Breakin oil n oil changes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taquitoqvola, Jul 9, 2018.
  1. Jul 9, 2018 at 11:45 AM
    Taquitoqvola
    Taquitoqvola [OP] Well-Known Member
    2018 TRDORDCSB MT QUIKASFKSAND
    Put about 600 miles. Lots of up n down on the tach & spedo.. im used to dumping out the oil min 1000 miles but ive also dumped earlier on vw 8v builds and 1nzfe engine redos just to see whatsup really.. they both continue to run like tops. Specially the old vw 8v, but this aint the place for that!
    Taco manual says to wait to change till first scheduled yadayadayada..
    How did u guys do it?
    Hows your sht runnin?
    Did u run the 4x4 for a mile at least to get stuff all greasy in the diffs. Did u dump this stuff out?
    What oil/fluids did u replace with. Do u guys use the mobile1 stuff that needs its own special filter? Runnin wallyworls special oil?
    Talk to me! Specially interested in hot temp tacs. Im in soflo.
    Thx again!
    Btw i love this fkntruck..
    Jcyr likes this.
  2. Jul 9, 2018 at 11:49 AM
    Mod fan
    Mod fan Well-Known Member
    Just changed mine for first at 5500 next oil change I’ll be putting on the Baxter performance spin on filter adapter. Factory setup sucks imo
  3. Jul 9, 2018 at 11:54 AM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    Unless you got extra money laying around and it'll make you sleep better at night, the guidelines in the manual are proven to be good to go.
  4. Jul 9, 2018 at 11:56 AM
    Mod fan
    Yup plenty of extra 30 dollars here and there not a problem, keeping this truck, treating it right
    cshrum likes this.
  5. Jul 9, 2018 at 12:00 PM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
  6. Jul 9, 2018 at 12:14 PM
    Mod fan
    Yeah that original plan of yours sounds overkill...just me but once I buy my cars they won’t see the dealer unless something catastrophic happens. One trip to buy at the dealer is enough lol
    dhectorg and michaeln like this.
  7. Jul 9, 2018 at 12:18 PM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    :deadhorse:
    oil changes before the service schedule are not needed unless you're operating in special heavy use circumstances which the manual calls out oil changes at 5,000 intervals.
    any sooner and you're throwing away money. This isnt an engine from 20-30 years ago. internal tolerances, metallurgy, and oils have all changed greatly. throw out the old mentality of frequent oil changes and get with the new norm of 10,000. Its been proven by numerous oil tests posted here its fine and toyota wouldn't risk their reputation of reliability on saving you a couple of oil changes.
    HutchJ, Sig45, suaveflooder and 3 others like this.
  8. Jul 9, 2018 at 12:20 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Your "hot" ambient temperature has no real importance in this vehicle as the oil is synthetic 0W-20. The viscosity index is of this oil is extremely flat whether you are in Alaska in the winter or Baja in the summer. You also have no need to change until 10K miles because A) this is not the 1970's and B) they build around 50K of these engines a month. There is no break in, there is no "what's up" with this engine. They run them, drain them and refill them before they ever get put in the truck, which is why they are so damn dependable. You get in and drive til 10K. Toyota probably has a little bit better assembly and process than you do lol. There are many many oil sample reports floating around here from Blackstone from guys like you that show the oil is just fine for 10K oil change intervals. If you are smarter than the engineers who designed it then change it out whenever you "feel" like it. Diffs are good for a long time. Rear shaft is sealed. Transmission is sealed on the auto. Run it a few miles every month is 4WD to keep the actuators from sticking. Welcome to Tacomaworld!
    HutchJ, JoeCOVA, cwdog and 1 other person like this.
  9. Jul 9, 2018 at 12:23 PM
    TelosHedge
    TelosHedge tiny moron
    Central NC
    18 Inferno Sport DCSB 4x2
    While I am no master mechanic this post is most likely to be accurate based on actual posted test results from owners, and of course, Toyota's track record for figuring out how to make engines last a very long time.
    If you want some middle ground and piece of mind maybe I'll tell you to change your oil on your own but leave your filter in for the full run of 10k. That'll save you some coin (and some annoyance of dealing with this silly filter) and still let you sleep better at night.
    As for me? 10k.
  10. Jul 9, 2018 at 12:27 PM
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    i changed my engine oil at 1000 amsoil changed all my diff and transmision tranfer case at 5000 with amsoil bought it new in 2012 allways changed oil at 4000 miles and done my diffs every year now showing 202000 never had any issues 2.7 with 5 speed
    RykerTaco and The hammer like this.
  11. Jul 9, 2018 at 12:28 PM
    Taquitoqvola
    Hipsi.. all noted. I will say that everytime i turned the key on those rebuilds i was crappin my pants that sht wouldnt run right.. cause at best..Amateur shadytree w a permanent structure, over here.lol.
    Thanks for chiming in guys.. it aint the 70s no mo!
    Thx for the welcome!
    Did i mention that love this fkn truck???
    The hammer, InfernoTonka and hiPSI like this.
  12. Jul 9, 2018 at 12:29 PM
    Taquitoqvola
    Man thats what i like to hear. Thx for sharing!!
    RykerTaco likes this.
  13. Jul 9, 2018 at 12:30 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Have you ever heard of a failure caused by an oil brand? All well known brands are just fine. Please don't fall for marketing hype.
  14. Jul 9, 2018 at 12:36 PM
    Mod fan
    100 % agree especially under normal conditions my local Napa had Napa brand full synthetic on a 3 day sale 2.99 unheard of price full synthetic made by valvoline
    hiPSI[QUOTED] likes this.
  15. Jul 9, 2018 at 12:39 PM
    Taquitoqvola
    Big fan of napa gold and napa/valvo on the cheap. I run it in errything i can
  16. Jul 9, 2018 at 12:40 PM
    Mod fan
    Yessir Napa gold is wix great stuff
    phsycle likes this.
  17. Jul 9, 2018 at 12:44 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I usually get the Mobil 1 from Wal-Mart too and then do the $12 Rebate they offer a couple times a year
    EdgeCrusher likes this.
  18. Jul 9, 2018 at 12:46 PM
    BSFord
    2018 TRD Sport 4x4
    Great tip, I'll watch out for that!
  19. Jul 9, 2018 at 12:47 PM
    Taquitoqvola
    On all my builds and beaters i get starters, compresors, whatever from them, they always swap for me on the spot, or have the exact thing i need next day in most cases. Good group /outfit. They like cars.
  20. Jul 9, 2018 at 8:05 PM
    Bean&CheeseTaco
    Bean&CheeseTaco Well-Known Member
    Did first oil change at 1500 miles with Mobil 1 Synthetic & oem filter of course, next change was at 5,000. I’m sure you’d be fine waiting until service is due, but I like to be meticulous with servicing.
    BSFord likes this.
