Break override malfunction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Flohick, Jun 27, 2022.
  1. Jun 27, 2022 at 7:17 AM
    Flohick
    Flohick [OP] Member
    Tyler
    17 trd OR
    I have 17 trd or I had a blown fuse and i replaced it now it just turns over and want start
  2. Jun 27, 2022 at 7:24 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    We need more info, what fuse? why did it blow? what were you doing before it blew? how many miles? what mods?
    Chew likes this.
  3. Jun 27, 2022 at 8:03 AM
    Flohick
    Flohick [OP] Member
    Tyler
    17 trd OR
    It was the 10a stop fuse that was under the hood, I was just driving down the road when I Noticed that I had a break override malfunction light on. So I turned the vehicle off and then it would not even try to turn over so then I found that the 10A stop fuse was blown so I replaced it and now it just turns over but will not start where before it wouldn’t even turn over with the blown one.. i have led taillights
  4. Jun 27, 2022 at 8:07 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Without any more information than we have at hand, I'd be looking for a second blown fuse. At the end of the day you're going to need to find out what caused the fuse(s) to blow in the first place. No one can tell you that with the information, or lack thereof here.
    Chew likes this.
  5. Jun 27, 2022 at 8:14 AM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    How long ago did you do a DIY mod like LED taillights?
    Chew likes this.
  6. Jun 27, 2022 at 8:16 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    There you go. LED taillights the culprit . There may be other fuses involved . This is a screenshot from tha MAN himself explaining why it happens with some led taillights. 3E062BC1-FEBD-4186-A776-DF5E0AD8337D.jpg
  7. Jun 27, 2022 at 8:24 AM
    Flohick
    Flohick [OP] Member
    Tyler
    17 trd OR
    I replaced the taillights about 5 months ago everything has been fine till yesterday
    FloridaFree likes this.
  8. Jun 27, 2022 at 9:49 AM
    Sierrahunter
    Sierrahunter Well-Known Member
    2022 SR5 Double Cab Long Bed 4x4
    This just happened to me as well. Dealer blamed the third brake light on my camper shell. Seriously stupid.
  9. Jun 27, 2022 at 9:51 AM
    cybrnook
    cybrnook Well-Known Member
    SE Michigan
    2022 TRD Off-Road Manual Transmission
    That's typically how things break when they go... It's great.... until it's not.
  10. Jun 27, 2022 at 10:06 AM
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    This make me nervous with my total tail v2 installed.
  11. Jun 27, 2022 at 10:26 AM
    Raijin822
    Raijin822 Well-Known Member
    Canada
    2021 TRD OR
    This was actually me that had the issue.
    Just replace the 10A fuse, and push down on ALL your fuses. The fuses on my truck in the engine bay were actually not all seated properly from factory.
    I have the total tails from Meso and since I replaced the fuse and made sure everything was seated properly, never had an issue again.
    bulalo[QUOTED] likes this.
  12. Jun 27, 2022 at 10:35 AM
    Flohick
    Flohick [OP] Member
    Tyler
    17 trd OR
    After I replaced the 10a fuse it just turns over but won’t crank
  13. Jun 27, 2022 at 10:39 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    To be clear the truck cranks (the starter turns the engine over), but the engine will not start?
    Is the CEL on? Is the security 'key' light on? Do you have access to a scan tool to check for codes?
  14. Jun 27, 2022 at 10:40 AM
    Raijin822
    Canada
    2021 TRD OR
    Hard to say what happened to your truck, maybe check all your fuses? Sounds like something else might have blown. Disconnect the battery while checking and replacing the fuses in the cab and bay.
    Wish I could help you ID exactly what is wrong but im just here behind a computer and not in front of your truck.
  15. Jun 27, 2022 at 10:44 AM
    Flohick
    Flohick [OP] Member
    Tyler
    17 trd OR
    Yes that’s correct the starter is turning the Motor but will not crank. I have a video but it it want let me upload it
  16. Jun 27, 2022 at 10:58 AM
    tirediron
    For ease of future discussions, 'cranking' is normally used to refer to the action of the starter-motor turning over the engine; the way your post reads, it sounds like the starter-motor is turning but the engine is not, as opposed to the engine turning, but not igniting.
    gudujarlson, jmneill, bulalo and 3 others like this.
  17. Jun 27, 2022 at 1:53 PM
    Flohick
    Flohick [OP] Member
    Tyler
    17 trd OR
    Did it blow a fuse?
  18. Jun 27, 2022 at 3:06 PM
    TRD-Troll
    NV
    2019 TRDOR DCSB AT
    Oh damn he is an ARFCOMer. Didn’t notice that before.
  19. Jun 27, 2022 at 3:22 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Me too! I just installed the total tail stage 1 kit about 2 weeks ago. Everything went great and didn't even need resistors. This is the first time I've read of an issue like this, but the OP replaced the entire tail light with a non-Meso tail light, so I'm hoping I won't have the same issue down the road. OP I hope you are able to resolve your issue.
    Flohick[OP] likes this.
  20. Jun 27, 2022 at 5:18 PM
    FloridaFree
    FloridaFree Well-Known Member
    TRD OffRoad 4x4 mgm
    OME 887 with nitro chargers, icon add a leaf ECGS bearing former 886
    is that osceola?
    good luck with finding out whats wrong
