Breaks stuck after washing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hook, Jun 30, 2024.
  1. Jun 30, 2024 at 12:08 PM
    Hook
    Hook [OP] New Member
    Hook
    2121 Trd off road
    Stock for now
    Washed my 21 Tacoma , backed into its spot, next day right rear e brake stuck! Tried rocking in low range, ( mines a manual) no help, then read on here about pulling e brake lever a few times while I'm under truck wiggling the lines, that worked and thanks to the people who wrote this.
    BUT, I didn't wash under truck only sprayed wheels to clean, so how in the hell does this happen, and yes I will now drive before parking, and YES, I'm now afraid to use ebrake.
  2. Jun 30, 2024 at 12:10 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    Breaks......?
    what BROKE?
    PLEASE post pics of your 2121 tacoma
    and welcome to TW
    Chew likes this.
  3. Jun 30, 2024 at 12:14 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    really ?
    fmb and Chew like this.
  4. Jun 30, 2024 at 12:18 PM
    Pwakchop
    Pwakchop Well-Known Member
    Nate
    Georgia
    2021 Cement DCSB TRD Sport
    Whole lotta' momentum
    Happened to me too, only sprayed the wheels. I just don't use the parking brake for a couple hours after I wash, no big deal. Happens to every drum brake vehicle I've owned.
  5. Jun 30, 2024 at 12:25 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Try stomping on the brake pedal fairly hard 2 - 3 times and the rear drums should break free.
    I have never had my rear drums get stuck after driving in heavy rain, but I do block the tires with the E-brake off when washing.
  6. Jun 30, 2024 at 12:27 PM
    lbhsbz
    lbhsbz Well-Known Member
    You need new rear shoes…when they get some wear in them, the dumbass reaction bar parking brake system that Toyota started using in ‘05 likes to jamb up.
    Use OEM shoes only, and use a high moly grease on all linkage contact points. That’ll get you another couple year LS before you have to do it again.
    be careful giving it the beans in 4 low…I just bent the shit outta my brake shoes and the rivets holding the lower anchor block onto the backing plate using force to try and break them free…
    replace the shoes before they’re 1/2 way worn and you shouldn’t have this issue.
  7. Jun 30, 2024 at 4:42 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Same thing happened to me a few years back in the late summer, around 50k miles. Set the Parkin brake, I hand washed the truck, sprayed water around the wheels, and when I went to drive away the rear brakes were “locked up”. Wet drums does something very weird to the parking brake system.
    RIX TUX likes this.
  8. Jun 30, 2024 at 5:12 PM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    I’ve heard of this happening somewhat frequently.
