation, and long periods of idle and low speed operation, intermixed with full throttle periods.
    The message I took away from that study was that if you used good quality oil, with the correct API spec at the correct viscosity and changed it recommended intervals, then brand really didn't matter.
    My personal experience is that high milage engines normally need to come apart when a combination of leaking rear main and front main seals, combined with ring and valve wear increase the oil consumption to over a quart a week, and decreased fuel economy from decreased compression and valve wear makes it economically worthwhile to either pull the motor and rebuild or replace the vehicle.
    On the Tacoma operated in climates with salted roads, I expect the bodies to fail long before the engines, even with "dino" oil.
    Howard
  11. Oct 8, 2012 at 7:25 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Much depends on your OCI, and you didn't post what that was. Personally, if it's 5K or less, any oil that meets API specs will be more then sufficient. For 8K, any of the Group III "hydro-cracked synthetic" oils will be more then sufficient. For 10K, a Group IV synthetic. For anything over 10K, Group IV and I'd add oil analysis to verify oil health.
  12. Oct 8, 2012 at 7:32 AM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    So far it's been Valvoline All Climate 5W-20 (with Toyota filters).
  13. Oct 8, 2012 at 8:05 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    mobil 1 in all my newer cars.
    brad penn or kendall in my air cooled machine.
  14. Oct 8, 2012 at 1:08 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Mobil 1 0w20 synthetic, what the owner's manual recommends. I've always had good luck with Mobil 1, Valvoline, and Castrol in all my vehicles. Little known secret, but O'Reilly's brand oil is Mobil 1 in disguise, so I typically get that, it's usually 2 dollars cheaper than anything else too.
  15. Oct 8, 2012 at 1:47 PM
    hetkind
    Howard
    Johnson City
    Not to hijack this thread, but you know who makes their O'Reilly's GEAR OIL? I picked up a gallon with an LSD rating for the wife's jeep and wondered if it is also an Exxon/Mobile product. Mobil seems to still be a major manufacturer of industrial lubricants, some of which are gear oils in various grades and types.
    Howard
  16. Oct 8, 2012 at 2:11 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    Mobil 1 is over priced. I use Quaker State Synthetic. It's $18 for a 5quart jug at Walmart.
  17. Oct 8, 2012 at 2:39 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Agreed. I put any 5w-30 dino oil i find on sale and change at 3k. Race car gets $15 qt. Oil though.
  18. Oct 8, 2012 at 2:42 PM
    hetkind
    Howard
    Johnson City
    you can easily move to a 5k oil change interval...
  19. Oct 8, 2012 at 2:43 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I normally use Penzoil Platinum full synthetic.
  20. Oct 8, 2012 at 2:45 PM
    J Rod
    J Rod Loves Sammiches.
    Jared
    Where theres more livestock than humans.
    2010 FJC
    16x8 Method NV Wheels, 285/75/16 Duratracs, Axe/Shovel Mount for Roof Rack, Tuffy Light Mount, Rigid Industries 40" LED light bar, Husky Liner floor mats, TT Blackout all around.
    Mobil1 Synthetic 5W30 with Mobil1 Filter. Nothing else touches any of my vehicles.
