Break away brakes with brake controller?
Discussion in 'Towing' started by iitywygms, Jan 2, 2015.
  1. Jan 2, 2015 at 2:56 PM
    iitywygms
    iitywygms [OP] Well-Known Member
    Norcal
    4x4
    Hi All:
    Picking up a small rv tomorrow. 14 footer.
    Person selling it says it has break away brakes only.
    Question. Can I use a brake controller with the current brakes on the trailer or will I need to install different type of brakes on the trailer?
  2. Jan 3, 2015 at 8:47 AM
    KVJ
    KVJ Active Member
    Kenny
    Bristolville,Ohio
    2015 TRD sport
    Raptor style grill
    Break away switch operates off a battery mounted on the trailer with a cable attached to the TV. If it weighs less than 2000# you can pull it home and figure it out from there. Check the laws in your state for brakes and break away switch requirements before driving too far.
  3. Jan 3, 2015 at 10:25 AM
    iitywygms
    Norcal
    4x4
    Break away brakes are electric correct? If that is true, then I should be able to use a brake controller correct? The trailer has a seven pin connector if that is any clue.
  4. Jan 3, 2015 at 10:29 AM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    Should be able to link up, breakaway is usually part of a whole brake system, as a safety feature.
  5. Jan 9, 2015 at 10:01 AM
    Indy
    Indy Master of all I survey.
    Surge brakes also have breakaway features. If the trailer comes away a pin gets pulled and applies the brakes.
  6. Jan 10, 2015 at 3:47 AM
    KVJ
    KVJ Active Member
    Kenny
    Bristolville,Ohio
    2015 TRD sport
    Raptor style grill
    To answer IITYWYGMS question in post #3.
    Think about this: If the trailer breaks loose, the TV plug will will disconnect. Thus no power to activate the brakes. See my first post, Break away switch operates off a battery mounted on the trailer with a cable attached to the TV. This is a separate battery like one on an RV travel trailer. Go to etrailer.com they have videos of installing them. I think your confusing a breakaway system with regular TV controlled braking.
