Break-in Period
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aw9d, Nov 28, 2011.
  1. Jan 11, 2018 at 11:19 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    I will agree with part of this; however, you have to remember that everything on the truck is brand new. This includes the trans, diffs, etc... I personally don’t think engines need breaking in because of the precise tolerances and maching have come a long way. Ask ECGS about break in when you order a diff from them, they have. A specific way to do it by varying rpms and speed.
    PackCon[QUOTED] likes this.
  2. Jan 11, 2018 at 12:05 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Disagree with your math. Two decades means your last sentence should be "It's not 1998 anymore."
  3. Jan 11, 2018 at 12:07 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    ...The comments don’t need to line up mathmatically...
    Both were independent statements.
  4. Jan 11, 2018 at 12:10 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Look up GM or Ford crate engine break-in proceedures.
    Heat cycling of all of the different components is a necessary step. Step RPM loading. Positive and negative loading of the engine.
  5. Jan 11, 2018 at 1:42 PM
    EnonEye
    EnonEye Well-Known Member
    David
    O-H-I-O
    Silver '06 DCSB TRDPreRunner Off-Road/ Tow package
    yea that 1,000 mile no-towing part on the break-in was tough. Took me all night that 1st night to get that 1,000 miles out of the way
