Breathers,Diff,transfer,Transmission
Discussion in 'Technical Chat' started by BRP27, Apr 26, 2010.
  1. Apr 26, 2010 at 1:32 PM
    BRP27
    BRP27 [OP] When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    I did the rear differential breather today. Easy Mod. Went to check the Transfer case and transmission breathers to see where they are at and how high up on the truck they are. On my 04 Tacoma the transmission breather is not running up higher, its right on top of the transmission.
    Here is the Differential breather that I put in behind the left rear tail light
    http://i533.photobucket.com/albums/ee334/studiduserid/Breathers005.jpg
    Here is the transmission case breather on top of case up by shift
    http://i533.photobucket.com/albums/ee334/studiduserid/Breathers002.jpg
    And the other breather on the transmission is also on top of the case. You cant see it because of the angle and how close it is to the floor board by the shifters
    http://i533.photobucket.com/albums/ee334/studiduserid/Breathers001.jpg
    The breathers are just like the one on top of the Diff,except they are molded into the transmission case. Which means you have to attach the hose to the top piece after you remove the cap.
    http://i533.photobucket.com/albums/ee334/studiduserid/Breathers004.jpg
    Here is the point of this post. The transmission on a 04 Tacoma Does not come from the factory with the breather raised up, at least not all of them? I will need to access the top of these cases from inside the cab buy pulling off the shifter boots and the cover to get at the top of the cases. There were a lot of posts that said these case breathers were already raised up. There are two breathers under the Hood probably going to Frt Diff and transfer case. But the ones I found on top of the transmission will need to be moved or water will come in thru them.
  2. Apr 26, 2010 at 1:42 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Hmmm, thats strange. My front diff/transfer case breathers are under the hood on the drivers side wheel well. NOt sure about the tranny.
  3. Apr 26, 2010 at 2:02 PM
    BRP27
    04 4X4 Tacoma SR5
    The breathers I am seeing are on top of the cases right where the shift levers come thru
    What I have read the frt diff, transfer and trans have breathers up high. I have a breather on each shift lever cover on the transmission
    I see the breathers on the fender well but I am seeing breathers that do not have hoses on them
    here is a picture on another engine that may be showing the breathers
    I plan to pull the cover off the shift levers and take a better look and run these vents up higher. Will get pictures if I can of the top of the trans and transfer.
  4. May 8, 2010 at 1:55 PM
    BRP27
    04 4X4 Tacoma SR5
    So I am answering my own questions, I get Rep for that
    Those are breathers on top of the transmission. I took off the shifter covers and there are two breathers on top of the trans. They do not screw out. I had to use the existing fitting and hook hoses up to them. These breathers are cast in.
    I ran fuel hose into a Tee and then ran this up to the firewall and put a breather above the frt diff and transfer breather. The shinny parts are the breathers after I pulled the caps off the breathers. I attached the fuel hose to these pieces. Be sure to get the hose on flush so it doesn not come off. These fittings are not ideal but it's what I had to deal with since they did not have the Hex head that the Rear diff breathers have
    the hoses are hooked up
    Routing
    I mounted the new breather behind the battery/fuse box
    chrslefty likes this.
  5. May 8, 2010 at 2:03 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    im curious, does the auto have a breather or is it a sealed unit?
  6. May 8, 2010 at 2:04 PM
    BRP27
    04 4X4 Tacoma SR5
    So if you have done the rear diff breather you are only good for water crossings that are below the top of the transmission unless you raise the transmission breathers.
  7. May 8, 2010 at 2:08 PM
    BRP27
    04 4X4 Tacoma SR5
    Not sure you would need to look under the truck or look at the FSM. There was some info out on my manual trans that it had a breather up to the inner fender well, that was not true.
  8. May 8, 2010 at 5:16 PM
    BRP27
    04 4X4 Tacoma SR5
    Here is a pic of a breather that came off the Rear diff. The two that came off the top of the Transmission I had to pull the top cap off with pliers and then hook the fuel hose to the portion that was remaining.
  9. May 8, 2010 at 5:27 PM
    Jahwn
    Jahwn Active Member
    San Diego
    2004 Tacoma ext. cab 4x4 V6 5spd
    I'm about to do the rear diff, and was hoping to find more info on these other breathers for the tranny and front diff.
    Good info and pics, thanks for posting.
  10. May 8, 2010 at 5:35 PM
    BRP27
    04 4X4 Tacoma SR5
    I was surprised to find that the breathers were not elevated on the transmission. I don't understand why Toyota would do it for the transfer case and not the transmission
  11. May 8, 2010 at 8:58 PM
    BRP27
    04 4X4 Tacoma SR5
    Why would Toyota put two breathers on the transmission? The rear and front diffs have one breather each.The transfer case has one breather. Why two on the transmission and why not elevate these breathers on the transmission. The transfer case right behind it is installed with a elevated breather( I saw a hose coming off the transfer case, I did not check where it routed to, but I assume it goes under the hood on the wheel well).
  12. May 11, 2010 at 8:02 PM
    quattrokiwi
    quattrokiwi Well-Known Member
    Bruce
    Nor Cal
    04 Tacoma, Limited, TRD, Locked, Geared, 4x4
    The ones on the drivers side under the hood that are extended some from the factory are the front diff and the front actuator for 4x4. I traced these yesterday as I extended them up beside brake fluid reservoir
    TOMB likes this.
  13. May 12, 2010 at 6:48 AM
    BRP27
    04 4X4 Tacoma SR5
    Thanks, I appreaciate the feedback.
  14. May 14, 2010 at 3:35 PM
    BRP27
    04 4X4 Tacoma SR5
    Went out today to check the hoses to make sure every thing was the way I left it. Noticed that the breather hose on the front of the transmission is kinked possibly blocking air flow. The front breather on the transmission is higher up on the transmission . So the hose has to make a tight bend to miss the floor board. To keep it from kinking I inserted a stiff smaller tube inside the bigger tube. This worked.
  15. Apr 30, 2012 at 4:40 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    I'm gonna go ahead and sub this so I can check my T/TC breather status when i get time and raise it if needed.
  16. Jan 8, 2014 at 10:26 AM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    Info on this link helped me.
    I've been smelling what seemed to be "sewing machine oil" after being in 4WD, only at times.
    Guess when the weather gets warm I'll have to check out breather hoses.
    Too cold today. -7 so it'll wait until spring.
  17. Dec 15, 2018 at 4:09 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    I'm gonna make this thread like Lazarus. 4 years later back from the dead.
    So OP how's this held up for you? Did you ever find a breather for the t-case? @BRP27
  18. Dec 16, 2018 at 5:01 PM
    BRP27
    04 4X4 Tacoma SR5
    All elevated breathers are performing as I expected ( no problems) . Never found a breather on T -case .
  19. Jan 13, 2019 at 1:41 AM
    4 by bryce
    4 by bryce New Member
    Bryce
    Edmonton
    04' tacoma 4x4
    Just did this on my 04 auto trans. I could only find a trans breather and what looks like a vent? Put them both further up into my engine bay I might be able to post photos if anybody is interested
  20. Jan 13, 2019 at 1:52 AM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Please do so!
