Brass compression fittings on PVC air line?
Discussion in 'Garage / Workshop' started by bigmooze, Nov 2, 2010.
  1. Nov 2, 2010 at 5:03 PM
    bigmooze
    bigmooze [OP] Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Need some advice from the TW community:
    Can brass compression fittings be used to couple 1/4" diameter PVC air line, such as that used for air bags?
    For me, these are more readily available than the push-to-connect types.
    The lines could be pressurized up to 150 psi (bags will not be operated at this pressure, however).
  2. Nov 3, 2010 at 2:28 AM
    bigmooze
    Richard
    Belle River, ON
    Bump, anyone?
  3. Nov 3, 2010 at 5:57 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    What will be the normal pressure?
    Brass compression fittings are used all the time in household plumbing.
  4. Nov 3, 2010 at 6:14 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    You will need the correct compression farrels and inserts to keep the plastic from crushing.
    That being said
    i do not like PVC used in compressed air systems.
    Many do and have no problems, BUT not good.
  5. Nov 3, 2010 at 6:14 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    I've seen people use both types of fittings on air bag setups.
  6. Nov 3, 2010 at 6:16 AM
    macgyver
    Brad
    Canton, GA
    Whats the matter...are you skurred?
  7. Nov 3, 2010 at 6:21 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2 It's not PVC pipe, it's PVC air line. It's designed for air pressure. I've probably got thousands of feet of it out on my manufacturing floor.
  8. Nov 3, 2010 at 6:26 AM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    YES indeed, PVC does not like hydrocarons ( oil from compressor or ? )
    It also becomes very brittle in sunlight or UV rays.
    As the temp goes up the pressure rating drop very quickly.
    Compressors produce very hot air and many introduce oil into the compressed air.
    Pipe can fail and schrapnel will fill the air.
    Air lines for bags are a different plastic I think.
  9. Nov 3, 2010 at 6:30 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    You can use them. Some people prefer to use compression fittings over push to connect because they claim it gets a better seal. On my s10 I have used both compression and push to connect and they both work good.
  10. Nov 3, 2010 at 6:46 AM
    bigmooze
    Richard
    Belle River, ON
    Thanks for all the replies, I'll see how it works out and report back.
  11. Dec 14, 2010 at 9:20 PM
    R6Racer
    R6Racer Member
    Ontario Canada
    03 PreRunner
    PVC & Air pressure lines = EXTREMELY BAD
    Don't do it.
    PVC is NOT designed to hold compressed air.
    Any one who has told you it's OK to use for air is badly mistaken!
    There are lots of materials you can use for air lines but PVC is one to most definitely stay away from! If you have it in, take it out!!!
    There is no such thing as PVC air line.
  12. Dec 14, 2010 at 9:44 PM
    R6Racer
    R6Racer Member
    Ontario Canada
    03 PreRunner
  13. Dec 15, 2010 at 8:21 AM
    98tacoma27
    Ben
    Not Beech Creek
    We are talking tubing, not pipe. You're comparing apples to oranges.
  14. Dec 15, 2010 at 8:36 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    we have PVC pipe running off our compressor in our basement and its routed under the floors and into the walls to our garage. Haven't had a problem in 5+ years of having it installed. Our system is 125lbs or less.
    I wouldn't use the brass comprssion fittings (with furls,etc) on PVC.
    Use regular threaded pipe fittings, and quick disconnects (if possible). Nothing wrong with the nylon quick pushloc fittings.
  15. Dec 15, 2010 at 8:43 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    I don't think people understand Ben, try another approach..
    Option #1 above, is what is used at work. We have miles of it on reels.
  16. Dec 15, 2010 at 8:45 AM
    98tacoma27
    Ben
    Not Beech Creek
    Can't, I keep losing brain cells.
  17. Dec 15, 2010 at 4:07 PM
    R6Racer
    R6Racer Member
    Ontario Canada
    03 PreRunner
    OOPS
    Sorry , my mistake! :sorry:
    Had a friend get hurt when a PVC pipe that was being used as an air line blew. He was almost 40 feet away & he ended up with a few stitches from it. Could have been MUCH worse! Janster the system that injured my buddy was only 130psi!
    Wouldn't wish that on anyone.
