Brand recommendations for parts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by guyofnowords, Jul 19, 2022.
  1. Jul 19, 2022 at 3:12 PM
    guyofnowords
    guyofnowords [OP] Well-Known Member
    Do you have any brand recommendations for:
    Sway bar end links
    Outer tie rod
    Lower ball joint
    Brake rotor
    So far, I'm looking to buy these brand for the parts:
    Sway bar end links (MOOG)
    Outer Tie rod (MEVOTECH - the supreme line)
    Lower ball joint (MEVOTECH - the supreme line)
    Brake rotors (BREMBO blanks)
    Also for the zerk fittings on the end links, outer tie rod, and the lower ball joint can I use Red 'N' Tacky grease to fill them?
  2. Jul 25, 2022 at 3:46 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I would say stock for all except for the brembos
  3. Jul 25, 2022 at 3:48 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Lots of people have had problems with spotty quality from Moog in the last several years.
    I can't speak for the other parts, but I can recommend the Mevotech greasable swaybar end links from Rockauto. They've held up to pretty hard use and very salty winters.
    I've used Red N Tacky on everything with a zerk on my truck for about 200k miles.
  4. Jul 25, 2022 at 4:05 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I’d say Toyota. There’s some Toyota dealers that have very competitive prices. Try conicelli Toyota out of PA, competitive prices and anything over $75 total is free shipping.
  5. Jul 25, 2022 at 4:09 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    All OEM. They are high quality and will last longer than MOOG. OEM blanks too. Upgrade only if you plan to offroad it.
    Only use the grease recommended by Toyota. I think it's moly palladium by Valvoline.
  6. Jul 25, 2022 at 7:10 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I have mevotech sway bar end links and outer tire rods. I would never In my life buy suspention parts from a stealership.
  7. Jul 25, 2022 at 7:19 PM
    acparker12
    acparker12 Well-Known Member
    Penns Valley, PA
    2014 MGM Tacoma TRD Sport 4x4
    Still figuring it out…
    OEM would be my go to but I wouldn’t hesitate to use mevotech either. I’m also hearing to many bad things about MOOG lately, which is sad
  8. Jul 25, 2022 at 7:56 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Don't overlook the inner tie rods. I just replaced my inner/outers with Moog. Discarded my sway bar, but the OME coils help with sway, more than I thought they would. I don't think you can buy OEM BJ’s a la carte, they only come with the control arms. Rotors, resurface the OEM’s if you can; otherwise, get what you can afford - Dura, AC Delco, Wagner, Centric, EBC, OEM, etc …
  9. Jul 26, 2022 at 11:04 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    I am a fan of NAPA parts, esp their premium lines, alternators and brake parts. Having said that, if I was keeping the truck, I would try to put OEM parts back on.
  10. Jul 27, 2022 at 4:16 PM
    guyofnowords
    I literally bought all the parts and brands as mentioned from my post... sadly I didn't get anyone posting on this post for almost a week, so I just went ahead and bought them and installed them.
    But I have read through your guy's post. Some very good recommendations and advice.
    So far, I installed:
    end links from Moog
    outer tie rod from Mevotech
    I just receive the Brembo rotors today
    For the ball joints, I'm going to leave it on until I can afford the OEM LCA
    For the grease, I just used some moly grease from orielly's auto part. I believe it's called master pro
  11. Jul 27, 2022 at 4:18 PM
    guyofnowords
    I tried to keep everything as OEM as I can, but the prices stack up in the end when I'm buying multiple parts...
    But how are NAPA parts holding up for you?
  12. Jul 27, 2022 at 4:26 PM
    guyofnowords
    I used to have some very minor play on both tires when I did the wiggle test (hands on 9 and 3 o'clock and shake the tire)
    When I replaced the outer tie rod, the play on the driver side went away, but the passenger side still persist.
    Was there any specific reason why you changed the inner tie rod too?
    For the BJ, I tried searching for it for a while... and stumbled on the same conclusion as you lol
    As for the Rotors, I went with Brembo's as they were the same price as OEM... I always wanted to try Brembos, so I figured, why not?
    Also, I didn't want to resurface them as they are 175K old... I would rather replace them.
  13. Jul 27, 2022 at 4:27 PM
    guyofnowords
    Have you used Mevotech before?
  14. Jul 27, 2022 at 4:27 PM
    guyofnowords
    How are they holding up for you? How many miles have you put on them? What type of grease did you use?
  15. Jul 27, 2022 at 4:30 PM
    guyofnowords
    For the grease, I used this one:
    https://www.oreillyauto.com/detail/...-2006-toyota-tacoma?q=grease+cartridge&pos=15
    Hopefully, this is capable as they didn't have the Vavoline brand in stock
    stevesnj[QUOTED] likes this.
  16. Jul 27, 2022 at 4:33 PM
    guyofnowords
    Nice to hear!
    I already installed and greased everything... If I wanted to switch to red n tacky, would I have to squeeze out all the old grease, or can I mix the two?
  17. Jul 27, 2022 at 4:34 PM
    guyofnowords
    Do you have brembo blanks installed?
  18. Jul 27, 2022 at 8:33 PM
    Chuy
    Lakeside, CA
    Silver Taco
    You check the inner rods two ways. Push up on the inside of the tie rod adjustment bar and feel for movement. The other way is to remove the outer tie rod and gently push and pull the adjustment bar into the rack/pinion, checking for play. I had some play both ways.
  19. Jul 28, 2022 at 1:27 PM
    TACOMA2NDGEN
    ROLAND
    new jersey
    baja squadron pros
    No I just know that brembo makes good shit
  20. Jul 28, 2022 at 1:30 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Next time you regrease (oil change) just push red n tacky until you see it coming out.
