Brians 05 Tacoma
Discussion in 'Long Travel Suspension' started by dirt designs, Jan 14, 2013.
  1. Jan 14, 2013 at 6:29 PM
    dirt designs
    dirt designs [OP] Well-Known Member
    slo
    01 Tacoma race truck
    Only factory parts left is cab and frame rails
    First Dirt Designs bolt on LT kit. I stuck with full race kits for the last 4 years but finally have designed some bolt in parts. The truck came in with replacement ucas+icons and is leaving with 8" kings and 15" of bolt on travel. With 35x12.5 tires!! The kit is a total of 6" over: 4" over arms and 2" for reworking the spindle geometry for better handling. It will use the stock hubs, brakes, and will still use the factory speed sensor.
    Should be getting finished up here within the next week and then i will start taking pre orders on these kits if anyone wants one.
  2. Jan 14, 2013 at 6:31 PM
    Blacktacoma23
    Blacktacoma23 CO
    Denver
    2011 TACO
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, Nitto Mud Grapplers, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5%/30% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
  3. Jan 14, 2013 at 7:09 PM
    MEMO CAMPOS
    MEMO CAMPOS Well-Known Member
    Westminster, Ca.
    05 PRERUNNER
    TC Upper Arms, ICON coilovers, Camburg spindles, AP standard leaf packs, ICON Resi.'s, AFE intake, Magnaflow Magnapack, Defiant Light Bar with PIAA 580's, 6K HID's top and bottom
  4. Jan 15, 2013 at 1:57 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Looks good.
    Any plans for a 4WD kit? Or 4WD compatible spindles?
  5. Jan 15, 2013 at 6:40 PM
    dirt designs
    slo
    This kit was designed to be just 2wd race. Its not just a lift spindle, so all the geometry is reworked and cant be made to work with 4wd.
    What kind of 4wd kit would you be wanting? Extended arms only? Arms+new spindles? If there is enough people interested in a kit I can design and build some. The hub blocks i have made work with 4wd.
  6. Jan 15, 2013 at 6:53 PM
    MEMO CAMPOS
    Westminster, Ca.
    05 PRERUNNER
    What geometry is different in the spindle and what type of handling is improved?
  7. Jan 15, 2013 at 9:06 PM
    dirt designs
    slo
    Reduced scrub radius (not wheel scrub). This means forces going into the steering through the tire are reduced.....40% less with this spindle then stock actually. And not just into the steering wheel, but less forces through the steering rack also. This does not mean you lose feeling of the tires, it really does just mean less forces going through your steering system completely. You will have more control in rough terrain, truck wont wander as much (caster doesnt only play a roll in this), and your steering should survive longer then a stock spindle.
    BIG reason why people shouldnt run wheel spacers!
  8. Jan 16, 2013 at 12:26 AM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    What I'm looking for is a fully fabricated 4WD spindle. Horizontal or vertical uniball I don't really care. I'm just tired of bending gussetted spindles. I know there are a good amount of us here and on TTORA that want a strong spindles available for 4WD's.
    I'm looking at building a custom LCA in the future (keeping same geometry of my All Pro 2'' kit but going with a boxed construction and secondary shock mount).
  9. Jan 16, 2013 at 8:22 AM
    MEMO CAMPOS
    Westminster, Ca.
    05 PRERUNNER
    Wow sounds amazing! Not to mention your actually improving even past the factory set up! You just made my LT decision and shopping even harder! I too agree with the spacer thing being in the wheel and tire business for 12 yrs now...
  10. Jan 16, 2013 at 9:52 AM
    Anthony250
    Anthony250 E-Fabber
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    TC Kit, Methods Double Standards, Sway Away, King Shocks. Prp Seats, 35's
    Nice work Steve, Im a big fan the red tacoma you built.
  11. Jan 16, 2013 at 8:45 PM
    dirt designs
    slo
    Thank you. Someday ill get back to that truck and start racing again.
    Some pics with 35x12.5
  12. Jan 16, 2013 at 10:02 PM
    Bandwagon
    Bandwagon Well-Known Member
    Escondido/San diego
    Camburg long travel, full glass,
    Will u be able to run a bypass also?
  13. Jan 16, 2013 at 10:08 PM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    What gears to push those 35s?
  14. Jan 16, 2013 at 10:16 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    i cant wait to get behind the wheel!!!! :D
    :burnrubber:
    running bypasses after i get and engine cage and bumping off the spindle when it happens. as for pushing the 35s, ill be running 4.88s
  15. Jan 16, 2013 at 10:17 PM
    dirt designs
    slo
    Of course! Im working on a upper bypass mount too
    Probably around there (4.88) but im not sure if hes swapping to 35s yet. These were the spares off a chevy we used for mockup to see if they cleared
  16. Jan 16, 2013 at 10:40 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Looking good! Any plans for 1st gen kits? Just curious.
  17. Jan 16, 2013 at 10:45 PM
    FBGW01
    FBGW01 Well-Known Member
    Kaleb
    East Mesa AZ
    check my build
    x2! :D
  18. Jan 16, 2013 at 11:03 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
  19. Jan 16, 2013 at 11:08 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Wait is this your rig??
  20. Jan 16, 2013 at 11:29 PM
    tacokid09
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    yes sir! :D
