Break Line Replace/Bleeding?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tac_99, Sep 5, 2019.
  1. Sep 5, 2019 at 1:07 PM
    Tac_99
    Tac_99 [OP] Well-Known Member
    Anthony
    99 Toyota Tacoma TRD
    *Brake*
    So today I noticed slight cracking on the front break lines of my 99 prerunner.
    Break system has been flushed not too long ago as I had rear axle seals replaced and rear drum breaks completely rebuilt break cylinders and all. SO break fluid is for sure pretty fresh still.
    I have flushed and bled break fluid on my street bike before which was very easy.
    MY QUESTION
    If I remove just the front rubber break lines and ensure the master cylinder doesn’t get too low... Do I need to bleed the entire system including the rears or can I just bleed front Passenger then driver and should be good? I’m curious about this?
  2. Sep 5, 2019 at 3:06 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If the level in the Master cylinder drops to the piston level it will suck air
    In theory it should work My luck is never that great
    cruxofthebisquit and GQ7227 like this.
  3. Sep 5, 2019 at 4:11 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    As long as you don't let the level get too low, yeah you should technically be fine.
    In practice, however, this almost never happens (at least for me) because there's that *one time* you go one pump too many and the fluid dips too far.
    Might as well just prepare yourself for a complete re-bleed, lol...
    GQ7227 and CS_AR like this.
  4. Sep 5, 2019 at 4:12 PM
    eon_blue
    Azusa, CA
    When I replaced my brake lines I hardly lost any fluid and I still had to bleed the system because air got into it. Same thing when I replaced my banjo bolts, had to bleed it afterward. I would count on having to bleed it, it's not that hard to do and it's better to be prepared for it than not.
    If you bleed the brakes its best to do all 4 corners...start furthest away from the master cylinder and work your way to the front.
  5. Sep 5, 2019 at 4:34 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Did your old line look like this? I just replaced both front lines last weekend on my 99 Prerunner. I've got another line coming to replace the rear line.
    I figured it was time to replace 20 year old lines.
    GQ7227 likes this.
  6. Sep 5, 2019 at 4:36 PM
    jbrandt
    Justin
    While that is just a protective rubber coating on the outside of the line, that's still pretty bad.
  7. Sep 6, 2019 at 11:23 AM
    Tac_99
    Anthony
    Yeah, I would def make sure it didn’t.
    I’m just wondering if I put the new lines on and start the bleed from the rear, would that air in front some how be pushed to the rest of the lines creating a lot of extra bleeding needed to be done At the rears as I work my way to the fronts.
    I may just wait until I do the entire suspension and add the rear extended break line and do it all at once.
    Yeah mine look pretty similar. Maybe not as bad, because they aren’t being bent like that pic and showing as much cracking, but definitely showing signs of cracking after 20years and almost 240k miles.
  8. Sep 6, 2019 at 11:33 AM
    jbrandt
    Justin
    I think we have a winner right here.
    :thumbsup:
    Wyoming09 and Tac_99[QUOTED][OP] like this.
