Brass in oil and Metal
Discussion in 'New Members' started by MatthArper26, Apr 21, 2013.
  1. Apr 21, 2013 at 4:50 PM
    MatthArper26
    MatthArper26 [OP] Active Member
    Poca w.v.
    2010 tacoma trd
    3in toy tec lift magnaflow off road pro series exhaust, airaid jr cold air intake system, poweraid throttle body spacer
    I changed my oil in my tacoma trd and there was brass and metal in the bottom of the pan it only has 52,000 on it and it is a 4.0L should I be warred or is this norm wear. this is the first gas truck for me in years and toyota
  2. Apr 21, 2013 at 4:53 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    "brass and metal" in the oil in a visible amount is a sign of imminent failure.
  3. Apr 21, 2013 at 4:56 PM
    MatthArper26
    Poca w.v.
    2010 tacoma trd
    It don't sound bad when it is running or driving down the road and has good power
  4. Apr 21, 2013 at 4:57 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    bearings?
  5. Apr 21, 2013 at 4:57 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    where would brass come from? :confused:
  6. Apr 21, 2013 at 5:21 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Is it actually brass or just brass colored?
  7. Apr 21, 2013 at 5:25 PM
    MatthArper26
    Poca w.v.
    2010 tacoma trd
    It's small pieces of brass
  8. Apr 22, 2013 at 10:31 AM
    OffroadToy
    I'm far from a expert but it seems to me the only place you'd find brass is in the bushings of a elec starter.
  9. Apr 22, 2013 at 10:40 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Most internal bearings like Rod/crankshaft/cam have a softer under layment of brass or copper IIRC... At least thats what I used to see when breaking down a smoked engine...
  10. Apr 22, 2013 at 11:06 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    1) get a used oil analysis immediately to determine the actual metals
    sometimes they can zero in on the actual part (engines have specific metals at specific
    hardness at specific locations, UOA can tell you exactly what part)
    2) do not drive, or risk severe engine damage
    3) if under warranty, bring it in asap
    tiny metal flakes are OK if the vehicle is brand new, but a 2010 should have zero
    visible metal anything in the oil
