Breaks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Poe, Sep 14, 2014.
  1. Sep 14, 2014 at 7:18 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    How often are you suppose to get your brakes pads changed? I have 13k miles on my truck and every now and again ill hear some squeaking when breaking
  2. Sep 14, 2014 at 7:19 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    I'm at 50k, still good
  3. Sep 14, 2014 at 7:20 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I've got 80k and still going. It's most likely brake dust.
  4. Sep 14, 2014 at 7:20 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Brakes
    When they are needed. Varies based on driving habits, towing and city or highway. Anywhere from 30-80K
  5. Sep 14, 2014 at 7:21 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    B R A K E S
    Inspect and change as needed.
  6. Sep 14, 2014 at 7:24 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    i spell good
  7. Sep 14, 2014 at 7:26 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    so whats the solution
  8. Sep 14, 2014 at 7:27 PM
    teneighty
    Spray with water
  9. Sep 14, 2014 at 7:29 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    haha ive done that still squeaking. :cool:
  10. Sep 14, 2014 at 7:29 PM
    Chicane
    Chicane Well-Known Member
    So Cal(Huntington Beach)
    14 DCSB TRD Sport
    Just to give you an idea. My 2004 Silverado was at 142,000 on original brakes when I traded it in. I'm guessing you are good.
  11. Sep 14, 2014 at 7:31 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    hopefully. just checking thanks guys
  12. Sep 14, 2014 at 7:34 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    You can get squeaks from the back of the pads rubbing on the pistons, pop the pads out and put copper grease on the back of the pads.
  13. Sep 14, 2014 at 8:25 PM
    Cjanik
    Cjanik Senior Member
    Chase
    Vegas
    '11 4x4 Off-Road DCSB in MGM
    OME front & rear shocks, OME 886 springs, Dakar rear leaf pack, ICON UCA, Demello front bumper, BFG M/T 255/85r16
    when your brakes are "squeaking" from being low on pad, you'll KNOW when its the low pad indicator. that shits LOUD AND ANNOYING. you wont be guessing.
  14. Sep 15, 2014 at 7:22 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    This...depends on how much stop and go, etc...
    I usually get about 40k before front pads are needed...longer on the drums (89k on my old 06 and still did not need replacement)
  15. Sep 15, 2014 at 7:34 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    Easiest way to get rid of a minor squeak with brakes is to dress the rotors with some fine grit sandpaper. Take the wheels off, and sand the slight shininess off the rotors. Just spin the rotor with the sandpaper and take the glaze off. That should relieve the squeal.
  16. Sep 15, 2014 at 7:45 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Try some CRC Brake Quiet.
    They have it at Autozone and NAPA.
  17. Sep 15, 2014 at 7:49 AM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    If the rear drum brakes didn't need replacing after 89K do you think they needing adjusting? Perhaps the fronts are doing more than their share of the work. I know the fronts do more than the rears, but maybe the rears should be doing more. Just curious.
  18. Sep 15, 2014 at 7:49 AM
    ducati
    ducati thie-trickster
    Carlsbad, CA
    2013 DC 4x4 Black
    Icon coils, Squeaky dakars, Thule rack, tinted windows, weathertech rain guards, Demello off road front bumper, warn winch, shok sound deadening.
    The squeak is most likely coming from the rear drum brakes. Mine does it as well. I haven't fixed yet. Usually solved with louder music.
  19. Sep 15, 2014 at 7:51 AM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    Douse the "breaks" and rotors with this.
  20. Sep 15, 2014 at 11:15 AM
    jerzeyjoe
    jerzeyjoe Well-Known Member
    New Jersey
    08 Prerunner 2W
    I had lose to 60,000 miles. Changed them when I rotated the tires. Still had some pad left, but with the tires off, half the work was already done.
