Breathers, Rear Diff & Front Diff -- Metric threads?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco2021LB, Apr 16, 2021.
  1. Apr 16, 2021 at 8:38 AM
    Taco2021LB
    Taco2021LB [OP] Well-Known Member
    Don
    WA
    2004 DblCab 4x4
    OME 882 Dakars Falken 235/85R16s
    After calling the local Auto Parts shops, nothing is getting pulled up for the Toyota part numbers. (90404-51026), (90404-51319)
    Online, I find them no problem. Toyota direct = No problem.
    I want a solution NOW.
    Question for anyone that may know.
    The breathers for the front and rear differential, I assume are Metric thread? What?
    I'm going to pull the rear.
    The hydraulic shop can likely get me fixed up.
  2. Apr 16, 2021 at 8:44 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    All the parts that I have ordered from the local Toyota Part Dept were delivered the NEXT DAY.
    Can't hardly get much faster, unless its sitting on the shelf.
    Amazon isn't that fast.
  3. Apr 16, 2021 at 8:48 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    As stated, just order from Amazon, Ebay, or even from a Toyota dealer.
    A lot of them are the same between different models even.
    If you've got your old one, and wanted to find the size/etc. take your current one off and take it to a hardware store where you can measure size/pitch.
    Huffster 3108 likes this.
  4. Apr 16, 2021 at 12:38 PM
    Taco2021LB
    Don
    WA
    2004 DblCab 4x4
    I went to the Hydraulic shop.
    The boys there, they had me fixed up with 3 threaded (barbed/no clamp necessary) nipples, and 12ft of 1/4" hose, in about 5 minutes.
    $20/OTD ;)
    The Front Diff and T/C went high on the FW.
    The rear vented to the gas fill area.
    All Installed
    DONE
    Wulf likes this.
  5. Apr 16, 2021 at 1:07 PM
    Taco2021LB
    Don
    WA
    2004 DblCab 4x4
    I ordered a wind deflector for the moon roof, and never got a call back. I gave up on that.
    I also ordered inner CV (Diff) seals and was told they'd be there the next day. Called, and nothing. The 2nd day I went to NAPA, and had them in my hands that day.
    Toyota Parts called me 4 days later, and said the parts were in. I told them I got them elsewhere, because I needed my truck on the road.
