"Breaking in" your Brand New Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NosiBaLasi, Aug 22, 2014.
  1. Sep 9, 2014 at 8:05 PM
    #61
    NosiBaLasi
    NosiBaLasi [OP] RESULTS, not excuses
    Jones
    Home of 1st Marine Expeditionary Force
    IG: overlandhd & tacoma_2gen_hq
    All in "My Build" page
    Recommend 1st oil change at 1500 mi then every 5kmi.
  2. Sep 9, 2014 at 8:21 PM
    #62
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Why 1500?
  3. Sep 9, 2014 at 8:24 PM
    #63
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Because that's 100 less than 1600 (which is 100 times 16) with 16 being equal to the number of quarts multiplied by the type of oil (2 cycle or 4 cycle) oil that you use. :rolleyes:
    2 Cycle oil only lasts 1/2 as long so you have to double it up and use 8 quarts instead of the 4 quarts you would normally use with 4 Cycle oil. Geez everybody knows that.
    Here is how to calculate it: 2 Cycle and 8 Quarts give you the number 28. 28/4 = 7
    Now, if you take 4 quarts of 4 Cycle oil you have the number 44. when you divide 44 by 6 (for V6 engines) you get 7 with a remainder of 2. This remainder of 2 indicates this oil will last twice as long. :D
    I say just wait for the oil light to come on, that way you'll be sure to get your Tacoma "Broken" :eek:...er ah.....I mean "Broken in" :rolleyes:
  4. Sep 9, 2014 at 8:50 PM
    #64
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    There's an oil light?
  5. Sep 9, 2014 at 8:53 PM
    #65
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    I think there is. :confused:
    I guess the best way to see is to drain all the oil out, and run the engine until you see a light turn on. :rolleyes:
  6. Sep 9, 2014 at 10:33 PM
    #66
    Spaghettiohead
    Spaghettiohead Member
    Andrew
    Alaska
    '14 DC Off-Road
    You're a fool to not change factory oil around 1000 miles. The metal parts are still wearing-in and the cylinder walls are being worn by the seating rings. Changed mine at 300 miles and the oil glistened in the sunlight...nothing but metal. Changed it again at 1300 with Amsoil and it came out looking like oil. I would NEVER have that amount of metal flowing through my engine for 5K miles as the stealership would have you do!
    Also changed the diff/tranny fluids at 1300 miles and same thing. First suggested service at 30K? Yikes.
  7. Sep 9, 2014 at 10:37 PM
    #67
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Metal?.......Wow you use mercury to lube your engine? :eek: That doesn't sound very environmentally friendly. :rolleyes:
  8. Sep 9, 2014 at 10:39 PM
    #68
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    LOL! Did Toyota forget to install the oil filter on your truck?
  9. Sep 9, 2014 at 11:39 PM
    #69
    Jimmyh
    SC
    2012 Prerunner SR5
    What is a seating ring? I have never heard of a " Seating " Ring before.
    Compression Rings - yes, Scraper Rings - yes and Oil Control Rings - yes.
    Seating Ring - No.
    I am thinking that you meant that the rings are still seating. Maybe, but I think that has happened already at 300 miles. Probably a lot sooner.
    If you had metal that was visible in your oil after 300 miles. You have other problems.
  10. Sep 10, 2014 at 4:22 AM
    #70
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    THIS.
    I have seen the testing facilities at the engine assembly plants where they do their testing. Every engine is connected to a test stand, automatically filled with coolant, and connected to fuel and power. They run the shit out of the engine with load/no load rev up/down, everything. It is intended to seat the rings and do any necessary break-in. In addition, if anything is going to fail on the engine due to manufacturing defects, that is when it will fail. The tests are designed that way. There are occasionally some that get by though and those are a big deal to the manufacturer and the engineers that designed the test.
    That being said *I* wouldn't drive it like I stole it off the lot. I was told 2 weeks ago to not use the cruise control for 500 Miles... :rolleyes:
  11. Sep 10, 2014 at 4:44 AM
    #71
    shotgunshooter3
    shotgunshooter3 Well-Known Member
    Somewhere in the Southwest
    2025 DCLB TRD OR, Blue Crush Metallic
    Mud flaps
    I broke mine in by driving from Lubbock TX to Enterprise AL, though I did avoid high RPM's (over 4k) for the first 5K miles or so.
  12. Sep 10, 2014 at 5:01 AM
    #72
    Large
    Large Red
    I see this turned in to a troll fest pretty quick.
    There's quite a difference in the mfg process between 1958 and 2014.
    95% of maintenance quesions can be answered by reading this, but the posts keep coming on a daily basis :confused:
    Where did you find this info?
  13. Sep 10, 2014 at 10:10 AM
    #73
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Trolls? aw, that's precious.:rofl:
  14. Sep 10, 2014 at 10:14 AM
    #74
    Large
    Large Red
    It's hard to have a discussion with people like you on this site.
    :pccoffee:
  15. Sep 10, 2014 at 10:32 AM
    #75
    Spaghettiohead
    Andrew
    Alaska
    '14 DC Off-Road
    Jimmy, sorry I wasn't clear - I did mean the rings seating against the cylinder walls.
  16. Sep 10, 2014 at 10:33 AM
    #76
    Spaghettiohead
    Andrew
    Alaska
    '14 DC Off-Road
    Dang! That must be it...
  17. Sep 10, 2014 at 1:45 PM
    #77
    Large
    Large Red
    You're more likely to wreck it before it will ever reach that.. I mean you are talking about a car that is almost 60 years old not some that are a few years old. There have been a few articles I read about million mile vehicles, volvo, a chebby, a couple of toyota vans from the 80s-90s.
  18. Sep 10, 2014 at 3:37 PM
    #78
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    If you look at the majority of my posts on other threads, you will see that I am actually very helpful.
    Lighten up, we (me and "people like me") are just having a little fun here. :)
  19. Sep 10, 2014 at 3:48 PM
    #79
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    at honda idk about others engines are assembled in Lincoln Alabama. They don't come assembled. A gallon or so of fuel is placed in tank. Then they are run around a small test track. If no rattles heard they go to storage for shipment. That's not broken in IMO.
    The blanket state of all engines is incorrect.
    How do I know?
    Quality control at Honda.
  20. Sep 10, 2014 at 4:55 PM
    #80
    Jimmyh
    SC
    2012 Prerunner SR5
    No wonder Honda sucks. [​IMG]
