Break pedal pressed=turn signal ind. on
Discussion in 'Technical Chat' started by roka666, Jun 1, 2010.
  1. Jun 1, 2010 at 10:51 AM
    roka666
    roka666 [OP] New Member
    Seattle, WA
    Tacoma 4X4 2.7L
    3" spacer lift, 3"body lift
    Hey everyone First post! whoohoo! so basically when I press the brake pedal, my right side turn signal in the rear comes on with the break light and holds steady(no flash) and the indicator lamp will turn on steady and dim...the right turn signal works normally when driving until I depress the brake pedal the turn signal indicator lamp will stop flashing and hold on steady and everything operates as described above, the signal will return to normal operation once the pedal is not depressed. I did wire my truck about 6 months ago for towing but have had no issues until a couple of days ago. Does this sound like a ground or crossed wire issue or is it an indicator of some more specific like a relay or something. Thanks for any help on this!
  2. Jun 1, 2010 at 10:54 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    if you rewired it for towing and the problem did not start right away, i'd say that some electrical tape came off and your turn signal and brake light power are touching one another. or something along those lines
  3. Jun 1, 2010 at 11:09 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    x2
    check all your connections from your wiring job and Im sure you will find the culprit
    and welcome to TW :thumbsup:
  4. Jun 1, 2010 at 5:50 PM
    roka666
    Seattle, WA
    Tacoma 4X4 2.7L
    cool... I was thinking that was probably the problem, just wanted to make sure it wasn't some sort of Toyota code for a bulb out in my glove box or something:D thanks!
