Breaking clank noises
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MenDriveTrucks, Dec 18, 2014.
  1. Dec 18, 2014 at 6:42 PM
    MenDriveTrucks
    MenDriveTrucks [OP] Member
    2014 Tacoma DBL Cab 4x4
    49K miles
    level Kit
    2" alum wheel spacers
    So this past month I've been hearing a clank noise sometimes when I brake. Doesn't happen all the time so I was curious about it. Called the dealer and they told me most likely the brakes are wearing down. He said the calipers adjust themselves now and then especially when you switch from reverse to drive.
    I've also noticed my front end vibe is getting stronger and some slight tire scouping. I don't recall hitting any massive bumps that would have thrown my alignment off. Just odd that both of these started to happen at the same time. So I'm curious if anybody else has heard this clank when their brakes start to wear down.
    I know dealers charge an arm and a leg for service so any recommendations for getting this work done cheaper in Phoenix AZ?
    Thanks
  2. Dec 18, 2014 at 7:26 PM
    SxSW
    SxSW Well-Known Member
    Joe
    NM
    14 Base
    Check the wheel bearings.
  3. Dec 18, 2014 at 8:09 PM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    It's Prob the brake pads slapping in the calipers. Normal. You can add the spring and stop them from making the slap sound. Do a search it's common.
  4. Dec 18, 2014 at 10:01 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Most all time the "clank" from the brakes will be right after you go from Reverse to Drive, or Drive to Reverse. The brakes "free float" for lack of a better term in the caliper. The noise has to do with the position the pads are in at the time you hit the brake. This is normal.
    But if you hear it multiple times while braking in ONE direction you should look into the problem further.
    I have found the degree at which the brakes are worn to have no effect on the noise being heard more often or any louder. So I can't say that worn brakes cause this issue.
  5. Dec 24, 2014 at 2:51 PM
    kavahawaii
    kavahawaii Member
    Hawaii
    06 PreRunner
    none
    My 06' has been doing it since it was new. It's just the pads shifting forward until the hit the stop. 90,000 miles and nothing has changed
