Break In
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FastPace, May 23, 2015.
  1. May 23, 2015 at 3:53 AM
    FastPace
    FastPace [OP] Well-Known Member
    Pete
    Mississippi
    Hey guys,
    So I've been driving my new 2015 Tacoma like how I normally drive it, as the general consensus is the engine comes already broken in. However, I have varied the RPM's whenever I can and try not to push it too hard.
    I have two questions I was hoping y'all can help.
    1. When do you recommend the first oil change and switch to synthetic? From searches, its somewhere between 3k-5k?
    2. Is there anything else I need to change? Some say differential fluid and some say don't. Anything else?
    Thanks millions
  2. May 23, 2015 at 4:00 AM
    ThorInc
    ThorInc Active Member
    Synthetic should not be used until the engine is fully broken in. My opinion would be not until at least 10000 miles but change the oil using non syntethic at recommended cycles until then.
  3. May 23, 2015 at 4:05 AM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    I've got about 1300 miles on mine. I always do the first oil change early to get any garbage out. Since I'm taking a little bit of a road trip next Friday, I plan to change the oil before I leave
  4. May 23, 2015 at 4:45 AM
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    Unless I am going to do some heavy duty use such as serious off roading are towing a heavy trailer I plan to follow the Owner's Manual recommendations in my 2015.
    At about 30,000 I will probably switch to synthetic in the engine, differentials, and transfer case .
    Not likely that I will do what many consider heavy duty off roading or towing.
  5. May 23, 2015 at 5:20 AM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    My truck had synthetic oil from the factory. Has been serviced at the dealership every oil change since i've owned it. It has synthetic oil put in every time. I see that some believe in a "break in period" for synthetic oil and don't agree.
    Oil in its natural state is random in its molecular make up. So it doesn't bond to the metals in the engine as easily. Yet, has an ability to remain "thicker" during natural wear and tear of an engine. It can potentially leave some part of the engine exposed to excessive wear and tear in some cases.
    Synthetic oil is man made and created to evenly bond on the metal parts of the engine. This thinner coat of oil allows the engine to move freely providing a more "efficient" engine. It will also allow the engines wear and tear to evenly break down in comparison to standard oil.
    Note: I have the 2.7l, so maybe the 4.0's have a different call on oil, but what i've stated about the oil(s) are still the same.
  6. May 23, 2015 at 5:41 AM
    Clearwater Bill
    Billy
    Largo Florida
    The 2.7's come from Toyota with syn. So do Corvettes, Mercedes, Porsches as well as various models of other marquees.
    Maybe the wives tale files need refreshing?
    To the OP. I'd ask why you want to change to syn? Are you aiming to take advantage of proven longer OCIs, like in the 10k range? If not, for your described use of the vehicle, syn would bring you no benefit, other than lightening you wallet.
  7. May 23, 2015 at 6:13 AM
    Harley2
    Harley2 Well-Known Member
    Rick
    Vermont
    15 Super White Double Cab 4x4
    I went Synthetic at first oil change 1500 miles. I also varied speed but included some good hard brief accelerations in the first 500 miles. It forces the piston rings against the cylinder walls for an oil tight break in. Different opinions here from everyone but that's what I do with my vehicles and my Bikes. Never had an engine that used oil or did not exceed 100,000 miles with no issues at all!
  8. May 23, 2015 at 9:00 AM
    FastPace
    Pete
    Mississippi
    Thanks guys!
    So I guess changing the oil at every 5k and differential at 15k is regular maintenance? Everything else is the 30k, 60k, etc. service, right?
  9. May 23, 2015 at 9:17 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    A lot of people push synthetic oil change intervals a little further. I change mine every 10K miles or so. Maintenance intervals are in your owners manual if you are in doubt. As far as engine break in goes, I bought my truck in Germany and it was on the Autobahn for it's first tank of fuel, held wide open for several hours. 10 years later, it still runs great. I think with modern engines break in is over rated, and they get ran at the factory anyhow. Now, an old school 350 V-8 is a different story.
  10. May 23, 2015 at 9:33 AM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    consider it already broken in and change the oil twice a year. :playball:
  11. May 23, 2015 at 10:33 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    do a first break in oil change at 2k then another at 5k, then every 5k after that..... oil type does not matter (syn or dino)
    Open that bitch up too, seat those rings!
    Also CHANGE YOUR REAR DIFF AT 5k.... its going to be NASTY
  12. May 23, 2015 at 10:41 AM
    4x4Active
    4x4Active Well-Known Member
    Saltwater Texas
    '13 Taco DC OR 3" lift stock rims on 33s
    Switch to synthetic when toyota care is done.
  13. May 23, 2015 at 10:52 AM
    nd4spdbh
    SoCal
    dont use toyota care..... watched them almost start my truck without oil in it....
  14. May 23, 2015 at 11:03 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Change it at 5,000 or whenever you want before that.
    I don't think it really matters how or when you change to synthetic. It won't hurt anything.
    Whether or not you still have 'fine particulates' left over from break in - you'll catch them on the next oil change. Every break-in is different depending on how you drive, etc. You could still have 'breakin' materials many many oil changes later.
    I changed mine at 2700 miles. No particular reason....other than, I knew I didn't want to wait till 5,000 and I had time in my work schedule to do it. I've been putting Mobile 1 in it ever since.
  15. May 23, 2015 at 11:08 AM
    Janster
    Jandy
    Lancaster, PA
    Look in your owners manual.
    Differentials are at 30K (front & rear plus Tcase) - at least, that's what it is for my 07.
  16. May 23, 2015 at 11:17 AM
    PeeDeeComa
    PeeDeeComa Well-Known Member
    Florence, SC
    2015 PreRunner SR5
    I don't worry about stuff like that.....its covered if they do something stupid like that.
  17. May 23, 2015 at 11:19 AM
    PeeDeeComa
    Florence, SC
    2015 PreRunner SR5
    Agree
  18. May 23, 2015 at 11:41 AM
    nd4spdbh
    SoCal
    ok, w/e floats your boat.
    Does not sit well with me if they start my truck without oil... run it for a bit and realize... oh shit, put oil back in it... and never tell you, cus thats what would of happened had i not been standing watching my truck as work was being done on it.
  19. May 23, 2015 at 11:51 AM
    ThorInc
    Maybe they are already broken in by the factory.
  20. May 23, 2015 at 11:58 AM
    PeeDeeComa
    Florence, SC
    2015 PreRunner SR5
    Wasn't trying to make it sound like a smart a$$ comment or anything like that. I was just implying holding the service department accountable if they screw up. In your case....that wouldn't sit well with me either but if its on the dealership....then pretty much you have them by the balls.
